[PATCH v3 5/9] board: freescale: ls1088a: Update I2C mux config
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson stcarlso@linux.microsoft.com --- board/freescale/ls1088a/ls1088a.c | 32 ++++--------------- configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls1088aqds_tfa_defconfig | 1 + configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_qspi_defconfig | 1 + ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_sdcard_qspi_defconfig | 1 + configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1088ardb_tfa_defconfig | 1 + 13 files changed, 18 insertions(+), 26 deletions(-)
diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index f5dc449d89..2f422634d5 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -26,6 +26,7 @@ #include <asm/arch/fsl_serdes.h> #include <asm/arch/soc.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> +#include "../common/i2c_mux.h"
#include "../common/qixis.h" #include "ls1088a_qixis.h" @@ -415,34 +416,13 @@ unsigned long get_board_ddr_clk(void) return 66666666; }
-int select_i2c_ch_pca9547(u8 ch) -{ - int ret; - -#if !CONFIG_IS_ENABLED(DM_I2C) - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); -#else - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(0, I2C_MUX_PCA_ADDR_PRI, 1, &dev); - if (!ret) - ret = dm_i2c_write(dev, 0, &ch, 1); -#endif - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - #if !defined(CONFIG_SPL_BUILD) void board_retimer_init(void) { u8 reg;
/* Retimer is connected to I2C1_CH5 */ - select_i2c_ch_pca9547(I2C_MUX_CH5); + select_i2c_ch_pca9547(I2C_MUX_CH5, 0);
/* Access to Control/Shared register */ reg = 0x0; @@ -532,7 +512,7 @@ void board_retimer_init(void)
#ifdef CONFIG_TARGET_LS1088AQDS /* Retimer is connected to I2C1_CH5 */ - select_i2c_ch_pca9547(I2C_MUX_CH5); + select_i2c_ch_pca9547(I2C_MUX_CH5, 0);
/* Access to Control/Shared register */ reg = 0x0; @@ -620,7 +600,7 @@ void board_retimer_init(void)
#endif /*return the default channel*/ - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); }
#ifdef CONFIG_MISC_INIT_R @@ -669,7 +649,7 @@ int misc_init_r(void)
int i2c_multiplexer_select_vid_channel(u8 channel) { - return select_i2c_ch_pca9547(channel); + return select_i2c_ch_pca9547(channel, 0); }
#ifdef CONFIG_TARGET_LS1088AQDS @@ -827,7 +807,7 @@ int board_init(void) u32 __iomem *irq_ccsr = (u32 __iomem *)ISC_BASE; #endif
- select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); board_retimer_init();
#ifdef CONFIG_ENV_IS_NOWHERE diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 55e52c8770..c36f37d5d1 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -74,3 +74,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index 9dc5f8dbb2..d401b91c40 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -75,3 +75,4 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 91903bd110..5711464e77 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -76,3 +76,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index fcb48741e3..fdeddaef44 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -82,3 +82,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 3e8c269add..6f30c6a284 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -85,3 +85,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index a0bd0cb23d..0df21ccd21 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -100,3 +100,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 6cd0251dd0..981da5f9af 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -76,3 +76,4 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index b71e60983f..1b3affc86a 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -77,3 +77,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 997f505778..a351ae48c5 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -87,3 +87,4 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 64b3136a3e..790ccbdb51 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -86,3 +86,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index 473dd08ba8..344fa73a99 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -85,3 +85,4 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index a3c7953303..082578d16b 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -92,3 +92,4 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y
Stephen Carlson
