[U-Boot] [PATCH 2/2] ppc4xx: Add board specific function to return the detected flash size
This function will be called to fixup size of the "reg" property of the NOR flash device tree nodes. Ebony can't use the weak default, since it has a special chip-select to bank-number binding.
Signed-off-by: Stefan Roese sr@denx.de --- board/amcc/ebony/flash.c | 31 +++++++++++++++++++++++++++++++ 1 files changed, 31 insertions(+), 0 deletions(-)
diff --git a/board/amcc/ebony/flash.c b/board/amcc/ebony/flash.c index 8fe3ba1..79d2c4c 100644 --- a/board/amcc/ebony/flash.c +++ b/board/amcc/ebony/flash.c @@ -34,6 +34,7 @@ #include <common.h> #include <ppc4xx.h> #include <asm/processor.h> +#include <asm/io.h>
#undef DEBUG #ifdef DEBUG @@ -71,6 +72,36 @@ static unsigned long flash_addr_table[8][CONFIG_SYS_MAX_FLASH_BANKS] = { */ static ulong flash_get_size(vu_long * addr, flash_info_t * info);
+/* + * Override the weak default mapping function with a board specific one + */ +u32 flash_get_bank_size(int cs, int idx) +{ + u8 reg = in_8((void *)CONFIG_SYS_FPGA_BASE); + + if ((reg & BOOT_SMALL_FLASH) && !(reg & FLASH_ONBD_N)) { + /* + * cs0: small flash (512KiB) + * cs2: 2 * big flash (2 * 2MiB) + */ + if (cs == 0) + return flash_info[2].size; + if (cs == 2) + return flash_info[0].size + flash_info[1].size; + } else { + /* + * cs0: 2 * big flash (2 * 2MiB) + * cs2: small flash (512KiB) + */ + if (cs == 0) + return flash_info[0].size + flash_info[1].size; + if (cs == 2) + return flash_info[2].size; + } + + return 0; +} + unsigned long flash_init(void) { unsigned long total_b = 0;
Dear Stefan Roese,
I think this commit must be merged into the previous one to keep the code bi-sectable (my understanding is that Ebony will break / not work correctly with only the first patch applied?).
Hi Wolfgang,
Without this patch, Ebony will continue to not work correctly (status quo). Only with both patches applied, this problem is fixed.
But, yes. I can squash them together and pull them into the ppc4xx repository for upstream merge, if nobody objects. Gerald, are you ok with this?
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
