[U-Boot] [PATCH v3] cmd: mem: Add a command to fill the memory with random data
This command fills the memory with data produced by rand().
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com --- changes in v3: - Add a new CONFIG option that depends on CMD_MEM
changes in v2: - Do not include the command if CONFIG_LIB_RAND is not set - make do_random() static
cmd/Kconfig | 7 +++++++ cmd/mem.c | 52 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 59 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index cda7931fe3..e180c8decd 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -550,6 +550,13 @@ config CMD_MEMORY base - print or set address offset loop - initialize loop on address range
+config CMD_RANDOM + bool "random" + default y + depends on CMD_MEMORY && (LIB_RAND || LIB_HW_RAND) + help + random - fill memory with random data + config CMD_MEMTEST bool "memtest" help diff --git a/cmd/mem.c b/cmd/mem.c index 392ed1756b..c6b8038fc9 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -1082,6 +1082,49 @@ static int do_mem_crc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#endif
+#ifdef CONFIG_CMD_RANDOM +static int do_random(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + unsigned long addr, len; + unsigned long seed; // NOT INITIALIZED ON PURPOSE + unsigned int *buf, *start; + unsigned char *buf8; + unsigned int i; + + if (argc < 3 || argc > 4) { + printf("usage: %s <addr> <len> [<seed>]\n", argv[0]); + return 0; + } + + len = simple_strtoul(argv[2], NULL, 16); + addr = simple_strtoul(argv[1], NULL, 16); + + if (argc == 4) { + seed = simple_strtoul(argv[3], NULL, 16); + if (seed == 0) { + printf("The seed cannot be 0. Using 0xDEADBEEF.\n"); + seed = 0xDEADBEEF; + } + } else { + seed = get_timer(0) ^ rand(); + } + + srand(seed); + start = map_sysmem(addr, len); + buf = start; + for (i = 0; i < (len / 4); i++) + *buf++ = rand(); + + buf8 = (unsigned char *)buf; + for (i = 0; i < (len % 4); i++) + *buf8++ = rand() & 0xFF; + + unmap_sysmem(start); + printf("%lu bytes filled with random data\n", len); + return 1; +} +#endif + /**************************************************/ U_BOOT_CMD( md, 3, 1, do_mem_md, @@ -1250,3 +1293,12 @@ U_BOOT_CMD( "" ); #endif + +#ifdef CONFIG_CMD_RANDOM +U_BOOT_CMD( + random, 4, 0, do_random, + "fill memory with random pattern", + "<addr> <len> [<seed>]\n" + " - Fill 'len' bytes of memory starting at 'addr' with random data\n" +); +#endif
Jean-Jacques Hiblot
