Pull request: u-boot-sunxi/master
Hi Tom,
Please pull this PR.
Summary: - H6 emac support - USB PHY H6 logic alignment
Travis-CI: https://gitlab.denx.de/u-boot/custodians/u-boot-sunxi
The following changes since commit d09b832cd8ccb7e37e2b188394df5a73d7074c3b:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-sh (2020-05-30 20:11:38 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-sunxi master
for you to fetch changes up to 1e7d00ae262e124eaf97d9e3ce4fb25739e4f5d6:
sunxi: H6: Enable Ethernet on the Pine H64 (2020-06-01 22:38:53 +0530)
---------------------------------------------------------------- Roman Stratiienko (1): phy: sun4i-usb: Align H6 initialization logic with the kernel
Samuel Holland (4): sunxi: Silence warning about non-static inline function net: sun8i_emac: Use consistent clock bitfield definitions net: sun8i_emac: Add support for the H6 variant sunxi: H6: Enable Ethernet on the Pine H64
arch/arm/mach-sunxi/dram_sunxi_dw.c | 18 +++++++++--------- configs/pine_h64_defconfig | 1 + drivers/net/sun8i_emac.c | 20 +++++++++++++------- drivers/phy/allwinner/phy-sun4i-usb.c | 6 ++++-- 4 files changed, 27 insertions(+), 18 deletions(-)
On Wed, Jun 03, 2020 at 12:19:32AM +0530, Jagan Teki wrote:
Hi Tom,
Summary:
- H6 emac support
Jagan Teki
