[U-Boot] [PATCH 1/3] crypto/fsl: fix "era" property value on LE platforms
Use fdt_setprop_u32() instead of fdt_setprop().
Fixes: 0181937fa371a ("crypto/fsl: Add fixup for crypto node") Signed-off-by: Horia Geantă horia.geanta@freescale.com Reviewed-by: Mingkai Hu Mingkai.Hu@freescale.com --- drivers/crypto/fsl/sec.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/crypto/fsl/sec.c b/drivers/crypto/fsl/sec.c index 443ee964feae..b25b1a4052d2 100644 --- a/drivers/crypto/fsl/sec.c +++ b/drivers/crypto/fsl/sec.c @@ -155,8 +155,7 @@ static void fdt_fixup_crypto_era(void *blob, u32 era) return; }
- err = fdt_setprop(blob, crypto_node, "fsl,sec-era", &era, - sizeof(era)); + err = fdt_setprop_u32(blob, crypto_node, "fsl,sec-era", era); if (err < 0) { printf("ERROR: could not set fsl,sec-era property: %s\n", fdt_strerror(err));
HW coherency won't work properly for CAAM write transactions if AWCACHE is left to default (POR) value - 4'b0001. It has to be programmed to 4'b0010.
For platforms that have HW coherency support: -PPC-based: the update has no effect; CAAM coherency already works due to the IOMMU (PAMU) driver setting the correct memory coherency attributes -ARM-based: the update fixes cache coherency issues, since IOMMU (SMMU) driver is not programmed to behave similar to PAMU
Fixes: b9eebfade974c ("fsl_sec: Add hardware accelerated SHA256 and SHA1") Signed-off-by: Horia Geantă horia.geanta@freescale.com Reviewed-by: Aneesh Bansal aneesh.bansal@freescale.com Reviewed-by: Mingkai Hu Mingkai.Hu@freescale.com --- drivers/crypto/fsl/jr.c | 10 ++++++---- drivers/crypto/fsl/jr.h | 2 ++ 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index f99d59480c81..e2bd913aa259 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -459,14 +459,16 @@ static int rng_init(void)
int sec_init(void) { - int ret = 0; - -#ifdef CONFIG_PHYS_64BIT ccsr_sec_t *sec = (void *)CONFIG_SYS_FSL_SEC_ADDR; uint32_t mcr = sec_in32(&sec->mcfgr); + int ret = 0;
- sec_out32(&sec->mcfgr, mcr | 1 << MCFGR_PS_SHIFT); + mcr = (mcr & ~MCFGR_AWCACHE_MASK) | (0x2 << MCFGR_AWCACHE_SHIFT); +#ifdef CONFIG_PHYS_64BIT + mcr |= (1 << MCFGR_PS_SHIFT); #endif + sec_out32(&sec->mcfgr, mcr); + ret = jr_init(); if (ret < 0) { printf("SEC initialization failed\n"); diff --git a/drivers/crypto/fsl/jr.h b/drivers/crypto/fsl/jr.h index cce2c589ce0b..152606008845 100644 --- a/drivers/crypto/fsl/jr.h +++ b/drivers/crypto/fsl/jr.h @@ -21,6 +21,8 @@ #define MCFGR_SWRST ((uint32_t)(1)<<31) /* Software Reset */ #define MCFGR_DMA_RST ((uint32_t)(1)<<28) /* DMA Reset */ #define MCFGR_PS_SHIFT 16 +#define MCFGR_AWCACHE_SHIFT 8 +#define MCFGR_AWCACHE_MASK (0xf << MCFGR_AWCACHE_SHIFT) #define JR_INTMASK 0x00000001 #define JRCR_RESET 0x01 #define JRINT_ERR_HALT_INPROGRESS 0x4
Applied to u-boot-fsl-qoriq master with minor change in subject. Thanks.
York
Signed-off-by: Horia Geantă horia.geanta@freescale.com --- drivers/crypto/fsl/sec.c | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/drivers/crypto/fsl/sec.c b/drivers/crypto/fsl/sec.c index b25b1a4052d2..0940faf768cc 100644 --- a/drivers/crypto/fsl/sec.c +++ b/drivers/crypto/fsl/sec.c @@ -60,27 +60,26 @@ void fdt_fixup_crypto_node(void *blob, int sec_rev) return; }
- val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].num_channels); - err = fdt_setprop(blob, crypto_node, "fsl,num-channels", &val, 4); + err = fdt_setprop_u32(blob, crypto_node, "fsl,num-channels", + sec_rev_prop_list[sec_idx].num_channels); if (err < 0) printf("WARNING: could not set crypto property: %s\n", fdt_strerror(err));
- val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].descriptor_types_mask); - err = fdt_setprop(blob, crypto_node, "fsl,descriptor-types-mask", - &val, 4); + err = fdt_setprop_u32(blob, crypto_node, "fsl,descriptor-types-mask", + sec_rev_prop_list[sec_idx].descriptor_types_mask); if (err < 0) printf("WARNING: could not set crypto property: %s\n", fdt_strerror(err));
- val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].exec_units_mask); - err = fdt_setprop(blob, crypto_node, "fsl,exec-units-mask", &val, 4); + err = fdt_setprop_u32(blob, crypto_node, "fsl,exec-units-mask", + sec_rev_prop_list[sec_idx].exec_units_mask); if (err < 0) printf("WARNING: could not set crypto property: %s\n", fdt_strerror(err));
- val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].channel_fifo_len); - err = fdt_setprop(blob, crypto_node, "fsl,channel-fifo-len", &val, 4); + err = fdt_setprop_u32(blob, crypto_node, "fsl,channel-fifo-len", + sec_rev_prop_list[sec_idx].channel_fifo_len); if (err < 0) printf("WARNING: could not set crypto property: %s\n", fdt_strerror(err));
York
York
Horia Geantă
York Sun
