[U-Boot] [PATCH] am33xx: pcm051: Remove wp pin mux for sd-card
The pcm051 does not have the wp pin connected to the sd-card socket. Therefore remove the pinmux for the pin. The was a carry-over from the am335x evm code.
Signed-off-by: Lars Poeschel poeschel@lemonage.de --- board/phytec/pcm051/mux.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/phytec/pcm051/mux.c b/board/phytec/pcm051/mux.c index 2cda331..74a873e 100644 --- a/board/phytec/pcm051/mux.c +++ b/board/phytec/pcm051/mux.c @@ -35,7 +35,6 @@ static struct module_pin_mux mmc0_pin_mux[] = { {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ - {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ {OFFSET(spi0_cs1), (MODE(5) | RXACTIVE | PULLUP_EN)}, /* MMC0_CD */ {-1}, };
Applied to u-boot-ti/master, thanks!
Lars Poeschel
