[U-Boot] [Bug Report] USB: descriptor handling
I found a bug when working with the u-boot USB subsystem on IXP425 processor (big endian Xscale aka ARMv5). I recognized that the second usb_endpoint_descriptor of the attached memory stick was corrupted.
The reason for this are the packed structures below (either u-boot and u-boot-usb):
-------------- /* Endpoint descriptor */ struct usb_endpoint_descriptor { unsigned char bLength; unsigned char bDescriptorType; unsigned char bEndpointAddress; unsigned char bmAttributes; unsigned short wMaxPacketSize; unsigned char bInterval; unsigned char bRefresh; unsigned char bSynchAddress;
} __attribute__ ((packed)); /* Interface descriptor */ struct usb_interface_descriptor { unsigned char bLength; unsigned char bDescriptorType; unsigned char bInterfaceNumber; unsigned char bAlternateSetting; unsigned char bNumEndpoints; unsigned char bInterfaceClass; unsigned char bInterfaceSubClass; unsigned char bInterfaceProtocol; unsigned char iInterface;
unsigned char no_of_ep; unsigned char num_altsetting; unsigned char act_altsetting; struct usb_endpoint_descriptor ep_desc[USB_MAXENDPOINTS]; } __attribute__ ((packed)); ------------
As usb_endpoint_descriptor is only 7byte in length, the start of all odd ep_desc[] structures is not word aligned. This makes wMaxPacketSize of these structures also not word aligned.
ARMv5 Architecture however does not support non-aligned multibyte data type (see A2.8 of ARM Architecture Reference Manual).
--- this piece of code in usb.c ------- case USB_DT_ENDPOINT: epno = dev->config.if_desc[ifno].no_of_ep; /* found an endpoint */ { int ii; USB_PRINTF("EPD(%d): ", buffer[index]); for(ii=0; ii<buffer[index]; ii++){ USB_PRINTF("%.2x ", buffer[index+ii]); } USB_PRINTF("\n"); } dev->config.if_desc[ifno].no_of_ep++; memcpy(&dev->config.if_desc[ifno].ep_desc[epno], &buffer[index], buffer[index]); le16_to_cpus(&(dev->config.if_desc[ifno].ep_desc[epno].\ wMaxPacketSize)); { int ii; USB_PRINTF("EPD(%d): ", buffer[index]); for(ii=0; ii<buffer[index]; ii++){ USB_PRINTF("%.2x ",*((unsigned char *)(&dev->config.if_desc[ifno].ep_desc[epno])+ii)); } USB_PRINTF("\n"); } USB_PRINTF("if %d, ep %d\n", ifno, epno); break; ----and following output (shortened) --- <first descriptor> EPD(7): 07 05 81 02 40 00 00 <- before endian swapping EPD(7): 07 05 81 02 00 40 00 <- after endian swapping <second descriptor> EPD(7): 07 05 02 02 40 00 00 EPD(7): 07 05 02 02 00 40 00 -------
It seems that the actual ARM implementation does support reading of non-aligned words (else USB would never have run on ARM) but writing is definitely not. You see the data of the second descriptor garbled. As writing is only needed on big endian ARM (for data swapping) this issue has been undetected up to now.
Either wMaxPacket size must be accessed with special code, or it must be aligned to modulo-2 address.
I suggest:
------------ diff --git a/include/usb.h b/include/usb.h index 9a2e72c..b36272b 100644 --- a/include/usb.h +++ b/include/usb.h @@ -93,8 +93,7 @@ struct usb_endpoint_descriptor { unsigned char bInterval; unsigned char bRefresh; unsigned char bSynchAddress; - -} __attribute__ ((packed)); +} __attribute__ ((packed)) __attribute__ ((aligned(2))); /* Interface descriptor */ struct usb_interface_descriptor { unsigned char bLength; ------------
With this change memory stick is identied correctly. I can do "fatls", but I cannot read data correctly from the disk. But might be something completely different issue ....
--- Stefan
Hello Stefan,
Nice catch!
Hmm, I count 9 bytes instead of 7...
As writing is only needed on big endian ARM (for data swapping) this issue has been undetected up to now. Either wMaxPacket size must be accessed with special code, or it must be aligned to modulo-2 address.
I suggest:
I agree, but this patch seems to be whitespace/tab broken...
I tested it, and fatls/fatload still works on ARM (at91), no regression detected with this patch so far.
Kind regards,
Remy
Hi
<snip>
The reason for this was corrupted PCI setup, which prevented the USB controller to bus-master to some memory regions.
USB memory stick now works great with IXP425 and ISP1562 or ISP1564.
The 1564 has the advantage that both USB ports are usable at a time as they are handled by the same controller.
The 1562 has one PCI device for each USB port. I think this is not handled in u-boot.
Well done all supporters.
--- Stefan
Remy Bohmer
Stefan Althoefer
