[U-Boot] [PATCH] rockchip: Set up default PWM flags
At present if the PWM set_invert() method is not called then the flags are not set up and the driver does not work properly. Fix this by setting up the default flags when probing.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: 874ee59 (rockchip: pwm: implement pwm_set_invert()) ---
drivers/pwm/rk_pwm.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pwm/rk_pwm.c b/drivers/pwm/rk_pwm.c index f3b2f7615d..5d78d4a67d 100644 --- a/drivers/pwm/rk_pwm.c +++ b/drivers/pwm/rk_pwm.c @@ -92,6 +92,7 @@ static int rk_pwm_probe(struct udevice *dev) return -EINVAL; } priv->freq = clk_get_rate(&clk); + priv->enable_conf = PWM_DUTY_POSTIVE | PWM_INACTIVE_POSTIVE;
return 0; }
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Philipp Tomsich
