[PATCH v4] imx: imx8mm: Add support for Mettler-Toledo snowflake board.
The board is similar to "Kontron SL i.MX8M Mini" SoM. There are two variants. Snowflake_v2 has an external SDCard Interface. LEIG is the same, but without display and without external SDCard Interface. Both variants support only 1GiB of main memory.
[ bigeasy: porting and a bit of cleanup ]
Signed-off-by: Manuel Traut manuel.traut@mt.com Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Sebastian Andrzej Siewior bigeasy@linutronix.de --- v3…v4: - Added Frieder's tag - Rebased on top of v2023.07-rc5. v2…v3: Addressing Frieder's comments: - Add "kontron,imx8mm-sl" to the compatible string. - Remove pca9450 node and pinctrl_i2c1. The included imx8mm-kontron-sl.dtsi already provides this. - Merge the overwritten values in dram_timing.ddrc_cfg/fsp_msg directly into lpddr4_timing.c. - Simplify the init in spl_dram_init() and panic() if the init failed. - Replace a reference to SMARC with the current product name of the SoM.
v1…v2: - Clarify details about the board and whether or not there is an external SD-card interface.
arch/arm/dts/Makefile | 1 + .../dts/imx8mm-mt-snowflake-v2-u-boot.dtsi | 116 ++ arch/arm/dts/imx8mm-mt-snowflake-v2.dts | 76 + arch/arm/mach-imx/imx8m/Kconfig | 8 + board/mt/snowflake_v2/Kconfig | 18 + board/mt/snowflake_v2/MAINTAINERS | 7 + board/mt/snowflake_v2/Makefile | 9 + board/mt/snowflake_v2/imximage.cfg | 8 + board/mt/snowflake_v2/lpddr4_timing.c | 1844 +++++++++++++++++ board/mt/snowflake_v2/snowflake_v2.c | 32 + board/mt/snowflake_v2/snowflake_v2.env | 33 + board/mt/snowflake_v2/spl.c | 147 ++ configs/snowflake_v2_emmcboot_defconfig | 134 ++ include/configs/snowflake_v2.h | 55 + 14 files changed, 2488 insertions(+) create mode 100644 arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-mt-snowflake-v2.dts create mode 100644 board/mt/snowflake_v2/Kconfig create mode 100644 board/mt/snowflake_v2/MAINTAINERS create mode 100644 board/mt/snowflake_v2/Makefile create mode 100644 board/mt/snowflake_v2/imximage.cfg create mode 100644 board/mt/snowflake_v2/lpddr4_timing.c create mode 100644 board/mt/snowflake_v2/snowflake_v2.c create mode 100644 board/mt/snowflake_v2/snowflake_v2.env create mode 100644 board/mt/snowflake_v2/spl.c create mode 100644 configs/snowflake_v2_emmcboot_defconfig create mode 100644 include/configs/snowflake_v2.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60653..c0806b92c7bf4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -981,6 +981,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-kontron-bl.dtb \ imx8mm-kontron-bl-osm-s.dtb \ + imx8mm-mt-snowflake-v2.dtb \ imx8mm-mx8menlo.dtb \ imx8mm-phg.dtb \ imx8mm-venice.dtb \ diff --git a/arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi b/arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi new file mode 100644 index 0000000000000..d6476db292b79 --- /dev/null +++ b/arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Mettler Toledo GmbH + */ + +/ { + + aliases { + usbgadget0 = &usbg1; + }; + + usbg1: usbg1 { + u-boot,dm-spl; + compatible = "fsl,imx27-usb-gadget"; + dr_mode = "peripheral"; + chipidea,usb = <&usbotg1>; + status = "okay"; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&i2c1 { + status = "okay"; + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&i2c2 { + status = "okay"; + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_ecspi1 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_100mhz { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_200mhz { + u-boot,dm-spl; +}; + +&pca9450 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@25/regulators} { + u-boot,dm-spl; +}; + +&ecspi1 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-mt-snowflake-v2.dts b/arch/arm/dts/imx8mm-mt-snowflake-v2.dts new file mode 100644 index 0000000000000..f56997543e6d9 --- /dev/null +++ b/arch/arm/dts/imx8mm-mt-snowflake-v2.dts @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Mettler Toledo GmbH + */ + +/dts-v1/; + +#include "imx8mm-kontron-sl.dtsi" +#include "imx8mm-u-boot.dtsi" + +/ { + model = "Mettler Toledo i.MX8MM Snowflake V2"; + compatible = "mt,imx8mm-snowflake-v2", "kontron,imx8mm-sl", "fsl,imx8mm"; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + disable-over-current; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x19 /* \SOM_RTC_INT */ + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x19 /* \SOM_USBC_INT */ + MX8MM_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x184 /* SOM_DIS_ID0 */ + MX8MM_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x184 /* SOM_DIS_ID1 */ + MX8MM_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x184 /* SOM_DIS_ID2 */ + MX8MM_IOMUXC_SAI2_TXC_GPIO4_IO25 0x19 /* SOM_PCB_ID0 */ + MX8MM_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x19 /* SOM_PCB_ID1 */ + MX8MM_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x19 /* SOM_PCBA_ID0 */ + MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x19 /* SOM_PCBA_ID1 */ + MX8MM_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x19 /* \SOM_STATLED_RES */ + MX8MM_IOMUXC_SAI5_RXC_GPIO3_IO20 0x19 /* \SOM_HUB_RES */ + MX8MM_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x19 /* \SOM_SUPPLY_EN */ + MX8MM_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x1c4 /* \SOM_COM_RES / version C */ + MX8MM_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x184 /* SOM_DBG_GPIO0 */ + MX8MM_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x184 /* SOM_DBG_GPIO1 */ + MX8MM_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x184 /* SOM_DBG_GPIO2 */ + MX8MM_IOMUXC_SAI3_TXD_GPIO5_IO1 0x184 /* SOM_DBG_GPIO3 version C */ + >; + }; + + pinctrl_sai1: sai1grp { + fsl,pins = < + MX8MM_IOMUXC_SAI1_TXFS_SAI1_TX_SYNC 0xd6 + MX8MM_IOMUXC_SAI1_TXC_SAI1_TX_BCLK 0xd6 + MX8MM_IOMUXC_SAI1_TXD0_SAI1_TX_DATA0 0xd6 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 7639439bdc97c..bd87511292894 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -167,6 +167,13 @@ config TARGET_IMX8MN_DDR4_EVK select FSL_CAAM select SPL_CRYPTO if SPL
+config TARGET_MT_SNOWFLAKE_V2 + bool "MT Snowflake v2" + select BINMAN + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_IMX8MN_VENICE bool "Support Gateworks Venice iMX8M Nano module" select BINMAN @@ -369,6 +376,7 @@ source "board/kontron/sl-mx8mm/Kconfig" source "board/menlo/mx8menlo/Kconfig" source "board/msc/sm2s_imx8mp/Kconfig" source "board/mntre/imx8mq_reform2/Kconfig" +source "board/mt/snowflake_v2/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/purism/librem5/Kconfig" diff --git a/board/mt/snowflake_v2/Kconfig b/board/mt/snowflake_v2/Kconfig new file mode 100644 index 0000000000000..f7c02ba1fbf61 --- /dev/null +++ b/board/mt/snowflake_v2/Kconfig @@ -0,0 +1,18 @@ +if TARGET_MT_SNOWFLAKE_V2 + +config SYS_BOARD + string + default "snowflake_v2" + +config SYS_VENDOR + string + default "mt" + +config SYS_CONFIG_NAME + string + default "snowflake_v2" + +config IMX_CONFIG + default "board/mt/snowflake_v2/imximage.cfg" + +endif diff --git a/board/mt/snowflake_v2/MAINTAINERS b/board/mt/snowflake_v2/MAINTAINERS new file mode 100644 index 0000000000000..e60d24e32f57e --- /dev/null +++ b/board/mt/snowflake_v2/MAINTAINERS @@ -0,0 +1,7 @@ +Mettler-Toledo Snowflake boards +M: Manuel Traut manuel.traut@mt.com +S: Maintained +F: arch/arm/dts/imx8mm-mt-snowflake* +F: board/mt/snowflake_v2 +F: configs/snowflake_v2_emmcboot_defconfig +F: include/configs/snowflake_v2.h diff --git a/board/mt/snowflake_v2/Makefile b/board/mt/snowflake_v2/Makefile new file mode 100644 index 0000000000000..6ced8f5b3e5ca --- /dev/null +++ b/board/mt/snowflake_v2/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (C) 2020 Mettler Toledo GmbH + +obj-y := snowflake_v2.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o +endif diff --git a/board/mt/snowflake_v2/imximage.cfg b/board/mt/snowflake_v2/imximage.cfg new file mode 100644 index 0000000000000..20061521f227e --- /dev/null +++ b/board/mt/snowflake_v2/imximage.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + + +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/mt/snowflake_v2/lpddr4_timing.c b/board/mt/snowflake_v2/lpddr4_timing.c new file mode 100644 index 0000000000000..6bfd10266ca99 --- /dev/null +++ b/board/mt/snowflake_v2/lpddr4_timing.c @@ -0,0 +1,1844 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x223 }, + { 0x3d400024, 0x3a980 }, + { 0x3d400064, 0x5b0087 }, + { 0x3d4000d0, 0xc00305ba }, + { 0x3d4000d4, 0x940000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x191e1920 }, + { 0x3d400104, 0x60630 }, + { 0x3d40010c, 0xb0b000 }, + { 0x3d400110, 0xe04080e }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xd8 }, + { 0x3d400144, 0x96004b }, + { 0x3d400180, 0x2ee0017 }, + { 0x3d400184, 0x2605b8e }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x21 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x21 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x2ee }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x21 }, + { 0x1200c7, 0x21 }, + { 0x2200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x1200ca, 0x24 }, + { 0x2200ca, 0x24 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x5d }, + { 0x2000c, 0xbb }, + { 0x2000d, 0x753 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/mt/snowflake_v2/snowflake_v2.c b/board/mt/snowflake_v2/snowflake_v2.c new file mode 100644 index 0000000000000..6510225321a06 --- /dev/null +++ b/board/mt/snowflake_v2/snowflake_v2.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler Toledo GmbH + */ + +#include <asm/arch/imx-regs.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <fdt_support.h> +#include <linux/arm-smccc.h> +#include <linux/errno.h> +#include <net.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_phys_sdram_size(phys_size_t *size) +{ + /* always 1GB RAM */ + *size = 0x40000000; + return 0; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return fdt_fixup_memory(blob, PHYS_SDRAM, gd->ram_size); +} + +int board_init(void) +{ + return 0; +} diff --git a/board/mt/snowflake_v2/snowflake_v2.env b/board/mt/snowflake_v2/snowflake_v2.env new file mode 100644 index 0000000000000..1ad9a2b2e17e7 --- /dev/null +++ b/board/mt/snowflake_v2/snowflake_v2.env @@ -0,0 +1,33 @@ +bootargs_base=console=ttymxc2,115200 vt.global_cursor_default=0 fbcon=font:VGA8x8 +script=boot.scr +bootdir= +bootdelay=1 +bootpart=1 +bootchooser=run bootchooser_1; run bootchooser_2; run bootchooser_3 +bootchooser_1=test -n ${BOOT_ORDER} || setenv BOOT_ORDER "system0 system1"; + test -n ${BOOT_system0_LEFT} || setenv BOOT_system0_LEFT 3; + test -n ${BOOT_system1_LEFT} || setenv BOOT_system1_LEFT 3; + setenv rauc_slot; +bootchooser_2=for BOOT_SLOT in ${BOOT_ORDER}; do if test x${rauc_slot} != x; then; + elif test x${BOOT_SLOT} = xsystem0; then + if test ${BOOT_system0_LEFT} -gt 0; then + echo Found valid slot system0, ${BOOT_system0_LEFT} attempts remaining; + setexpr BOOT_system0_LEFT ${BOOT_system0_LEFT} - 1; + setenv bootpart 1; setenv rauc_slot rauc.slot=system0; fi; + elif test x${BOOT_SLOT} = xsystem1; then + if test ${BOOT_system1_LEFT} -gt 0; then + echo Found valid slot system1, ${BOOT_system1_LEFT} attempts remaining; + setexpr BOOT_system1_LEFT ${BOOT_system1_LEFT} - 1; + setenv bootpart 2; setenv rauc_slot rauc.slot=system1; fi; fi; done +bootchooser_3=if test -n ${rauc_slot}; then saveenv; else + echo No valid slot found, resetting tries to 3; + setenv BOOT_system0_LEFT 3; setenv BOOT_system1_LEFT 3; + saveenv; reset; fi; echo Booting from ${rauc_slot}...; +emmcboot=run bootchooser; setenv bootargs ${bootargs_base} + root=/dev/mmcblk0p${bootpart} ro rootfstype=ext4 rootwait ${rauc_slot}; + echo Booting from eMMC; + ext4load mmc 0:${bootpart} ${scriptaddr} /boot/fitImage && bootm ${scriptaddr} +sdboot=run bootchooser; setenv bootargs ${bootargs_base} + root=/dev/mmcblk1p${bootpart} ro rootfstype=ext4 rootwait ${rauc_slot}; + echo Booting from SD card; + ext4load mmc 1:${bootpart} ${scriptaddr} /boot/fitImage && bootm ${scriptaddr} diff --git a/board/mt/snowflake_v2/spl.c b/board/mt/snowflake_v2/spl.c new file mode 100644 index 0000000000000..e28878db91cb3 --- /dev/null +++ b/board/mt/snowflake_v2/spl.c @@ -0,0 +1,147 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler Toledo GmbH + */ + +#include <common.h> +#include <spl.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/arch/ddr.h> +#include <asm/armv8/mmu.h> +#include <asm/gpio.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +#include <i2c.h> +#include <init.h> +#include <linux/delay.h> + +#include <power/pmic.h> +#include <power/pca9450.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + switch (boot_dev_spl) { + case SD1_BOOT: + case MMC1_BOOT: + return BOOT_DEVICE_MMC1; + case USB_BOOT: + return BOOT_DEVICE_BOARD; + default: + return BOOT_DEVICE_NONE; + } +} + +bool check_ram_available(long size) +{ + long sz = get_ram_size((long *)PHYS_SDRAM, size); + + if (sz == size) + return true; + + return false; +} + +void spl_dram_init(void) +{ + printf("Snowflake v2: DDR RAM INIT "); + + if (ddr_init(&dram_timing) || !check_ram_available(SZ_1G)) + panic("Init DDR RAM failed\n"); + + puts("1GB DDR RAM\n"); + writel(1, M4_BOOTROM_BASE_ADDR); +} + +int board_fit_config_name_match(const char *name) +{ + puts("Snowflake: FIT CONFIG check\n"); + if (is_imx8mm() && + !strcmp(name, "imx8mm-mt-snowflake-v2")) + return 0; + + puts("FIT CONFIG CHECK failed\n"); + return -1; +} + +int power_init_board(void) +{ + struct udevice *dev; + int ret = pmic_get("pmic@25", &dev); + + if (ret) { + puts("Snowflake: no PMIC\n"); + return ret; + } + + /* BUCKxOUT_DVS0/1 control BUCK123 output, clear PRESET_EN */ + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29); + /* BUCK1 SOC 850mV */ + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x14); + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x14); + /* BUCK2 ARM 950mV/850mV */ + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS0, 0x1C); + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS1, 0x14); + /* BUCK3 DRAM/GPU/VPU 950mV */ + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x1C); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS1, 0x1C); + /* set VDD_SNVS_0V8 from default 0.85V to 0.8V */ + pmic_reg_write(dev, PCA9450_LDO2CTRL, 0xC0); + return 0; +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + puts("Normal Boot\n"); + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) + printf("Failed to find clock node. Check device tree\n"); +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(2); + + timer_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + preloader_console_init(); + + enable_tzc380(); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + puts("Snowflake: lowlevel init DONE\n"); + board_init_r(NULL, 0); +} diff --git a/configs/snowflake_v2_emmcboot_defconfig b/configs/snowflake_v2_emmcboot_defconfig new file mode 100644 index 0000000000000..4ac54e55c351e --- /dev/null +++ b/configs/snowflake_v2_emmcboot_defconfig @@ -0,0 +1,134 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_IMX8M=y +CONFIG_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-mt-snowflake-v2" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_MT_SNOWFLAKE_V2=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x91fff0 +CONFIG_SPL=y +CONFIG_ARMV8_SPL_EXCEPTION_VECTORS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_SYS_BOOT_GET_CMDLINE=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x500000 +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="ext4load mmc 0:1 0x60480000 boot/leic-kernel.fit; setenv bootargs console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200 root=/dev/mmcblk0p1 rootwait rw; bootm 0x60480000" +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x910000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x2C0 +CONFIG_SPL_DMA=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=276 +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_HOSTNAME=y +CONFIG_HOSTNAME="snowflake-v2" +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x60480000 +CONFIG_FASTBOOT_BUF_SIZE=0x7300000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_SPL_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_SPL_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +# CONFIG_MMC_VERBOSE is not set +CONFIG_MMC_SDHCI=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PHY=y +CONFIG_NOP_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_USB_EHCI_HCD=y +# CONFIG_USB_EHCI_MX7 is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x50000000 +CONFIG_IMX_WATCHDOG=y +# CONFIG_SPL_SHA1 is not set +# CONFIG_SPL_SHA256 is not set diff --git a/include/configs/snowflake_v2.h b/include/configs/snowflake_v2.h new file mode 100644 index 0000000000000..a2aa016f13d91 --- /dev/null +++ b/include/configs/snowflake_v2.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler Toledo GmbH + * + * Configuration settings for the MT Snowflake v2 Terminal, based on Kontron + * "Kontron SL i.MX8M Mini" SoM. + */ +#ifndef __SNOWFLAKE_V2_IMX8M_MINI_H +#define __SNOWFLAKE_V2_IMX8M_MINI_H + +#ifdef CONFIG_SPL_BUILD +#include <config.h> +#endif + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include <asm/mach-imx/gpio.h> + +/* + * ####################################### + * ### RAM ### + * ####################################### + */ + +#define PHYS_SDRAM DDR_CSD1_BASE_ADDR +#define PHYS_SDRAM_SIZE (SZ_1G) +#define CFG_SYS_SDRAM_BASE PHYS_SDRAM + +#define CFG_SYS_INIT_RAM_ADDR 0x40000000 +#define CFG_SYS_INIT_RAM_SIZE 0x200000 + +/* + * ####################################### + * ### USB ### + * ####################################### + */ +#ifdef CONFIG_USB_EHCI_HCD +#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CFG_MXC_USB_FLAGS 0 +#endif + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) +#include <config_distro_bootcmd.h> +/* Do not try to probe USB net adapters for net boot */ +#undef BOOTENV_RUN_NET_USB_START +#define BOOTENV_RUN_NET_USB_START "" + +#ifdef CONFIG_SPL_BUILD +#define CFG_MALLOC_F_ADDR 0x930000 +#endif + +#endif /* __SNOWFLAKE_V2_IMX8M_MINI_H */
This patch probably got somehow lost. Rebased against latest master.
It is originally based on:
From patchwork Fri Mar 31 14:18:41 2023
X-Patchwork-Submitter: Sebastian Andrzej Siewior bigeasy@linutronix.de X-Patchwork-Id: 1763795 X-Patchwork-Delegate: sbabic@denx.de Return-Path: u-boot-bounces@lists.denx.de X-Original-To: incoming@patchwork.ozlabs.org Delivered-To: patchwork-incoming@legolas.ozlabs.org Authentication-Results: legolas.ozlabs.org; spf=pass (sender SPF authorized) smtp.mailfrom=lists.denx.de (client-ip=2a01:238:438b:c500:173d:9f52:ddab:ee01; helo=phobos.denx.de; envelope-from=u-boot-bounces@lists.denx.de; receiver=<UNKNOWN>) Authentication-Results: legolas.ozlabs.org;
The board is similar to "Kontron SL i.MX 8M Mini" SoM. There are two variants. Snowflake_v2 has an external SDCard Interface. LEIG is the same, but without display and without external SDCard Interface. Both variants support only 1GiB of main memory.
[ bigeasy: porting and a bit of cleanup ]
Signed-off-by: Manuel Traut manuel.traut@mt.com Signed-off-by: Sebastian Andrzej Siewior bigeasy@linutronix.de Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de
v4?v5: - Rebased on top of todays master v3?v4: - Added Frieder's tag - Rebased on top of v2023.07-rc5. v2?v3: Addressing Frieder's comments: - Add "kontron,imx8mm-sl" to the compatible string. - Remove pca9450 node and pinctrl_i2c1. The included imx8mm-kontron-sl.dtsi already provides this. - Merge the overwritten values in dram_timing.ddrc_cfg/fsp_msg directly into lpddr4_timing.c. - Simplify the init in spl_dram_init() and panic() if the init failed. - Replace a reference to SMARC with the current product name of the SoM.
v1?v2: - Clarify details about the board and whether or not there is an external SD-card interface.
--- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi | 139 ++ arch/arm/dts/imx8mm-mt-snowflake-v2.dts | 126 ++ arch/arm/mach-imx/imx8m/Kconfig | 8 + board/mt/snowflake_v2/Kconfig | 18 + board/mt/snowflake_v2/MAINTAINERS | 7 + board/mt/snowflake_v2/Makefile | 9 + board/mt/snowflake_v2/imximage.cfg | 8 + board/mt/snowflake_v2/lpddr4_timing.c | 1844 +++++++++++++++++++++++ board/mt/snowflake_v2/snowflake_v2.c | 32 + board/mt/snowflake_v2/spl.c | 146 ++ configs/snowflake_leig_defconfig | 141 ++ configs/snowflake_sdcard_defconfig | 140 ++ include/configs/snowflake_v2.h | 113 ++ 14 files changed, 2732 insertions(+) create mode 100644 arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-mt-snowflake-v2.dts create mode 100644 board/mt/snowflake_v2/Kconfig create mode 100644 board/mt/snowflake_v2/MAINTAINERS create mode 100644 board/mt/snowflake_v2/Makefile create mode 100644 board/mt/snowflake_v2/imximage.cfg create mode 100644 board/mt/snowflake_v2/lpddr4_timing.c create mode 100644 board/mt/snowflake_v2/snowflake_v2.c create mode 100644 board/mt/snowflake_v2/spl.c create mode 100644 configs/snowflake_leig_defconfig create mode 100644 configs/snowflake_sdcard_defconfig create mode 100644 include/configs/snowflake_v2.h
Index: u-boot-deb-manut/arch/arm/dts/Makefile =================================================================== --- u-boot-deb-manut.orig/arch/arm/dts/Makefile +++ u-boot-deb-manut/arch/arm/dts/Makefile @@ -1015,6 +1015,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-icore-mx8mm-edimm2.2.dtb \ imx8mm-kontron-bl.dtb \ imx8mm-kontron-bl-osm-s.dtb \ + imx8mm-mt-snowflake-v2.dtb \ imx8mm-mx8menlo.dtb \ imx8mm-phg.dtb \ imx8mm-venice.dtb \ Index: u-boot-deb-manut/arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi =================================================================== --- /dev/null +++ u-boot-deb-manut/arch/arm/dts/imx8mm-mt-snowflake-v2-u-boot.dtsi @@ -0,0 +1,139 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Mettler-Toledo GmbH + */ + +#include "imx8mm-u-boot.dtsi" + +/ { + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + u-boot,dm-spl; + wdt = <&wdog1>; + }; + + usbg1: usbg1 { + u-boot,dm-spl; + compatible = "fsl,imx27-usb-gadget"; + dr_mode = "peripheral"; + chipidea,usb = <&usbotg1>; + status = "okay"; + }; +}; + +&{/aliases} { + usbgadget0 = &usbg1; +}; + +&i2c1 { + status = "okay"; + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&i2c2 { + status = "okay"; + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_ecspi1 { + u-boot,dm-spl; +}; + +&pinctrl_i2c1 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_100mhz { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1_200mhz { + u-boot,dm-spl; +}; + +&pca9450 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@25/regulators} { + u-boot,dm-spl; +}; + +&ecspi1 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; + /* + * Delete the reference to the IO voltage regulator in order to prevent + * wrong information being passed to the MMC driver by reading the current + * voltage of the PCA9450 LDO5. + */ + /delete-property/ vqmmc-supply; + pinctrl-names = "default"; + no-1-8-v; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&pinctrl_wdog { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; Index: u-boot-deb-manut/arch/arm/dts/imx8mm-mt-snowflake-v2.dts =================================================================== --- /dev/null +++ u-boot-deb-manut/arch/arm/dts/imx8mm-mt-snowflake-v2.dts @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Mettler-Toledo GmbH + */ + +/dts-v1/; + +#include "imx8mm-kontron-sl.dtsi" +#include "imx8mm-u-boot.dtsi" + +/ { + model = "Mettler-Toledo i.MX 8M Mini Snowflake/LEIG"; + compatible = "mt,imx8mm-snowflake-v2", "mt,imx8mm-leig", "kontron,imx8mm-sl", "fsl,imx8mm"; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + disable-over-current; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + vmmc-supply = <®_vdd_3v3>; + vqmmc-supply = <®_nvcc_sd>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MM_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x19 /* \SOM_RTC_INT */ + MX8MM_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x19 /* \SOM_USBC_INT */ + MX8MM_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x184 /* SOM_DIS_ID0 */ + MX8MM_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x184 /* SOM_DIS_ID1 */ + MX8MM_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x184 /* SOM_DIS_ID2 */ + MX8MM_IOMUXC_SAI2_TXC_GPIO4_IO25 0x19 /* SOM_PCB_ID0 */ + MX8MM_IOMUXC_SAI2_TXD0_GPIO4_IO26 0x19 /* SOM_PCB_ID1 */ + MX8MM_IOMUXC_SAI2_MCLK_GPIO4_IO27 0x19 /* SOM_PCBA_ID0 */ + MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x19 /* SOM_PCBA_ID1 */ + MX8MM_IOMUXC_SAI5_RXFS_GPIO3_IO19 0x19 /* \SOM_STATLED_RES */ + MX8MM_IOMUXC_SAI5_RXC_GPIO3_IO20 0x19 /* \SOM_HUB_RES */ + MX8MM_IOMUXC_SAI5_RXD0_GPIO3_IO21 0x19 /* \SOM_SUPPLY_EN */ + MX8MM_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x1c4 /* \SOM_COM_RES / version C */ + MX8MM_IOMUXC_SAI5_RXD2_GPIO3_IO23 0x184 /* SOM_DBG_GPIO0 */ + MX8MM_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x184 /* SOM_DBG_GPIO1 */ + MX8MM_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x184 /* SOM_DBG_GPIO2 */ + MX8MM_IOMUXC_SAI3_TXD_GPIO5_IO1 0x184 /* SOM_DBG_GPIO3 version C */ + >; + }; + + pinctrl_sai1: sai1grp { + fsl,pins = < + MX8MM_IOMUXC_SAI1_TXFS_SAI1_TX_SYNC 0xd6 + MX8MM_IOMUXC_SAI1_TXC_SAI1_TX_BCLK 0xd6 + MX8MM_IOMUXC_SAI1_TXD0_SAI1_TX_DATA0 0xd6 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MM_IOMUXC_I2C4_SCL_I2C4_SCL 0x400001c3 + MX8MM_IOMUXC_I2C4_SDA_I2C4_SDA 0x400001c3 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x190 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d0 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d0 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d0 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d0 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d0 + MX8MM_IOMUXC_SD2_CD_B_GPIO2_IO12 0x019 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x194 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d4 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d4 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d4 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d4 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d4 + MX8MM_IOMUXC_SD2_CD_B_GPIO2_IO12 0x019 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { + fsl,pins = < + MX8MM_IOMUXC_SD2_CLK_USDHC2_CLK 0x196 + MX8MM_IOMUXC_SD2_CMD_USDHC2_CMD 0x1d6 + MX8MM_IOMUXC_SD2_DATA0_USDHC2_DATA0 0x1d6 + MX8MM_IOMUXC_SD2_DATA1_USDHC2_DATA1 0x1d6 + MX8MM_IOMUXC_SD2_DATA2_USDHC2_DATA2 0x1d6 + MX8MM_IOMUXC_SD2_DATA3_USDHC2_DATA3 0x1d6 + MX8MM_IOMUXC_SD2_CD_B_GPIO2_IO12 0x019 + MX8MM_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0x1d0 + >; + }; +}; Index: u-boot-deb-manut/arch/arm/mach-imx/imx8m/Kconfig =================================================================== --- u-boot-deb-manut.orig/arch/arm/mach-imx/imx8m/Kconfig +++ u-boot-deb-manut/arch/arm/mach-imx/imx8m/Kconfig @@ -170,6 +170,13 @@ config TARGET_IMX8MN_DDR4_EVK select FSL_CAAM select SPL_CRYPTO if SPL
+config TARGET_MT_SNOWFLAKE_V2 + bool "MT Snowflake v2" + select BINMAN + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_IMX8MN_VENICE bool "Support Gateworks Venice iMX8M Nano module" select BINMAN @@ -380,8 +387,9 @@ source "board/google/imx8mq_phanbell/Kco source "board/kontron/pitx_imx8m/Kconfig" source "board/kontron/sl-mx8mm/Kconfig" source "board/menlo/mx8menlo/Kconfig" -source "board/msc/sm2s_imx8mp/Kconfig" source "board/mntre/imx8mq_reform2/Kconfig" +source "board/msc/sm2s_imx8mp/Kconfig" +source "board/mt/snowflake_v2/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/purism/librem5/Kconfig" Index: u-boot-deb-manut/board/mt/snowflake_v2/Kconfig =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/Kconfig @@ -0,0 +1,18 @@ +if TARGET_MT_SNOWFLAKE_V2 + +config SYS_BOARD + string + default "snowflake_v2" + +config SYS_VENDOR + string + default "mt" + +config SYS_CONFIG_NAME + string + default "snowflake_v2" + +config IMX_CONFIG + default "board/mt/snowflake_v2/imximage.cfg" + +endif Index: u-boot-deb-manut/board/mt/snowflake_v2/MAINTAINERS =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/MAINTAINERS @@ -0,0 +1,7 @@ +Mettler-Toledo Snowflake boards +M: Manuel Traut manuel.traut@mt.com +S: Maintained +F: arch/arm/dts/imx8mm-mt-snowflake* +F: board/mt/snowflake_v2 +F: configs/snowflake_v2_emmc_defconfig +F: include/configs/snowflake_v2.h Index: u-boot-deb-manut/board/mt/snowflake_v2/Makefile =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (C) 2020 Mettler-Toledo GmbH + +obj-y := snowflake_v2.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o +endif Index: u-boot-deb-manut/board/mt/snowflake_v2/imximage.cfg =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/imximage.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + + +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x7E1000 Index: u-boot-deb-manut/board/mt/snowflake_v2/lpddr4_timing.c =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/lpddr4_timing.c @@ -0,0 +1,1844 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x223 }, + { 0x3d400024, 0x3a980 }, + { 0x3d400064, 0x5b0087 }, + { 0x3d4000d0, 0xc00305ba }, + { 0x3d4000d4, 0x940000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310000 }, + { 0x3d4000e8, 0x66004d }, + { 0x3d4000ec, 0x16004d }, + { 0x3d400100, 0x191e1920 }, + { 0x3d400104, 0x60630 }, + { 0x3d40010c, 0xb0b000 }, + { 0x3d400110, 0xe04080e }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xd8 }, + { 0x3d400144, 0x96004b }, + { 0x3d400180, 0x2ee0017 }, + { 0x3d400184, 0x2605b8e }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x21 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x21 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x2ee }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x21 }, + { 0x1200c7, 0x21 }, + { 0x2200c7, 0x21 }, + { 0x200ca, 0x24 }, + { 0x1200ca, 0x24 }, + { 0x2200ca, 0x24 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4d66 }, + { 0x5401c, 0x4d00 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4d66 }, + { 0x54022, 0x4d00 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x4d }, + { 0x54036, 0x4d }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x4d }, + { 0x5403c, 0x4d }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x5d }, + { 0x2000c, 0xbb }, + { 0x2000d, 0x753 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; Index: u-boot-deb-manut/board/mt/snowflake_v2/snowflake_v2.c =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/snowflake_v2.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler-Toledo GmbH + */ + +#include <asm/arch/imx-regs.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <fdt_support.h> +#include <linux/arm-smccc.h> +#include <linux/errno.h> +#include <net.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_phys_sdram_size(phys_size_t *size) +{ + /* always 1GB RAM */ + *size = 0x40000000; + return 0; +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return fdt_fixup_memory(blob, PHYS_SDRAM, gd->ram_size); +} + +int board_init(void) +{ + return 0; +} Index: u-boot-deb-manut/board/mt/snowflake_v2/spl.c =================================================================== --- /dev/null +++ u-boot-deb-manut/board/mt/snowflake_v2/spl.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler-Toledo GmbH + */ + +#include <common.h> +#include <spl.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/imx8mm_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/arch/ddr.h> +#include <asm/armv8/mmu.h> +#include <asm/gpio.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +#include <i2c.h> +#include <init.h> +#include <linux/delay.h> + +#include <power/pmic.h> +#include <power/pca9450.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + switch (boot_dev_spl) { + case SD1_BOOT: + case MMC1_BOOT: + return BOOT_DEVICE_MMC1; + case SD2_BOOT: + case MMC2_BOOT: + return BOOT_DEVICE_MMC2; + case USB_BOOT: + return BOOT_DEVICE_BOARD; + default: + return BOOT_DEVICE_NONE; + } +} + +bool check_ram_available(long size) +{ + long sz = get_ram_size((long *)PHYS_SDRAM, size); + + if (sz == size) + return true; + + return false; +} + +void spl_dram_init(void) +{ + if (ddr_init(&dram_timing) || !check_ram_available(SZ_1G)) + panic("Init DDR RAM failed\n"); + + puts("1GB DDR RAM\n"); + writel(1, M4_BOOTROM_BASE_ADDR); +} + +int board_fit_config_name_match(const char *name) +{ + if (is_imx8mm() && + !strcmp(name, "imx8mm-mt-snowflake-v2")) + return 0; + + puts("FIT CONFIG CHECK failed\n"); + return -1; +} + +int power_init_board(void) +{ + struct udevice *dev; + int ret = pmic_get("pmic@25", &dev); + + if (ret) { + puts("Snowflake/LEIG: no PMIC\n"); + return ret; + } + + /* BUCKxOUT_DVS0/1 control BUCK123 output, clear PRESET_EN */ + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29); + /* BUCK1 SOC 850mV */ + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x14); + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x14); + /* BUCK2 ARM 950mV/850mV */ + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS0, 0x1C); + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS1, 0x14); + /* BUCK3 DRAM/GPU/VPU 950mV */ + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS0, 0x1C); + pmic_reg_write(dev, PCA9450_BUCK3OUT_DVS1, 0x1C); + /* set VDD_SNVS_0V8 from default 0.85V to 0.8V */ + pmic_reg_write(dev, PCA9450_LDO2CTRL, 0xC0); + return 0; +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + puts("Normal Boot\n"); + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) + printf("Failed to find clock node. Check device tree\n"); +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(2); + + timer_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + preloader_console_init(); + + enable_tzc380(); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} Index: u-boot-deb-manut/configs/snowflake_leig_defconfig =================================================================== --- /dev/null +++ u-boot-deb-manut/configs/snowflake_leig_defconfig @@ -0,0 +1,141 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_IMX8M=y +CONFIG_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFDE00 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-mt-snowflake-v2" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_MT_SNOWFLAKE_V2=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0xFFFFBE00 +CONFIG_ARMV8_SPL_EXCEPTION_VECTORS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_BOOT_GET_CMDLINE=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x500000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="fastboot usb 0" +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x910000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x920000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x2C0 +CONFIG_SPL_DMA=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_USB_HOST=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_CI_UDC=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=276 +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CMD_IMPORTENV=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_ENV_FLAGS=y +CONFIG_CMD_NVEDIT_INFO=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x60480000 +CONFIG_FASTBOOT_BUF_SIZE=0x7300000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +# CONFIG_MMC_VERBOSE is not set +CONFIG_MMC_SDHCI=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PHY=y +CONFIG_NOP_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_EHCI_HCD=y +# CONFIG_USB_EHCI_MX7 is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x50000000 +CONFIG_IMX_WATCHDOG=y +# CONFIG_SPL_SHA1 is not set +# CONFIG_SPL_SHA256 is not set Index: u-boot-deb-manut/configs/snowflake_sdcard_defconfig =================================================================== --- /dev/null +++ u-boot-deb-manut/configs/snowflake_sdcard_defconfig @@ -0,0 +1,140 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_IMX8M=y +CONFIG_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x3F0000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-mt-snowflake-v2" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_MT_SNOWFLAKE_V2=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_ARMV8_SPL_EXCEPTION_VECTORS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_BOOT_GET_CMDLINE=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x500000 +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="fastboot usb 0" +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x910000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x920000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_DMA=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_USB_HOST=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_CI_UDC=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=276 +# CONFIG_CMD_EXPORTENV is not set +CONFIG_CMD_IMPORTENV=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_ENV_FLAGS=y +CONFIG_CMD_NVEDIT_INFO=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_PART=0 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x60480000 +CONFIG_FASTBOOT_BUF_SIZE=0x7300000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +# CONFIG_MMC_VERBOSE is not set +CONFIG_MMC_SDHCI=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PHY=y +CONFIG_NOP_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_EHCI_HCD=y +# CONFIG_USB_EHCI_MX7 is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x50000000 +CONFIG_IMX_WATCHDOG=y +# CONFIG_SPL_SHA1 is not set +# CONFIG_SPL_SHA256 is not set Index: u-boot-deb-manut/include/configs/snowflake_v2.h =================================================================== --- /dev/null +++ u-boot-deb-manut/include/configs/snowflake_v2.h @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Kontron Electronics GmbH + * Copyright (C) 2020 Mettler-Toledo GmbH + * + * Configuration settings for the MT Snowflake v2 Terminal, based on Kontron + * "Kontron SL i.MX 8M Mini" SoM. + */ +#ifndef __SNOWFLAKE_V2_IMX8M_MINI_H +#define __SNOWFLAKE_V2_IMX8M_MINI_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_MALLOC_F_ADDR 0x930000 +#endif + +/* + * ####################################### + * ### RAM ### + * ####################################### + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE SZ_2M + +#if defined(CONFIG_ENV_IS_IN_MMC) +/* Environment in eMMC, before config block at the end of 1st "boot sector" */ +#endif + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/* SDRAM configuration */ +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */ + +#ifndef CONFIG_SPL_BUILD + +#define MEM_LAYOUT_ENV_SETTINGS \ + "fdt_addr_r=0x50200000\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "kernel_comp_addr_r=0x40200000\0" \ + "kernel_comp_size=0x08000000\0" \ + "ramdisk_addr_r=0x50300000\0" \ + "scriptaddr=0x50280000\0" + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 0) + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + MEM_LAYOUT_ENV_SETTINGS \ + "boot_script_dhcp=boot.scr\0" \ + "console=ttymxc2\0" \ + "fdt_addr=0x43000000\0" \ + "initrd_addr=0x43800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "setup=setenv setupargs console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200\0" + +#include <config_distro_bootcmd.h> + +#endif + +#define CONFIG_ENV_FLAGS_LIST_STATIC \ + "BOOT_A_LEFT:da," \ + "BOOT_B_LEFT:da," \ + "BOOT_ORDER:sa," \ + "board:sa," \ + "board_name:sa," \ + "bootcmd:sa," \ + "bootdelay:sa," \ + "boot_syslinux_conf:sa," \ + "rauc_slot:sa," \ + "setup:sa," \ + "soc:sa," \ + "vendor:sa," \ + "baudrate:so," \ + "boot_a_script:so," \ + "boot_extlinux:so," \ + "boot_prefixes:so," \ + "boot_scripts:so," \ + "boot_targets:so," \ + "bootcmd_mmc0:so, "\ + "bootcmd_mmc1:so, "\ + "console=ttymxc2:so," \ + "distro_bootcmd:so," \ + "efi_dtb_prefixes:so," \ + "fdt_addr_h:so," \ + "initrd_addr:xo," \ + "initrd_high:xo," \ + "kernel_addr_r:xo," \ + "kernel_comp_addr_r r:xo," \ + "load_efi_dtb s:xo," \ + "mmc_boot:so," \ + "ramdisk_addr_r:so," \ + "scan_dev_for_boot:so," \ + "scan_dev_for_boot_part:so," \ + "scan_dev_for_efi:so," \ + "scan_dev_for_extlinux:so," \ + "scan_dev_for_scripts:so," \ + "scriptaddr:so," + +/* Do not try to probe USB net adapters for net boot */ +#undef BOOTENV_RUN_NET_USB_START +#define BOOTENV_RUN_NET_USB_START "" + +#ifdef CONFIG_SPL_BUILD +#define CFG_MALLOC_F_ADDR 0x930000 +#endif + +#endif /* __SNOWFLAKE_V2_IMX8M_MINI_H */
On Fri, Sep 29, 2023 at 9:13 AM Manuel Traut manuel.traut@mt.com wrote:
This patch probably got somehow lost. Rebased against latest master.
It is originally based on:
From patchwork Fri Mar 31 14:18:41 2023 X-Patchwork-Submitter: Sebastian Andrzej Siewior bigeasy@linutronix.de X-Patchwork-Id: 1763795 X-Patchwork-Delegate: sbabic@denx.de Return-Path: u-boot-bounces@lists.denx.de X-Original-To: incoming@patchwork.ozlabs.org Delivered-To: patchwork-incoming@legolas.ozlabs.org Authentication-Results: legolas.ozlabs.org; spf=pass (sender SPF authorized) smtp.mailfrom=lists.denx.de (client-ip=2a01:238:438b:c500:173d:9f52:ddab:ee01; helo=phobos.denx.de; envelope-from=u-boot-bounces@lists.denx.de; receiver=<UNKNOWN>) Authentication-Results: legolas.ozlabs.org;
The board is similar to "Kontron SL i.MX 8M Mini" SoM. There are two variants. Snowflake_v2 has an external SDCard Interface. LEIG is the same, but without display and without external SDCard Interface. Both variants support only 1GiB of main memory.
[ bigeasy: porting and a bit of cleanup ]
Signed-off-by: Manuel Traut manuel.traut@mt.com Signed-off-by: Sebastian Andrzej Siewior bigeasy@linutronix.de Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de
v4?v5:
- Rebased on top of todays master
v3?v4:
- Added Frieder's tag
- Rebased on top of v2023.07-rc5.
v2?v3: Addressing Frieder's comments:
- Add "kontron,imx8mm-sl" to the compatible string.
- Remove pca9450 node and pinctrl_i2c1. The included imx8mm-kontron-sl.dtsi already provides this.
- Merge the overwritten values in dram_timing.ddrc_cfg/fsp_msg directly into lpddr4_timing.c.
- Simplify the init in spl_dram_init() and panic() if the init failed.
- Replace a reference to SMARC with the current product name of the SoM.
v1?v2:
- Clarify details about the board and whether or not there is an external SD-card interface.
The changelog should go below the --- line.
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Manuel Traut
