[PATCH RESEND 1/2] dt-bindings: phy-mtk-tphy: add properties for phy tuning
Add properties to improve eye diagram which sometimes need adjust some parameters of u2phy; Add a property to tune disconnect threshold;
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- doc/device-tree-bindings/phy/phy-mtk-tphy.txt | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/doc/device-tree-bindings/phy/phy-mtk-tphy.txt b/doc/device-tree-bindings/phy/phy-mtk-tphy.txt index 3042c39d09..300e236b5b 100644 --- a/doc/device-tree-bindings/phy/phy-mtk-tphy.txt +++ b/doc/device-tree-bindings/phy/phy-mtk-tphy.txt @@ -52,6 +52,15 @@ Optional properties (port (child) node): "da_ref": the reference clock of analog phy, used if the clocks of analog and digital phys are separated, otherwise uses "ref" clock only if needed. +- mediatek,eye-vrt : The selection of VRT reference voltage (U2 phy), + the value is [1, 7] +- mediatek,eye-term : The selection of HS_TX TERM reference voltage (U2 phy), + the value is [1, 7] +- mediatek,discth : The selection of disconnect threshold (U2 phy), + the value is [1, 15] +- mediatek,pre-emphasis : The level of pre-emphasis which used to widen + the eye opening and boost eye swing, + the value is [1, 3]
Example:
Signed-off-by: Chunfeng Yun chunfeng.yun@mediatek.com --- drivers/phy/phy-mtk-tphy.c | 58 +++++++++++++++++++++++++++++++++++++- 1 file changed, 57 insertions(+), 1 deletion(-)
diff --git a/drivers/phy/phy-mtk-tphy.c b/drivers/phy/phy-mtk-tphy.c index 1883f9f83e..ea9edf212c 100644 --- a/drivers/phy/phy-mtk-tphy.c +++ b/drivers/phy/phy-mtk-tphy.c @@ -47,6 +47,11 @@ #define PA0_USB20_PLL_PREDIV GENMASK(7, 6) #define PA0_RG_USB20_INTR_EN BIT(5)
+#define U3P_USBPHYACR1 0x004 +#define PA1_RG_INTR_CAL GENMASK(23, 19) +#define PA1_RG_VRT_SEL GENMASK(14, 12) +#define PA1_RG_TERM_SEL GENMASK(10, 8) + #define U3P_USBPHYACR2 0x008 #define PA2_RG_U2PLL_BW GENMASK(21, 19)
@@ -56,8 +61,10 @@ #define PA5_RG_U2_HS_100U_U3_EN BIT(11)
#define U3P_USBPHYACR6 0x018 +#define PA6_RG_U2_PRE_EMP GENMASK(31, 30) #define PA6_RG_U2_BC11_SW_EN BIT(23) #define PA6_RG_U2_OTG_VBUSCMP_EN BIT(20) +#define PA6_RG_U2_DISCTH GENMASK(7, 4) #define PA6_RG_U2_SQTH GENMASK(3, 0)
#define U3P_U2PHYACR4 0x020 @@ -240,7 +247,7 @@ struct u3phy_banks {
struct mtk_phy_instance { void __iomem *port_base; - const struct device_node *np; + struct device_node *np; union { struct u2phy_banks u2_banks; struct u3phy_banks u3_banks; @@ -250,6 +257,11 @@ struct mtk_phy_instance { struct clk da_ref_clk; /* reference clock of analog phy */ u32 index; u32 type; + + u32 eye_vrt; + u32 eye_term; + u32 discth; + u32 pre_emphasis; };
struct mtk_tphy { @@ -564,6 +576,47 @@ static void phy_v2_banks_init(struct mtk_tphy *tphy, } }
+static void phy_parse_property(struct mtk_tphy *tphy, + struct mtk_phy_instance *instance) +{ + ofnode node = np_to_ofnode(instance->np); + + if (instance->type != PHY_TYPE_USB2) + return; + + ofnode_read_u32(node, "mediatek,eye-vrt", &instance->eye_vrt); + ofnode_read_u32(node, "mediatek,eye-term", &instance->eye_term); + ofnode_read_u32(node, "mediatek,discth", &instance->discth); + ofnode_read_u32(node, "mediatek,pre-emphasis", &instance->pre_emphasis); + + dev_dbg(tphy->dev, "vrt:%d, term:%d, disc:%d, emp:%d\n", + instance->eye_vrt, instance->eye_term, + instance->discth, instance->pre_emphasis); +} + +static void u2_phy_props_set(struct mtk_tphy *tphy, + struct mtk_phy_instance *instance) +{ + struct u2phy_banks *u2_banks = &instance->u2_banks; + void __iomem *com = u2_banks->com; + + if (instance->eye_vrt) + clrsetbits_le32(com + U3P_USBPHYACR1, PA1_RG_VRT_SEL, + FIELD_PREP(PA1_RG_VRT_SEL, instance->eye_vrt)); + + if (instance->eye_term) + clrsetbits_le32(com + U3P_USBPHYACR1, PA1_RG_TERM_SEL, + FIELD_PREP(PA1_RG_TERM_SEL, instance->eye_term)); + + if (instance->discth) + clrsetbits_le32(com + U3P_USBPHYACR6, PA6_RG_U2_DISCTH, + FIELD_PREP(PA6_RG_U2_DISCTH, instance->discth)); + + if (instance->pre_emphasis) + clrsetbits_le32(com + U3P_USBPHYACR6, PA6_RG_U2_PRE_EMP, + FIELD_PREP(PA6_RG_U2_PRE_EMP, instance->pre_emphasis)); +} + static int mtk_phy_init(struct phy *phy) { struct mtk_tphy *tphy = dev_get_priv(phy->dev); @@ -586,6 +639,7 @@ static int mtk_phy_init(struct phy *phy) switch (instance->type) { case PHY_TYPE_USB2: u2_phy_instance_init(tphy, instance); + u2_phy_props_set(tphy, instance); break; case PHY_TYPE_USB3: u3_phy_instance_init(tphy, instance); @@ -692,6 +746,8 @@ static int mtk_phy_xlate(struct phy *phy, return -EINVAL; }
+ phy_parse_property(tphy, instance); + return 0; }
Chunfeng Yun
