[PATCH] scripts/get_maintainer.pl: obey ignore list
If the user creates a .get_maintainer.ignore file, make sure it is consulted and obeyed for *all* emails discovered by the script.
Signed-off-by: Trevor Woerner twoerner@gmail.com --- scripts/get_maintainer.pl | 1 + 1 file changed, 1 insertion(+)
diff --git a/scripts/get_maintainer.pl b/scripts/get_maintainer.pl index e3b41616c9..8c0fb8656e 100755 --- a/scripts/get_maintainer.pl +++ b/scripts/get_maintainer.pl @@ -2435,6 +2435,7 @@ sub merge_email {
for (@_) { my ($address, $role) = @$_; + next if (ignore_email_address($address)); if (!$saw{$address}) { if ($output_roles) { push(@lines, "$address ($role)");
for (@_) {
- next if (ignore_email_address($address)); if (!$saw{$address}) { if ($output_roles) { push(@lines, "$address ($role)");
This got me to check and see that yes, our copy of get_maintainers.pl is out of date from Linux. And in fact, a re-sync will let us add a .get_maintainer.conf file and use upstream a lot more closely as it now has logic to find all MAINTAINERS files in a tree.
But this change isn't upstream. Please work with Joe Perches upstream to get this change accepted and it'll flow down to us and not get overwritten when I forget it was an intentional change :) Thanks!
Hi Tom,
for (@_) {
Thanks for the tip!
I ran my patches through the kernel's latest get_maintainer.pl script and it correctly removes email entries that are listed in my ~/.get_maintainer.ignore file without any changes required. Therefore a re-sync would appear to fix the issue I found.
I can take a look at the re-sync if you wish? It's unclear to me whether you're looking into the re-sync or not.
Best regards, Trevor
On Fri, Jun 11, 2021 at 10:56:55AM -0400, Trevor Woerner wrote:
Hi Tom,
for (@_) {
Thanks for the tip!
Please do. I took a quick attempt at it, but I couldn't convince it to use all of our MAINTAINERS files, by default, for some reason. Thanks!
Trevor Woerner
