Re: [U-Boot] MIPS cpu has problem detecting CFI
On Sat, Oct 10, 2009 at 12:27 PM, myuboot@fastmail.fm wrote:
On Fri, 09 Oct 2009 12:16 -0500, "Andrew Dyer" amdyer@gmail.com wrote:
On Fri, Oct 9, 2009 at 11:21 AM, myuboot@fastmail.fm wrote:
I think I found a problem in cpu/mips/start.S.
gp register is used to point to the SDRAM. But after gp is adjusted to proper location, a C function flush_cache is called. But this function actually changes gp register before gp is used to jump to SDRAM. That makes the u-boot run from flash and fails to detect CFI.
Here is the assembler code for flush_cache.c (gdb) disassem 0xb0000798 Dump of assembler code for function flush_cache: 0xb000078c <flush_cache+0>: lui gp,0x3 0xb0000790 <flush_cache+4>: addiu gp,gp,-32300 0xb0000794 <flush_cache+8>: addu gp,gp,t9
And here is how I fixed the issue -
diff --git a/u-boot-2009.08/cpu/mips/start.S b/u-boot-2009.08/cpu/mips/start.S index 57db589..0e8f8ed 100644 --- a/u-boot-2009.08/cpu/mips/start.S +++ b/u-boot-2009.08/cpu/mips/start.S @@ -321,6 +321,7 @@ relocate_code: move t6, gp sub gp, CONFIG_SYS_MONITOR_BASE add gp, a2 /* gp now adjusted */
- move t8, gp
sub s1, gp, t6 /* s1 <-- relocation offset */
/* @@ -358,6 +359,7 @@ relocate_code:
/* Jump to where we've relocated ourselves. */
- move gp, t8
addi t0, s2, in_ram - _start jr t0 nop
Something seems weird here - IIRC, $gp is supposed to be saved in the stack frame during the function prologue and restored from the frame on exit. Also I think relying on $t8 is risky, as I don't believe it is guaranteed by the ABI to be preserved across function calls.
What compiler are you using? Can you post the whole flush_cache() disassembly?
You may be right. The c function should get the input arguments through stack. I just use the same toolchain(with -S option) to generate the assembler code and the assembler code does not show the modification on the gp register. I am attaching the whole assembler code file here too. But the assembler code I sent in my previous mail did show the gp pointer is changed. In that email, I got that assembler using gdb through a BDI debugger. I don't have BDI with me today so I cann't give you the whole assembler code using BDI.
Could it be the gcc toolchain generates the wrong code when it is creating object file, but generates correct assembler code? Or the BDI is changing the assembler code at run time such that I see the wrong assembler code? But if that is the case, I don't know how to explain with my workaround/fix the board did come up even without bdi and it seems to work every time. I am so confused now. Any suggestion on anything I can try?
1) please don't top post, put replies on the bottom, I fixed this in this post.
2) reply to the list, there are a lot of smart people (better versed in toolchains than I) who read it. I've cc'd the list on this one.
3) the assembler looks fine, but it doesn't have the function prologue that the gdb dump shows. I doubt the bdi is modifying the asm. I /think/ the linker might be the part that inserts that or maybe the compile after it generates the asm. Try looking at the output of '${CROSS_COMPILE}objdump --source cpu.o' and then '${CROSS_COMPILE}objdump --source u-boot'.
4) where did the toolchain come from, what version, etc.? Maybe run gcc with the -v option to see the subprograms and options it sets.
5) try downloading the mips ELDK and build u-boot with that.
- move t8, gp
- move gp, t8
- please don't top post, put replies on the bottom, I fixed this in this
post.
- reply to the list, there are a lot of smart people (better versed
- the assembler looks fine, but it doesn't have the function prologue
- where did the toolchain come from, what version, etc.? Maybe run
- try downloading the mips ELDK and build u-boot with that.
Thanks for 1) and 2). For 3), both results show GP register is modified. the result of ${CROSS_COMPILE}objdump --source cpu.o is:
void flush_cache(ulong start_addr, ulong size) { 7c: 3c1c0000 lui gp,0x0 80: 279c0000 addiu gp,gp,0 84: 0399e021 addu gp,gp,t9 unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; unsigned long addr = start_addr & ~(lsize - 1); 88: 2403fff0 li v1,-16 8c: 00831024 and v0,a0,v1 unsigned long aend = (start_addr + size - 1) & ~(lsize - 1); 90: 2484ffff addiu a0,a0,-1 94: 00852021 addu a0,a0,a1 98: 00831824 and v1,a0,v1
while (1) { cache_op(Hit_Writeback_Inv_D, addr); 9c: bc550000 cache 0x15,0(v0) cache_op(Hit_Invalidate_I, addr); a0: bc500000 cache 0x10,0(v0) if (addr == aend) a4: 1443fffd bne v0,v1,9c <flush_cache+0x20> a8: 24420010 addiu v0,v0,16 break; addr += lsize; } #if defined(CONFIG_TNETVxxxx) invalidate_dcache(); ac: 8f990000 lw t9,0(gp) b0: 03200008 jr t9 b4: 00000000 nop
000000b8 <do_reset>: void __attribute__((weak)) _machine_restart(void) { }
For 4), I generated the toolchain by myself using buildroot 2009.08. Using built-in specs. And the result of gcc -v is: Target: mips-linux-uclibc Configured with: /home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/gcc-4.4.1/configure --prefix=/usr --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=mips-linux-uclibc --enable-languages=c --with-sysroot=/home/root123/sources/buildroot-2009.08-k/build_mips/staging_dir --with-build-time-tools=/home/root123/sources/buildroot-2009.08-k/build_mips/staging_dir/usr/mips-linux-uclibc/bin --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-libssp --disable-tls --enable-shared --with-gmp=/home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/gmp --with-mpfr=/home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/mpfr --disable-nls --enable-threads --disable-multilib --disable-decimal-float --with-float=soft --with-abi=32 --with-tune=mips32 : (reconfigured) /home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/gcc-4.4.1/configure --prefix=/usr --build=i386-pc-linux-gnu --host=i386-pc-linux-gnu --target=mips-linux-uclibc --enable-languages=c --with-sysroot=/home/root123/sources/buildroot-2009.08-k/build_mips/staging_dir --with-build-time-tools=/home/root123/sources/buildroot-2009.08-k/build_mips/staging_dir/usr/mips-linux-uclibc/bin --disable-__cxa_atexit --enable-target-optspace --with-gnu-ld --disable-libssp --disable-tls --enable-shared --with-gmp=/home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/gmp --with-mpfr=/home/root123/sources/buildroot-2009.08-k/toolchain_build_mips/mpfr --disable-nls --enable-threads --disable-multilib --disable-decimal-float --with-float=soft --with-abi=32 --with-tune=mips32 Thread model: posix gcc version 4.4.1 (GCC)
For most of the flags above, they are automatically added by buildroot. Please let me know if there is anything wrong with the setting.
4) I am not familiar with ELDK. It seems to be able to create toolchain quickly. I will give it a try. How is the toolchain created by ELDK different from buildroot or openembedded?
Thanks.
It looks like the code expects t9 to have the gp value. I need to get my setup up to -current and do a build test with eldk to help much more (we don't do much mips anymore here, so my setup is a bit behind the times).
nothing stands out, but I'm not a gcc expert.
- I am not familiar with ELDK. It seems to be able to create toolchain
It comes with a prebuilt toolchain. I believe the compiler version is a bit older than what you are running (looks like 4.2.2 from the web page).
whoops - the above is wrong - t9 is supposed to have the starting address of the function in it. The 0 constants in the preceding two instructions are supposed to be setup by the linker to give an offset to the correct value of $gp for this function.
http://books.google.com/books?id=kk8G2gK4Tw8C&pg=PA413&lpg=PA413&...
was where I found this.
Andrew Dyer
myuboot@fastmail.fm
