[U-Boot] [PATCH] common/board_f.c: remove CONFIG_SYS_GENERIC_GLOBAL_DATA
CONFIG_SYS_GENERIC_GLOBAL_DATA is no longer used by any board or platform, so support for it can be dropped.
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com --- README | 6 ------ common/board_f.c | 27 --------------------------- scripts/config_whitelist.txt | 1 - 3 files changed, 34 deletions(-)
diff --git a/README b/README index 3fdb89c..15ac00d 100644 --- a/README +++ b/README @@ -404,12 +404,6 @@ The following options need to be configured: supported, core will start to execute uboot when wakes up.
- Generic CPU options: - CONFIG_SYS_GENERIC_GLOBAL_DATA - Defines global data is initialized in generic board board_init_f(). - If this macro is defined, global data is created and cleared in - generic board board_init_f(). Without this macro, architecture/board - should initialize global data before calling board_init_f(). - CONFIG_SYS_BIG_ENDIAN, CONFIG_SYS_LITTLE_ENDIAN
Defines the endianess of the CPU. Implementation of those diff --git a/common/board_f.c b/common/board_f.c index 5915e50..37bbf5a 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -211,14 +211,6 @@ static int init_func_spi(void) } #endif
-__maybe_unused -static int zero_global_data(void) -{ - memset((void *)gd, '\0', sizeof(gd_t)); - - return 0; -} - static int setup_mon_len(void) { #if defined(__ARM__) || defined(__MICROBLAZE__) @@ -910,25 +902,6 @@ static const init_fnc_t init_sequence_f[] = {
void board_init_f(ulong boot_flags) { -#ifdef CONFIG_SYS_GENERIC_GLOBAL_DATA - /* - * For some architectures, global data is initialized and used before - * calling this function. The data should be preserved. For others, - * CONFIG_SYS_GENERIC_GLOBAL_DATA should be defined and use the stack - * here to host global data until relocation. - */ - gd_t data; - - gd = &data; - - /* - * Clear global data before it is accessed at debug print - * in initcall_run_list. Otherwise the debug print probably - * get the wrong value of gd->have_console. - */ - zero_global_data(); -#endif - gd->flags = boot_flags; gd->have_console = 0;
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index db28457..2df02d0 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3341,7 +3341,6 @@ CONFIG_SYS_GBIT_MII_BUSNAME CONFIG_SYS_GBL_DATA_OFFSET CONFIG_SYS_GBL_DATA_SIZE CONFIG_SYS_GENERIC_BOARD -CONFIG_SYS_GENERIC_GLOBAL_DATA CONFIG_SYS_GIC400_ADDR CONFIG_SYS_GP1DIR CONFIG_SYS_GP1ODR
Reviewed-by: Vladimir Zapolskiy vz@mleia.com
Apparently my IODATA Landisk board was the last user of the option, and I removed the dependency today.
Thank you for the change.
-- With best wishes, Vladimir
On 15 August 2017 at 15:11, Thomas Petazzoni thomas.petazzoni@free-electrons.com wrote:
Great news!
Signed-off-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com Reviewed-by: Vladimir Zapolskiy vz@mleia.com Reviewed-by: Simon Glass sjg@chromium.org
Thomas Petazzoni
Vladimir Zapolskiy
