[U-Boot] [PATCH v3] AVR32: fix timer_init() function
timer_init() now returns an int (the error code) instead of void. This makes compilation fail with:
interrupts.c:111: error: conflicting types for 'timer_init' /home/svens/u-boot/u-boot/include/common.h:246: error: previous declaration of 'timer_init' was here make[1]: *** [interrupts.o] Error 1
Signed-off-by: Sven Schnelle svens@stackframe.org --- Changes for v3: - return -EINVAL regardless of the return value Changes for v2: - Coding style
arch/avr32/cpu/interrupts.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/avr32/cpu/interrupts.c b/arch/avr32/cpu/interrupts.c index 6681e13..49a00f1 100644 --- a/arch/avr32/cpu/interrupts.c +++ b/arch/avr32/cpu/interrupts.c @@ -107,7 +107,7 @@ static int set_interrupt_handler(unsigned int nr, void (*handler)(void), return 0; }
-void timer_init(void) +int timer_init(void) { extern void timer_interrupt_handler(void); u64 tmp; @@ -120,8 +120,9 @@ void timer_init(void) tb_factor = (u32)tmp;
if (set_interrupt_handler(0, &timer_interrupt_handler, 3)) - return; + return -EINVAL;
/* For all practical purposes, this gives us an overflow interrupt */ sysreg_write(COMPARE, 0xffffffff); + return 0; } -- 1.7.5.4
Dear Sven,
Am 04.10.2015 21:53, schrieb Sven Schnelle:
Acked-by: Andreas Bießmann andreas.devel@googlemail.com
Hi Wolfgang,
Le 05/10/2011 09:12, Andreas Bießmann a écrit :
Dear Sven,
Apparently, something went quite wrong with the date for this patch. See http://patchwork.ozlabs.org/patch/117688/, which places it in 2015 (like Andreas' answer does), ignoring Sven's patch mails dates.
Wolfgang, maybe this should be mentioned to the patchwork folks.
Amicalement,
Dear Albert,
Am 08.11.2011 10:38, schrieb Albert ARIBAUD:
Hi Wolfgang,
Dear Sven,
Sven's MUA has set the 'Date:' field to 'Date: Sun, 4 Oct 2015 21:53:32 +0200' in Mail header.
BTW this will also be the date of the patch in git and could lead to problems when merge/rebase in future. Sven, could you please provide another version of the patch _or_ Reinhard could you please adopt the mail header (Date:) before applying this patch?
I don't think patchwork was wrong here. My MUA acts the same way.
best regards
Andreas Bießmann
Changes for v3:
Changes for v2:
- Coding style
Applied to u-boot-staging/agust@denx.de after fixing the date to patch reception date from email header. Thanks.
Anatolij
Dear Sven Schnelle,
Changes for v3:
Changes for v2:
- Coding style
Applied, thanks. [Cherry-picked Anatolij's commit.]
Dear Sven,
would you be willing to disclose the secrets of running such a time machine ?
We're just discussing to drop support for AVR32 systems due to lack of a custodian, and appearent lack of interest, see 02/25 To:u-boot@lists.d [PATCH] AVR32 removal due to lack of custodian. http://article.gmane.org/gmane.comp.boot-loaders.u-boot/125752
Are you still interestedin AVR32? Would you be willing to volunteer to take over custodianship for this processor family?
Or Andreas, would you?
Hi Wolfgang,
On 02/26/2012 11:40 PM, Wolfgang Denk wrote:
Dear Sven,
Hehe. The 'time machine' was basically a dead CMOS battery in my Thinkpad at that time ;)
I fear i don't have enough time for maintaining a port, and i only have one AVR32 Board (the ATGNW100). I think Andreas would be a much better maintainer, IMHO he has much more knowledge on the AVR32 area.
Regards, Sven
participants (5)
Albert ARIBAUD
Anatolij Gustschin
Andreas Bießmann
Sven Schnelle
