[PATCH] doc: android: Fix a typo
%s/than/then
Signed-off-by: Bin Meng bmeng@tinylab.org ---
doc/android/boot-image.rst | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/android/boot-image.rst b/doc/android/boot-image.rst index c719b4d711..8f247c7093 100644 --- a/doc/android/boot-image.rst +++ b/doc/android/boot-image.rst @@ -11,7 +11,7 @@ Android Boot Image is used to boot Android OS. It usually contains kernel image (like ``zImage`` file) and ramdisk. Sometimes it can contain additional binaries. This image is built as a part of AOSP (called ``boot.img``), and being flashed into ``boot`` partition on eMMC. Bootloader then reads that image from -``boot`` partition to RAM and boots the kernel from it. Kernel than starts +``boot`` partition to RAM and boots the kernel from it. Kernel then starts ``init`` process from the ramdisk. It should be mentioned that recovery image (``recovery.img``) also has Android Boot Image format.
On jeu., mai 25, 2023 at 14:30, Bin Meng bmeng@tinylab.org wrote:
%s/than/then
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
-- 2.25.1
Bin Meng
Mattijs Korpershoek
