[U-Boot] [PATCH] tegra20: tamonten: Fix the early gpio init
To set gpio during the early init we now need to use tegra_spl_gpio_direction_output(), copied from seaboard.
Change-Id: Id0aadb17a71b78e75e8c3f8de374102b3eab767b Signed-off-by: Alban Bedel alban.bedel@avionic-design.de --- board/avionic-design/common/tamonten.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index 9c86779..ea2425a 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -23,8 +23,10 @@ #ifdef CONFIG_BOARD_EARLY_INIT_F void gpio_early_init(void) { +#ifndef CONFIG_SPL_BUILD gpio_request(GPIO_PI4, NULL); - gpio_direction_output(GPIO_PI4, 1); +#endif + tegra_spl_gpio_direction_output(GPIO_PI4, 1); } #endif
That shouldn't be present on upstream patches.
- tegra_spl_gpio_direction_output(GPIO_PI4, 1); }
Surely you only want to call tegra_spl_*() from SPL, and not from non-SPL code? In other words, don't you need something more like:
#ifdef CONFIG_SPL_BUILD tegra_spl_gpio_direction_output(GPIO_PI4, 1); #else gpio_request(GPIO_PI4, NULL); gpio_direction_output(GPIO_PI4, 1); #endif
... although perhaps the SPL and non-SPL code should simply be separated into separate files, so that there's no need for ifdefs, and it's obvious if SPL and non-SPL code are duplicating the same work?
On Thu, 02 Oct 2014 09:42:18 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
Sorry about this.
Sadly not, at this point the gpio driver isn't available yet, that's why one need to use tegra_spl_gpio_direction_output(). As mentioned in the commit log I copied this from seaboard, assuming it would be correct.
AFAICT the gpio_request() could be removed too, it doesn't work at this point anyway.
Actually none of the code from tamonten.c is needed for the SPL, a build with both function under #ifndef CONFIG_SPL_BUILD works just fine. Any pointer on how I can get tamonten.c out of the SPL build?
Alban
Sorry about this.
Hmm. CC Simon to comment on which GPIO drivers are available in SPL/non-SPL, and why the above ifdef doesn't work.
Indeed, if manipulating the GPIO in SPL isn't even necessary, then just wrapping the whole code in #ifndef CONFIG_SPL_BUILD makes sense to me.
I'm not sure now that the Makefile structure has changed to Kbuild. It might be as simple as:
obj-$(CONFIG_SPL_BUILD) += foo.o
(but using whatever the opposite of CONFIG_SPL_BUILD is.
Hi Stephen,
Sorry about this.
}tegra_spl_gpio_direction_output(GPIO_PI4, 1);
See my previous reply.
I think this will drop the message. But I should have mentioned in my other reply that we don't really need to call gpio_early_init_uart() from board_early_init_f() if we are already calling it from spl_board_init(). Separate issue to this patch of course.
Hi Alban,
Sorry about this.
If you use patman it will take these out for you automatically without you having to think about it.
This is a temporary measure until the SPL series is applied to dm/next at least (I expect sometime this month). While driver model is available before relocation, the Tegra GPIO driver is not marked in the device tree with "u-boot,dm-pre-reloc", so is not available this early. Device tree additions give Stephen a headache, and I decided it was better for it not to work for now, and just use the SPL function.
There are three stages to consider:
1. SPL 2. U-Boot, before relocation 3. U-Boot, after relocation
At present, driver model does not support 1 (see dm/spl-working for patches if you want to see this). It supports 2 but only for drivers marked pre-relocation (except serial, for which a hack forces the console to be bound and used in the device tree case without the u-boot,dm-pre-reloc marker). It supports 3 fully.
There is a bit of an update on current status here:
http://www.denx.de/wiki/U-Boot/DriverModel
My approach with driver model is incremental, since that's the only way to make any progress.
This should work:
ifndef CONFIG_SPL_BUILD obj-y += tamonten.o endif
But it seems odd to me. At least on seaboard I didn't get the SPL message unless this code was executed.
On 10/02/2014 01:05 PM, Simon Glass wrote:
Hi Alban,
Sorry about this.
- SPL
- U-Boot, before relocation
- U-Boot, after relocation
That's roughly what I expected. Given that, I fail to see why the following wouldn't work then:
(or have just 1 of those two ifdef branches; presumably the GPIO only needs to be initialized in one place not both?)
Hi Stephen,
Hi Alban,
Sorry about this.
- SPL
Yes that's true, although be aware that the gpio_request() and gpio_direction_output() will in fact always fail at present, since they are called before the GPIO driver is inited pre-reloc. But since it has happened in SPL it doesn't matter.
I haven't tested this, and it's icky to rely on failure and not checking the return code, and I slightly prefer Alban's solution at least for now. This is only going to be a problem for another month or so.
Alban Bedel
Stephen Warren
