[PATCH] arm: stm32mp1: Set soc_type, soc_pkg, soc_rev env variables
Split up get_soc_name(), clean the decoding up a bit, and set up environment variables which contain the SoC type, package, revision. This is useful on SoMs, where multiple SoC options are populated.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- arch/arm/mach-stm32mp/cpu.c | 105 ++++++++++++++++++------------------ 1 file changed, 53 insertions(+), 52 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 3faa4ec18a4..887db9b5b0c 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -349,89 +349,78 @@ u32 get_cpu_package(void) return get_otp(BSEC_OTP_PKG, PKG_SHIFT, PKG_MASK); }
-void get_soc_name(char name[SOC_NAME_SIZE]) +static const char * const soc_type[] = { + "????", + "151C", "151A", "151F", "151D", + "153C", "153A", "153F", "153D", + "157C", "157A", "157F", "157D" +}; + +static const char * const soc_pkg[] = { "??", "AD", "AC", "AB", "AA" }; +static const char * const soc_rev[] = { "?", "A", "B", "Z" }; + +static void get_cpu_string_offsets(unsigned int *type, unsigned int *pkg, + unsigned int *rev) { - char *cpu_s, *cpu_r, *pkg; + u32 cpu_type = get_cpu_type(); + u32 ct = cpu_type & ~(BIT(7) | BIT(0)); + u32 cm = ((cpu_type & BIT(7)) >> 6) | (cpu_type & BIT(0)); + u32 cp = get_cpu_package();
- /* MPUs Part Numbers */ - switch (get_cpu_type()) { - case CPU_STM32MP157Fxx: - cpu_s = "157F"; - break; - case CPU_STM32MP157Dxx: - cpu_s = "157D"; - break; - case CPU_STM32MP157Cxx: - cpu_s = "157C"; - break; - case CPU_STM32MP157Axx: - cpu_s = "157A"; - break; - case CPU_STM32MP153Fxx: - cpu_s = "153F"; - break; - case CPU_STM32MP153Dxx: - cpu_s = "153D"; + /* Bits 0 and 7 are the ACDF, 00:C 01:A 10:F 11:D */ + switch (ct) { + case CPU_STM32MP151Cxx: + *type = cm + 1; break; case CPU_STM32MP153Cxx: - cpu_s = "153C"; - break; - case CPU_STM32MP153Axx: - cpu_s = "153A"; - break; - case CPU_STM32MP151Fxx: - cpu_s = "151F"; - break; - case CPU_STM32MP151Dxx: - cpu_s = "151D"; + *type = cm + 5; break; - case CPU_STM32MP151Cxx: - cpu_s = "151C"; - break; - case CPU_STM32MP151Axx: - cpu_s = "151A"; + case CPU_STM32MP157Cxx: + *type = cm + 9; break; default: - cpu_s = "????"; + *type = 0; break; }
/* Package */ - switch (get_cpu_package()) { + switch (cp) { case PKG_AA_LBGA448: - pkg = "AA"; - break; case PKG_AB_LBGA354: - pkg = "AB"; - break; case PKG_AC_TFBGA361: - pkg = "AC"; - break; case PKG_AD_TFBGA257: - pkg = "AD"; + *pkg = cp; break; default: - pkg = "??"; + pkg = 0; break; }
- /* REVISION */ + /* Revision */ switch (get_cpu_rev()) { case CPU_REVA: - cpu_r = "A"; + *rev = 1; break; case CPU_REVB: - cpu_r = "B"; + *rev = 2; break; case CPU_REVZ: - cpu_r = "Z"; + *rev = 3; break; default: - cpu_r = "?"; + *rev = 0; break; } +} + +void get_soc_name(char name[SOC_NAME_SIZE]) +{ + unsigned int type, pkg, rev;
- snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", cpu_s, pkg, cpu_r); + get_cpu_string_offsets(&type, &pkg, &rev); + + snprintf(name, SOC_NAME_SIZE, "STM32MP%s%s Rev.%s", + soc_type[type], soc_pkg[pkg], soc_rev[rev]); }
#if defined(CONFIG_DISPLAY_CPUINFO) @@ -620,11 +609,23 @@ static int setup_serial_number(void) return 0; }
+static void setup_soc_type_pkg_rev(void) +{ + unsigned int type, pkg, rev; + + get_cpu_string_offsets(&type, &pkg, &rev); + + env_set("soc_type", soc_type[type]); + env_set("soc_pkg", soc_pkg[pkg]); + env_set("soc_rev", soc_rev[rev]); +} + int arch_misc_init(void) { setup_boot_mode(); setup_mac_address(); setup_serial_number(); + setup_soc_type_pkg_rev();
return 0; }
Hi Marek
- "151C", "151A", "151F", "151D",
- "153C", "153A", "153F", "153D",
- "157C", "157A", "157F", "157D"
unsigned int *rev)
- u32 cpu_type = get_cpu_type();
- u32 ct = cpu_type & ~(BIT(7) | BIT(0));
- u32 cm = ((cpu_type & BIT(7)) >> 6) | (cpu_type & BIT(0));
- u32 cp = get_cpu_package();
cpu_s = "157F";
break;
cpu_s = "157D";
break;
cpu_s = "157C";
break;
cpu_s = "157A";
break;
cpu_s = "153F";
break;
cpu_s = "153D";
- /* Bits 0 and 7 are the ACDF, 00:C 01:A 10:F 11:D */
- switch (ct) {
break; case CPU_STM32MP153Cxx:*type = cm + 1;
cpu_s = "153C";
break;
cpu_s = "153A";
break;
cpu_s = "151F";
break;
cpu_s = "151D";
break;*type = cm + 5;
cpu_s = "151C";
break;
cpu_s = "151A";
break; default:*type = cm + 9;
cpu_s = "????";
*type = 0;
break; }
/* Package */
- switch (cp) { case PKG_AA_LBGA448:
pkg = "AA";
case PKG_AB_LBGA354:break;
pkg = "AB";
case PKG_AC_TFBGA361:break;
pkg = "AC";
case PKG_AD_TFBGA257:break;
pkg = "AD";
break; default:*pkg = cp;
pkg = "??";
break; }pkg = 0;
- /* REVISION */
- /* Revision */ switch (get_cpu_rev()) { case CPU_REVA:
cpu_r = "A";
break; case CPU_REVB:*rev = 1;
cpu_r = "B";
break; case CPU_REVZ:*rev = 2;
cpu_r = "Z";
break; default:*rev = 3;
cpu_r = "?";
break; }*rev = 0;
- unsigned int type, pkg, rev;
- get_cpu_string_offsets(&type, &pkg, &rev);
- env_set("soc_type", soc_type[type]);
- env_set("soc_pkg", soc_pkg[pkg]);
- env_set("soc_rev", soc_rev[rev]);
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Hi Marek,
{unsigned int *rev)
cpu_s = "157F";
break;
cpu_s = "157D";
break;
cpu_s = "157C";
break;
cpu_s = "157A";
break;
cpu_s = "153F";
break;
cpu_s = "153D";
- switch (ct) {
cpu_s = "153C";
break;
cpu_s = "153A";
break;
cpu_s = "151F";
break;
cpu_s = "151D";
cpu_s = "151C";
break;
cpu_s = "151A";
cpu_s = "????";
*type = 0;
break; }
/* Package */
pkg = "AA";
pkg = "AB";
pkg = "AC";
pkg = "AD";
./include/dt-bindings/pinctrl/stm32-pinfunc.h:37:
#define STM32MP_PKG_AA 0x1 #define STM32MP_PKG_AB 0x2 #define STM32MP_PKG_AC 0x4 #define STM32MP_PKG_AD 0x8
So it can't be used as index in array in the next part of the patch
=> soc_pkg[pkg]
need to parse a array ?
static const struct { const u8 value; char *; } static const char * const soc_pkg[] = { { 0, "??"}, { STM32MP_PKG_AA, "AA" }, { STM32MP_PKG_AB, "AB" }, { STM32MP_PKG_AC, "AC" }, { STM32MP_PKG_AD, "AD" }};
pkg = "??";
break; }pkg = 0;
- /* REVISION */
cpu_r = "A";
cpu_r = "B";
cpu_r = "Z";
*rev = 3;
For information rev = 2.1 => "Z" for STM32MP15 in STMicrolectonics naming rules
normally
v1 => "A"
v2 => "B"
v3 => "C"
"Z" => first minor revision of the chip vX.1
"Y" => second minor revision of the chip => vX.2 or vY.1
It is a nightmare to have coherent naming rule, but I propose to use a numericale value in "soc_rev"
/* Revision */ switch (get_cpu_rev()) { case CPU_REVA: *rev = 10; break; case CPU_REVB: *rev = 20; break; case CPU_REVZ: *rev = 21; break;
printf("%d") in env variable => "soc_rev"
or
value = get_cup_rev();
*rev_value = (value & 0xF000 > 24) * 10 + (value & 0xF);
and search in array for associated string to display the associated character (only required to respect the STMicrolectronic nomenclature as request by our Marketing)
static const struct { const u8 value; char *; } static const char * const soc_rev[] = { { 0, "?"}, { 10, "A" }, { 20, "B" }, { 21, "Z" }; /* revZ for v2.1 on STM32MP15 */
other solution: parsing an array
static const struct { const u32 value; char *; } static const char * const soc_rev[] = { { 0, "?"}, { CPU_REVA, "A" }, { CPU_REVB, "B" }, { CPU_REVZ, "Z" }; /* revZ for v2.1 on STM32MP15 */
break;
default:
cpu_r = "?";
break; }*rev = 0;
return 0; }
FYI: I plan to move this part in UCLASS_SOC, to prepare new SOC introduction
I hopes that will solve also this issues => soc_get_revision / soc_get_machine
even if package is missing in soc_uclass....
Patrick
Patrice CHOTARD
Patrick DELAUNAY
