[U-Boot] [PATCH] OMAP: Fix copy-paste bug that did not enable UART4 clock
UART3 was enabled twice instead of UART4.
One more cosmetic change in a comment on EMIF clock.
Signed-off-by: Lubomir Popov lpopov@mm-sol.com
--- arch/arm/cpu/armv7/omap-common/clocks-common.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index 9ed1899..2b955c7 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -612,7 +612,7 @@ void freq_update_core(void)
/* * Putting EMIF in HW_AUTO is seen to be causing issues with - * EMIF clocks and the master DLL. Put EMIF in SW_WKUP + * EMIF clocks and the master DLL. Keep EMIF in SW_WKUP * in OMAP5430 ES1.0 silicon */ if (omap_rev != OMAP5430_ES1_0) { @@ -659,7 +659,7 @@ void setup_clocks_for_console(void) MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << MODULE_CLKCTRL_MODULEMODE_SHIFT);
- clrsetbits_le32((*prcm)->cm_l4per_uart3_clkctrl, + clrsetbits_le32((*prcm)->cm_l4per_uart4_clkctrl, MODULE_CLKCTRL_MODULEMODE_MASK, MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << MODULE_CLKCTRL_MODULEMODE_SHIFT);
Lubomir Popov
