[U-Boot] [PATCH] ARM: imx6ul: Move liteSOM source to SoC directory
Moving arch/arm/mach-litesom/ to arch/arm/cpu/armv7/mx6/ was requested in [1] during discussion of chiliSOM support patches.
[1] http://lists.denx.de/pipermail/u-boot/2017-January/279137.html
Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- arch/arm/Kconfig | 2 -- arch/arm/Makefile | 1 - arch/arm/cpu/armv7/mx6/Kconfig | 9 ++++++++- arch/arm/cpu/armv7/mx6/Makefile | 1 + arch/arm/{mach-litesom => cpu/armv7/mx6}/litesom.c | 0 .../include/mach => include/asm/arch-mx6}/litesom.h | 4 ++-- arch/arm/mach-litesom/Kconfig | 6 ------ arch/arm/mach-litesom/Makefile | 6 ------ board/grinn/liteboard/board.c | 2 +- 9 files changed, 12 insertions(+), 19 deletions(-) rename arch/arm/{mach-litesom => cpu/armv7/mx6}/litesom.c (100%) rename arch/arm/{mach-litesom/include/mach => include/asm/arch-mx6}/litesom.h (68%) delete mode 100644 arch/arm/mach-litesom/Kconfig delete mode 100644 arch/arm/mach-litesom/Makefile
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 30f0925308..b96a86ef85 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -989,8 +989,6 @@ source "arch/arm/mach-keystone/Kconfig"
source "arch/arm/mach-kirkwood/Kconfig"
-source "arch/arm/mach-litesom/Kconfig" - source "arch/arm/mach-mvebu/Kconfig"
source "arch/arm/cpu/armv7/ls102xa/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 4b8bf80c40..9c6834b332 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -58,7 +58,6 @@ machine-$(CONFIG_ARCH_HIGHBANK) += highbank machine-$(CONFIG_ARCH_KEYSTONE) += keystone # TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD machine-$(CONFIG_KIRKWOOD) += kirkwood -machine-$(CONFIG_LITESOM) += litesom machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu # TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index b8dc5c8df6..1ee96cc125 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -35,6 +35,13 @@ config MX6UL select ROM_UNIFIED_SECTIONS bool
+config MX6UL_LITESOM + bool + select MX6UL + select DM + select DM_THERMAL + select SUPPORT_SPL + config MX6ULL bool select MX6UL @@ -244,7 +251,7 @@ config TARGET_PICO_IMX6UL config TARGET_LITEBOARD bool "Grinn liteBoard (i.MX6UL)" select BOARD_LATE_INIT - select LITESOM + select MX6UL_LITESOM
config TARGET_PLATINUM_PICON bool "platinum-picon" diff --git a/arch/arm/cpu/armv7/mx6/Makefile b/arch/arm/cpu/armv7/mx6/Makefile index 8af191d660..024f7031ad 100644 --- a/arch/arm/cpu/armv7/mx6/Makefile +++ b/arch/arm/cpu/armv7/mx6/Makefile @@ -10,3 +10,4 @@ obj-y := soc.o clock.o obj-$(CONFIG_SPL_BUILD) += ddr.o obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_MX6UL_LITESOM) += litesom.o diff --git a/arch/arm/mach-litesom/litesom.c b/arch/arm/cpu/armv7/mx6/litesom.c similarity index 100% rename from arch/arm/mach-litesom/litesom.c rename to arch/arm/cpu/armv7/mx6/litesom.c diff --git a/arch/arm/mach-litesom/include/mach/litesom.h b/arch/arm/include/asm/arch-mx6/litesom.h similarity index 68% rename from arch/arm/mach-litesom/include/mach/litesom.h rename to arch/arm/include/asm/arch-mx6/litesom.h index 6833949ae8..656b96aca9 100644 --- a/arch/arm/mach-litesom/include/mach/litesom.h +++ b/arch/arm/include/asm/arch-mx6/litesom.h @@ -4,8 +4,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __ARCH_ARM_MACH_LITESOM_SOM_H__ -#define __ARCH_ARM_MACH_LITESOM_SOM_H__ +#ifndef __ARCH_ARM_MX6UL_LITESOM_H__ +#define __ARCH_ARM_MX6UL_LITESOM_H__
int litesom_mmc_init(bd_t *bis);
diff --git a/arch/arm/mach-litesom/Kconfig b/arch/arm/mach-litesom/Kconfig deleted file mode 100644 index 9b7f36d7ba..0000000000 --- a/arch/arm/mach-litesom/Kconfig +++ /dev/null @@ -1,6 +0,0 @@ -config LITESOM - bool - select MX6UL - select DM - select DM_THERMAL - select SUPPORT_SPL diff --git a/arch/arm/mach-litesom/Makefile b/arch/arm/mach-litesom/Makefile deleted file mode 100644 index b15eb64793..0000000000 --- a/arch/arm/mach-litesom/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# (C) Copyright 2016 Grinn -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y := litesom.o diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 13dd0a63db..2d184c8125 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -9,6 +9,7 @@ #include <asm/arch/iomux.h> #include <asm/arch/imx-regs.h> #include <asm/arch/crm_regs.h> +#include <asm/arch/litesom.h> #include <asm/arch/mx6ul_pins.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> @@ -20,7 +21,6 @@ #include <fsl_esdhc.h> #include <linux/sizes.h> #include <linux/fb.h> -#include <mach/litesom.h> #include <miiphy.h> #include <mmc.h> #include <netdev.h>
- bool
- select MX6UL
- select DM
- select DM_THERMAL
- select LITESOM
- select MX6UL_LITESOM
- bool
- select MX6UL
- select DM
- select DM_THERMAL
Best regards, Stefano Babic
Marcin Niestroj
Stefano Babic
