[U-Boot] [PATCH] ColdFire: Fix M54451 serial boot dram setup
The serial boot dram extended/standard mode register was not setup and was using default DRAM setup causing the U-boot was unstable to boot up in serial mode.
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- cpu/mcf5445x/start.S | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpu/mcf5445x/start.S b/cpu/mcf5445x/start.S index d5a7f93..26fb2ce 100644 --- a/cpu/mcf5445x/start.S +++ b/cpu/mcf5445x/start.S @@ -243,9 +243,9 @@ wait1000: nop #elif defined(CONFIG_M54451EVB) /* Issue LEMR */ - move.l #(CONFIG_SYS_SDRAM_MODE), (%a2) + move.l #(CONFIG_SYS_SDRAM_MODE), (%a1) nop - move.l #(CONFIG_SYS_SDRAM_EMOD), (%a2) + move.l #(CONFIG_SYS_SDRAM_EMOD), (%a1) nop #endif
Tsi-Chung Liew
