[U-Boot] [PATCH] fdt: Add warning about CONFIG_OF_EMBED
This option has crept into use with some boards. Add a warning to try to prevent this.
As an example: https://lists.denx.de/pipermail/u-boot/2017-September/304966.html
Makefile | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/Makefile b/Makefile index 0d11ff97971..05896598fe3 100644 --- a/Makefile +++ b/Makefile @@ -947,6 +947,14 @@ ifeq ($(CONFIG_LIBATA)$(CONFIG_DM_SCSI)$(CONFIG_MVSATA_IDE),y) @echo "Failure to update by the deadline may result in board removal." @echo "See doc/driver-model/MIGRATION.txt for more info." @echo "====================================================" +endif +ifeq ($(CONFIG_OF_EMBED),y) + @echo "===================== WARNING ======================" + @echo "CONFIG_OF_EMBED is enabled. This option should only" + @echo "be used for debugging purposes. Please use" + @echo "CONFIG_OF_SEPARATE for boards in mainline." + @echo "See doc/README.fdt-control for more info." + @echo "====================================================" endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG
Am 05.12.2018 um 14:57 schrieb Simon Glass:
We have just discussed this in another thread. There seem to be ~109 defconfigs in the tree that enable OF_EMBED.
I doubt all of them do this for fun, so we might want to collect the reasons they do so. I do know two:
- socfpga_stratix10_defconfig needs this to get a correct u-boot-spl.hex - I would need it to ensure in SPL, the DTB is in one block with the other readonly parts. Without OF_EMBED, we have '.text', '.bss', DT.
- @echo "===================== WARNING ======================"
- @echo "CONFIG_OF_EMBED is enabled. This option should only"
- @echo "be used for debugging purposes. Please use"
- @echo "CONFIG_OF_SEPARATE for boards in mainline."
- @echo "See doc/README.fdt-control for more info."
- @echo "====================================================" endif @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG
Hi Simon,
On Wed, 5 Dec 2018 at 07:22, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Let's fix that then.
Similarly, let's change that.
CONFIG_OF_EMBED should not be a work-around for missing features that we need.
Hi Simon,
Am 05.12.2018 um 16:57 schrieb Simon Glass:
Hi Simon,
I'm with you there. Don't get me wrong, I don't want to argue to use OF_EMBED, just wanted to list the use cases I know so that we only fix them once instead of letting everyone fixing them on their own.
On Wed, Dec 05, 2018 at 05:08:53PM +0100, Simon Goldschmidt wrote:
Hi Simon,
Hi Simon,
Yes, please, what is the way to fix say this one board? And can we then from there try and (semi)automate changing over?
Dear Simon and Simon,
u-boot-spl.hex
Another use case is imx6:
When I want to use SPL's embedded DTB for early init, with OF_SEPARATE I get fdt_blob = (ulong *)&__bss_end; ,which points me to 0x18200060, which is in DDR (and there is either garbage nor DDR is not initialized at all).
The above looks like the __bss_end is for u-boot proper.
The workaround (for now) is to have OF_EMBED, which assigns gd->fdt_blob = __dtb_dt_spl_begin [1], and this is a correct address.
Hence, I'm wondering if shall I assign: gd->fdt_blob = __dtb_dt_spl_begin;
in my early SPL code (and do not use fdt_setup() function at all in SPL) ?
Moreover, defining board_fdt_blob_setup() for _each_ IMX6 board which would switch to DM_MMC in SPL seems like an no acceptable solution.
[1] - ./spl/dts/dt-spl.dtb.S:3:.global __dtb_dt_spl_begin --> Looks like __dtb_dt_spl_begin is exactly for this purpose.
- @echo
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
u-boot-spl.hex
Or you could update fdt_setup() to do what you want (perhaps with a new CONFIG?).
Hi Simon,
Hi Lukasz,
u-boot-spl.hex
I've found the root cause of this problem....
For the board I had not defined CONFIG_SPL_SEPARATE_BSS. After providing it the OF_SEPARATE can be used (and dtb is appended between SPL binary and bss (in SDRAM) region.
Lukasz Majewski
Hi Lukasz,
On Mon, 31 Dec 2018 at 04:26, Lukasz Majewski lukma@denx.de wrote:
Hi Simon,
Hi Lukasz,
u-boot-spl.hex
OK that's great news, thank you for digging into it.
Lukasz Majewski
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
Lukasz Majewski
Simon Goldschmidt
