[U-Boot] [PATCH v2 1/5] efi: app: Add a sysreset driver
This adds the DM sysreset driver for EFI application support.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - drop patches already applied - new patch to add a sysreset driver for efi app
lib/efi/efi_app.c | 28 +++++++++++++++++++++++++++- 1 file changed, 27 insertions(+), 1 deletion(-)
diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index 3eb8eeb..5879d40 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -10,11 +10,13 @@
#include <common.h> #include <debug_uart.h> +#include <dm.h> #include <errno.h> #include <linux/err.h> #include <linux/types.h> #include <efi.h> #include <efi_api.h> +#include <sysreset.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -129,7 +131,7 @@ efi_status_t EFIAPI efi_main(efi_handle_t image, return EFI_SUCCESS; }
-void reset_cpu(ulong addr) +static void efi_exit(void) { struct efi_priv *priv = global_priv;
@@ -137,3 +139,27 @@ void reset_cpu(ulong addr) printf("U-Boot EFI exiting\n"); priv->boot->exit(priv->parent_image, EFI_SUCCESS, 0, NULL); } + +static int efi_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + efi_exit(); + + return -EINPROGRESS; +} + +static const struct udevice_id efi_sysreset_ids[] = { + { .compatible = "efi,reset" }, + { } +}; + +static struct sysreset_ops efi_sysreset_ops = { + .request = efi_sysreset_request, +}; + +U_BOOT_DRIVER(efi_sysreset) = { + .name = "efi-sysreset", + .id = UCLASS_SYSRESET, + .of_match = efi_sysreset_ids, + .ops = &efi_sysreset_ops, + .flags = DM_FLAG_PRE_RELOC, +};
This adds a reset driver for tangier processor.
Changes in v2: - new patch to add a reset driver for tangier processor
arch/x86/cpu/tangier/Makefile | 2 +- arch/x86/cpu/tangier/sysreset.c | 48 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 49 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/tangier/sysreset.c
diff --git a/arch/x86/cpu/tangier/Makefile b/arch/x86/cpu/tangier/Makefile index 44ccb3f..8274482 100644 --- a/arch/x86/cpu/tangier/Makefile +++ b/arch/x86/cpu/tangier/Makefile @@ -2,5 +2,5 @@ # # Copyright (c) 2017 Intel Corporation
-obj-y += car.o tangier.o sdram.o +obj-y += car.o tangier.o sdram.o sysreset.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o diff --git a/arch/x86/cpu/tangier/sysreset.c b/arch/x86/cpu/tangier/sysreset.c new file mode 100644 index 0000000..e762ee1 --- /dev/null +++ b/arch/x86/cpu/tangier/sysreset.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + * + * Reset driver for tangier processor + */ + +#include <common.h> +#include <dm.h> +#include <sysreset.h> +#include <asm/scu.h> + +static int tangier_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + int value; + + switch (type) { + case SYSRESET_WARM: + value = IPCMSG_WARM_RESET; + break; + case SYSRESET_COLD: + value = IPCMSG_COLD_RESET; + break; + default: + return -ENOSYS; + } + + scu_ipc_simple_command(value, 0); + + return -EINPROGRESS; +} + +static const struct udevice_id tangier_sysreset_ids[] = { + { .compatible = "intel,reset-tangier" }, + { } +}; + +static struct sysreset_ops tangier_sysreset_ops = { + .request = tangier_sysreset_request, +}; + +U_BOOT_DRIVER(tangier_sysreset) = { + .name = "tangier-sysreset", + .id = UCLASS_SYSRESET, + .of_match = tangier_sysreset_ids, + .ops = &tangier_sysreset_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Andy,
Changes in v2:
Could you please help test this driver? This series is at u-boot-x86/reset branch. Thanks!
Regards, Bin
On Thu, 2018-07-19 at 18:04 +0800, Bin Meng wrote:
Hi Andy,
Changes in v2:
Can you point me out to what exact steps I have to perform to test this functionality?
Just boot to U-boot console, run 'reset' and see if everything works as before? Or something more?
Hi Andy,
Changes in v2:
So, I merged the mentioned branch on top of my testing setup for ACPI bits. After, I boot to U-boot console and type reset (done 2 times with different delay after boot: few seconds vs. few dozen of seconds). After I tried to boot my ACPI kernel.
If it's enough, you may take mine Tested-by: Andy Shevchenko andriy.shevchenko@linux.intel.com
for u-boot-x86/reset branch.
Hi Andy,
On Thu, Jul 19, 2018 at 6:38 PM, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Hi Andy,
Changes in v2:
This is enough. Thank you for the testing!
Regards, Bin
Changes in v2:
Changes in v2:
applied to u-boot-x86, thanks!
It's good to print a message when doing reset.
Changes in v2: - new patch per Wolfgang's suggestion to add a standard message when doing reset
drivers/sysreset/sysreset-uclass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index 7e06c3c..59dbe99 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -69,6 +69,8 @@ void reset_cpu(ulong addr)
int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { + printf("resetting ...\n"); + sysreset_walk_halt(SYSRESET_COLD);
Changes in v2:
I wonder how many platforms will actually show this message and how many will just put it in their serial buffer and then discard it?
Changes in v2:
Edison does.
Changes in v2:
In preparation for the reset driver conversion, eliminate the reset_cpu() call in the FSP init path as it's too early for the reset driver to work.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
arch/x86/lib/fsp/fsp_common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index b4ba129..d5ed1d5 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -132,7 +132,7 @@ int arch_fsp_init(void) chipset_clear_sleep_state(); /* Reboot */ debug("Rebooting..\n"); - reset_cpu(0); + outb(SYS_RST | RST_CPU, IO_PORT_RESET); /* Should not reach here.. */ panic("Reboot System"); }
Changes in v2: None
Adding back
Changes in v2: None
Adding back
This converts all x86 boards over to DM sysreset.
Changes in v2: - remove include of "reset.dsti" in edison.dts - add SYSRESET for efi-x86_app and edison
arch/Kconfig | 2 ++ arch/x86/cpu/baytrail/valleyview.c | 6 ------ arch/x86/cpu/braswell/braswell.c | 6 ------ arch/x86/cpu/cpu.c | 26 -------------------------- arch/x86/cpu/ivybridge/early_me.c | 7 ++++--- arch/x86/cpu/ivybridge/sdram.c | 3 ++- arch/x86/cpu/qemu/qemu.c | 6 ------ arch/x86/cpu/quark/quark.c | 6 ------ arch/x86/cpu/tangier/tangier.c | 6 ------ arch/x86/dts/bayleybay.dts | 1 + arch/x86/dts/baytrail_som-db5800-som-6867.dts | 1 + arch/x86/dts/broadwell_som-6896.dts | 1 + arch/x86/dts/cherryhill.dts | 1 + arch/x86/dts/chromebook_link.dts | 1 + arch/x86/dts/chromebook_samus.dts | 1 + arch/x86/dts/chromebox_panther.dts | 1 + arch/x86/dts/conga-qeval20-qa3-e3845.dts | 1 + arch/x86/dts/cougarcanyon2.dts | 1 + arch/x86/dts/crownbay.dts | 1 + arch/x86/dts/dfi-bt700.dtsi | 1 + arch/x86/dts/edison.dts | 5 +++++ arch/x86/dts/efi-x86_app.dts | 5 +++++ arch/x86/dts/efi-x86_payload.dts | 1 + arch/x86/dts/galileo.dts | 1 + arch/x86/dts/minnowmax.dts | 1 + arch/x86/dts/qemu-x86_i440fx.dts | 1 + arch/x86/dts/qemu-x86_q35.dts | 1 + arch/x86/dts/reset.dtsi | 6 ++++++ arch/x86/include/asm/processor.h | 5 ----- arch/x86/include/asm/u-boot-x86.h | 1 - configs/chromebook_link64_defconfig | 1 + 31 files changed, 41 insertions(+), 66 deletions(-) create mode 100644 arch/x86/dts/reset.dtsi
diff --git a/arch/Kconfig b/arch/Kconfig index dd5a887..cbeb9f6 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -118,6 +118,8 @@ config X86 imply DM_SPI_FLASH imply DM_USB imply DM_VIDEO + imply SYSRESET + imply SYSRESET_X86 imply CMD_FPGA_LOADMK imply CMD_GETTIME imply CMD_IO diff --git a/arch/x86/cpu/baytrail/valleyview.c b/arch/x86/cpu/baytrail/valleyview.c index b7d481a..8882a76 100644 --- a/arch/x86/cpu/baytrail/valleyview.c +++ b/arch/x86/cpu/baytrail/valleyview.c @@ -55,9 +55,3 @@ int arch_misc_init(void)
return 0; } - -void reset_cpu(ulong addr) -{ - /* cold reset */ - x86_full_reset(); -} diff --git a/arch/x86/cpu/braswell/braswell.c b/arch/x86/cpu/braswell/braswell.c index 32a6a5e..7a83b06 100644 --- a/arch/x86/cpu/braswell/braswell.c +++ b/arch/x86/cpu/braswell/braswell.c @@ -27,9 +27,3 @@ int arch_misc_init(void)
return 0; } - -void reset_cpu(ulong addr) -{ - /* cold reset */ - x86_full_reset(); -} diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 99f8e68..290ee08 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -76,37 +76,11 @@ int x86_init_cache(void) } int init_cache(void) __attribute__((weak, alias("x86_init_cache")));
-int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - printf("resetting ...\n"); - - /* wait 50 ms */ - udelay(50000); - disable_interrupts(); - reset_cpu(0); - - /*NOTREACHED*/ - return 0; -} - void flush_cache(unsigned long dummy1, unsigned long dummy2) { asm("wbinvd\n"); }
-__weak void reset_cpu(ulong addr) -{ - /* Do a hard reset through the chipset's reset control register */ - outb(SYS_RST | RST_CPU, IO_PORT_RESET); - for (;;) - cpu_hlt(); -} - -void x86_full_reset(void) -{ - outb(FULL_RST | SYS_RST | RST_CPU, IO_PORT_RESET); -} - /* Define these functions to allow ehch-hcd to function */ void flush_dcache_range(unsigned long start, unsigned long stop) { diff --git a/arch/x86/cpu/ivybridge/early_me.c b/arch/x86/cpu/ivybridge/early_me.c index 1a15229..219d5be 100644 --- a/arch/x86/cpu/ivybridge/early_me.c +++ b/arch/x86/cpu/ivybridge/early_me.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <sysreset.h> #include <asm/pci.h> #include <asm/cpu.h> #include <asm/processor.h> @@ -138,17 +139,17 @@ int intel_early_me_init_done(struct udevice *dev, struct udevice *me_dev, case ME_HFS_ACK_RESET: /* Non-power cycle reset */ set_global_reset(dev, 0); - reset_cpu(0); + sysreset_walk_halt(SYSRESET_COLD); break; case ME_HFS_ACK_PWR_CYCLE: /* Power cycle reset */ set_global_reset(dev, 0); - x86_full_reset(); + sysreset_walk_halt(SYSRESET_COLD); break; case ME_HFS_ACK_GBL_RESET: /* Global reset */ set_global_reset(dev, 1); - x86_full_reset(); + sysreset_walk_halt(SYSRESET_COLD); break; case ME_HFS_ACK_S3: case ME_HFS_ACK_S4: diff --git a/arch/x86/cpu/ivybridge/sdram.c b/arch/x86/cpu/ivybridge/sdram.c index 2f253e8..8a58d03 100644 --- a/arch/x86/cpu/ivybridge/sdram.c +++ b/arch/x86/cpu/ivybridge/sdram.c @@ -18,6 +18,7 @@ #include <spi.h> #include <spi_flash.h> #include <syscon.h> +#include <sysreset.h> #include <asm/cpu.h> #include <asm/processor.h> #include <asm/gpio.h> @@ -497,7 +498,7 @@ int dram_init(void) /* If MRC data is not found we cannot continue S3 resume. */ if (pei_data->boot_mode == PEI_BOOT_RESUME && !pei_data->mrc_input) { debug("Giving up in sdram_initialize: No MRC data\n"); - reset_cpu(0); + sysreset_walk_halt(SYSRESET_COLD); }
/* Pass console handler in pei_data */ diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index ca4b3f0..5e8b4f0 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -156,12 +156,6 @@ int print_cpuinfo(void) } #endif
-void reset_cpu(ulong addr) -{ - /* cold reset */ - x86_full_reset(); -} - int arch_early_init_r(void) { qemu_chipset_init(); diff --git a/arch/x86/cpu/quark/quark.c b/arch/x86/cpu/quark/quark.c index 4fd6864..d39edb2 100644 --- a/arch/x86/cpu/quark/quark.c +++ b/arch/x86/cpu/quark/quark.c @@ -270,12 +270,6 @@ int print_cpuinfo(void) return default_print_cpuinfo(); }
-void reset_cpu(ulong addr) -{ - /* cold reset */ - x86_full_reset(); -} - static void quark_pcie_init(void) { u32 val; diff --git a/arch/x86/cpu/tangier/tangier.c b/arch/x86/cpu/tangier/tangier.c index 0a15e64..df2c600 100644 --- a/arch/x86/cpu/tangier/tangier.c +++ b/arch/x86/cpu/tangier/tangier.c @@ -4,7 +4,6 @@ */
#include <common.h> -#include <asm/scu.h> #include <asm/u-boot-x86.h>
/* @@ -24,8 +23,3 @@ int print_cpuinfo(void) { return default_print_cpuinfo(); } - -void reset_cpu(ulong addr) -{ - scu_ipc_simple_command(IPCMSG_COLD_RESET, 0); -} diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 74291a8..9683c52 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -12,6 +12,7 @@ /include/ "skeleton.dtsi" /include/ "keyboard.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/baytrail_som-db5800-som-6867.dts b/arch/x86/dts/baytrail_som-db5800-som-6867.dts index 36e6069..4e8a761 100644 --- a/arch/x86/dts/baytrail_som-db5800-som-6867.dts +++ b/arch/x86/dts/baytrail_som-db5800-som-6867.dts @@ -12,6 +12,7 @@
/include/ "skeleton.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/broadwell_som-6896.dts b/arch/x86/dts/broadwell_som-6896.dts index 3966199..ec691f1 100644 --- a/arch/x86/dts/broadwell_som-6896.dts +++ b/arch/x86/dts/broadwell_som-6896.dts @@ -2,6 +2,7 @@
/include/ "skeleton.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/cherryhill.dts b/arch/x86/dts/cherryhill.dts index 3e29683..39e2d2f 100644 --- a/arch/x86/dts/cherryhill.dts +++ b/arch/x86/dts/cherryhill.dts @@ -10,6 +10,7 @@
diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index 26b9f85..115a088 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -5,6 +5,7 @@ /include/ "skeleton.dtsi" /include/ "keyboard.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index 52a9ea6..9c48c9a 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -5,6 +5,7 @@ /include/ "skeleton.dtsi" /include/ "keyboard.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/chromebox_panther.dts b/arch/x86/dts/chromebox_panther.dts index b25c919..a72a85e 100644 --- a/arch/x86/dts/chromebox_panther.dts +++ b/arch/x86/dts/chromebox_panther.dts @@ -2,6 +2,7 @@
/include/ "skeleton.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts index c3d1514..5884dbc 100644 --- a/arch/x86/dts/conga-qeval20-qa3-e3845.dts +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -12,6 +12,7 @@
diff --git a/arch/x86/dts/cougarcanyon2.dts b/arch/x86/dts/cougarcanyon2.dts index c1cda73..9801790 100644 --- a/arch/x86/dts/cougarcanyon2.dts +++ b/arch/x86/dts/cougarcanyon2.dts @@ -10,6 +10,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "keyboard.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index d8faa9d..2ffcc5f 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -10,6 +10,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "keyboard.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/dfi-bt700.dtsi b/arch/x86/dts/dfi-bt700.dtsi index cb96fdf..51d33e7 100644 --- a/arch/x86/dts/dfi-bt700.dtsi +++ b/arch/x86/dts/dfi-bt700.dtsi @@ -9,6 +9,7 @@ #include <dt-bindings/interrupt-router/intel-irq.h>
#include "skeleton.dtsi" +#include "reset.dtsi" #include "rtc.dtsi" #include "tsc_timer.dtsi"
diff --git a/arch/x86/dts/edison.dts b/arch/x86/dts/edison.dts index 9033532..5c80f5c 100644 --- a/arch/x86/dts/edison.dts +++ b/arch/x86/dts/edison.dts @@ -85,4 +85,9 @@ compatible = "intel,scu-ipc"; reg = <0xff009000 0x1000>; }; + + reset { + compatible = "intel,reset-tangier"; + u-boot,dm-pre-reloc; + }; }; diff --git a/arch/x86/dts/efi-x86_app.dts b/arch/x86/dts/efi-x86_app.dts index e70e351..20150f6 100644 --- a/arch/x86/dts/efi-x86_app.dts +++ b/arch/x86/dts/efi-x86_app.dts @@ -23,4 +23,9 @@ serial: serial { compatible = "efi,uart"; }; + + reset { + compatible = "efi,reset"; + u-boot,dm-pre-reloc; + }; }; diff --git a/arch/x86/dts/efi-x86_payload.dts b/arch/x86/dts/efi-x86_payload.dts index 148b587..19f2530 100644 --- a/arch/x86/dts/efi-x86_payload.dts +++ b/arch/x86/dts/efi-x86_payload.dts @@ -10,6 +10,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "keyboard.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index 3454abd..3a5d168 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -9,6 +9,7 @@ #include <dt-bindings/interrupt-router/intel-irq.h>
/include/ "skeleton.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 42ba0c7..02ab4c1 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -11,6 +11,7 @@
/include/ "skeleton.dtsi" /include/ "serial.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi" /include/ "coreboot_fb.dtsi" diff --git a/arch/x86/dts/qemu-x86_i440fx.dts b/arch/x86/dts/qemu-x86_i440fx.dts index 6565429..2e5210d 100644 --- a/arch/x86/dts/qemu-x86_i440fx.dts +++ b/arch/x86/dts/qemu-x86_i440fx.dts @@ -10,6 +10,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "keyboard.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/qemu-x86_q35.dts b/arch/x86/dts/qemu-x86_q35.dts index f1c4cb9..e8f55b1 100644 --- a/arch/x86/dts/qemu-x86_q35.dts +++ b/arch/x86/dts/qemu-x86_q35.dts @@ -20,6 +20,7 @@ /include/ "skeleton.dtsi" /include/ "serial.dtsi" /include/ "keyboard.dtsi" +/include/ "reset.dtsi" /include/ "rtc.dtsi" /include/ "tsc_timer.dtsi"
diff --git a/arch/x86/dts/reset.dtsi b/arch/x86/dts/reset.dtsi new file mode 100644 index 0000000..f979d83 --- /dev/null +++ b/arch/x86/dts/reset.dtsi @@ -0,0 +1,6 @@ +/ { + reset { + compatible = "x86,reset"; + u-boot,dm-pre-reloc; + }; +}; diff --git a/arch/x86/include/asm/processor.h b/arch/x86/include/asm/processor.h index dd957d2..f1d9977 100644 --- a/arch/x86/include/asm/processor.h +++ b/arch/x86/include/asm/processor.h @@ -43,11 +43,6 @@ enum { FULL_RST = 1 << 3, /* full power cycle */ };
-/** - * x86_full_reset() - reset everything: perform a full power cycle - */ -void x86_full_reset(void); - static inline __attribute__((always_inline)) void cpu_hlt(void) { asm("hlt"); diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index 2340ef8..670fcdc 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -40,7 +40,6 @@ int x86_cleanup_before_linux(void); void x86_enable_caches(void); void x86_disable_caches(void); int x86_init_cache(void); -void reset_cpu(ulong addr); ulong board_get_usable_ram_top(ulong total_size); int default_print_cpuinfo(void);
diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 59b6bd0..9af2c4d 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200
Changes in v2:
Changes in v2:
Changes in v2:
Changes in v2:
Andy Shevchenko
Bin Meng
