[PATCH] mtd: spi-nor-ids: Add Spansion s25fs512s flash entry
Spansion "s25fs512s" flash is incorrectly decoded as "s25fl512s" on various platforms as former is not present. Add the entry.
Linux already has both the flashes present. A snippet below: { "s25fl512s", INFO6(0x010220, 0x4d0080, 256 * 1024, 256...}, { "s25fs512s", INFO6(0x010220, 0x4d0081, 256 * 1024, 256...},
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- drivers/mtd/spi/spi-nor-ids.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 973b6f8..42baa84 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -193,7 +193,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25sl064p", 0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25fl256s0", 0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fl512s", 0x010220, 0x4d0080, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fs512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_512k", 0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
Kuldeep Singh
