[PATCH] lz4: Use a private header for U-Boot
At present U-Boot has a header file called lz4.h for its own use. If the host has its own lz4 header file installed (e.g. from the 'liblz4-dev' package) then host builds will use that instead.
Move the U-Boot file into its own directory, as is done with various other headers with the same problem.
Signed-off-by: Simon Glass sjg@chromium.org --- Here is the azure build
https://dev.azure.com/simon0972/u-boot/_build/results?buildId=9&view=res...
cmd/unlz4.c | 2 +- common/image.c | 2 +- include/{ => u-boot}/lz4.h | 0 lib/lz4_wrapper.c | 2 +- test/compression.c | 2 +- 5 files changed, 4 insertions(+), 4 deletions(-) rename include/{ => u-boot}/lz4.h (100%)
diff --git a/cmd/unlz4.c b/cmd/unlz4.c index 323ab467173..5f20838e899 100644 --- a/cmd/unlz4.c +++ b/cmd/unlz4.c @@ -7,7 +7,7 @@ #include <common.h> #include <command.h> #include <env.h> -#include <lz4.h> +#include <u-boot/lz4.h>
static int do_unlz4(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) diff --git a/common/image.c b/common/image.c index 5b77113bea3..3fa60b58279 100644 --- a/common/image.c +++ b/common/image.c @@ -61,7 +61,6 @@ DECLARE_GLOBAL_DATA_PTR; #include <display_options.h> #include <gzip.h> #include <image.h> -#include <lz4.h> #include <imximage.h> #include <relocate.h> #include <linux/lzo.h> @@ -71,6 +70,7 @@ DECLARE_GLOBAL_DATA_PTR; #include <lzma/LzmaDec.h> #include <lzma/LzmaTools.h> #include <u-boot/crc.h> +#include <u-boot/lz4.h>
static const table_entry_t uimage_arch[] = { { IH_ARCH_INVALID, "invalid", "Invalid ARCH", }, diff --git a/include/lz4.h b/include/u-boot/lz4.h similarity index 100% rename from include/lz4.h rename to include/u-boot/lz4.h diff --git a/lib/lz4_wrapper.c b/lib/lz4_wrapper.c index cdbcd05bd43..ebcb5c09a22 100644 --- a/lib/lz4_wrapper.c +++ b/lib/lz4_wrapper.c @@ -6,10 +6,10 @@ #include <common.h> #include <compiler.h> #include <image.h> -#include <lz4.h> #include <linux/kernel.h> #include <linux/types.h> #include <asm/unaligned.h> +#include <u-boot/lz4.h>
static u16 LZ4_readLE16(const void *src) { diff --git a/test/compression.c b/test/compression.c index 4cd1be564f3..26d3c80fb5a 100644 --- a/test/compression.c +++ b/test/compression.c @@ -9,11 +9,11 @@ #include <gzip.h> #include <image.h> #include <log.h> -#include <lz4.h> #include <malloc.h> #include <mapmem.h> #include <asm/io.h>
+#include <u-boot/lz4.h> #include <u-boot/zlib.h> #include <bzlib.h>
