[PATCH v2] doc: add bootelf command documentation
Signed-off-by: Maxim Moskalets maximmosk4@gmail.com --- v2: Add Configuration section. --- doc/usage/cmd/bootelf.rst | 58 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 58 insertions(+) create mode 100644 doc/usage/cmd/bootelf.rst
diff --git a/doc/usage/cmd/bootelf.rst b/doc/usage/cmd/bootelf.rst new file mode 100644 index 0000000000..748c3e2e4b --- /dev/null +++ b/doc/usage/cmd/bootelf.rst @@ -0,0 +1,58 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright 2024, Maxim Moskalets maximmosk4@gmail.com + +.. index:: + single: bootelf (command) + +bootelf command +=============== + +Synopsis +-------- + +:: + + bootelf [-p|-s] [-d <fdt_addr>] [<image_addr> [<arg>]...] + +Description +----------- + +The *bootelf* command is used to launch a ELF binary at *image_addr*. If +*image_addr* is not specified, the bootelf command will try to find image in +*image_load_addr* variable (*CONFIG_SYS_LOAD_ADDR* by default). + +Args after *image_addr* will be passed to application in common *argc*, *argv* +format. + +A command sequence to run a ELF image using FDT might look like + +:: + + load mmc 0:1 ${loadaddr} /kernel.elf + load mmc 0:1 ${fdt_addr_r} /soc-board.dtb + bootelf -d ${fdt_addr_r} ${loadaddr} ${loadaddr} + +image_addr + Address of the ELF binary. + +fdt_addr + Address of the device-tree. This argument in only needed if bootable + application uses FDT that requires additional setup (like /memory node). + +arg + Any text arguments for bootable application. This is usually the address + of the device-tree. + +Flags: + +-p|-s + Load ELF image via program headers (-p) or via section headers (-s). + +-d + Setup FDT by address. + +Configuration +------------- + +The bootelf command is only available if CONFIG_CMD_ELF=y. FDT setup by flag -d +need CONFIG_CMD_ELF_FDT_SETUP=y.
Maxim Moskalets
