[U-Boot] [PATCH] mtdcore: Fix a build error with CONFIG_CMD_MTDPARTS_SPREAD
This patch fixes the build error for CONFIG_CMD_MTDPARTS_SPREAD introduced by the commit:
commit dfe64e2c89731a3f9950d7acd8681b68df2bae03 Author: Sergey Lapin slapin@ossfans.org Date: Mon Jan 14 03:46:50 2013 +0000
mtd: resync with Linux-3.7.1
Signed-off-by: Maxin B. John maxin.john@enea.com --- drivers/mtd/mtdcore.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 0a38fbe..328a2b9 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -167,7 +167,7 @@ void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset, *truncated = 0; *len_incl_bad = 0;
- if (!mtd->block_isbad) { + if (!mtd->_block_isbad) { *len_incl_bad = length; return; } @@ -183,7 +183,7 @@ void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset,
block_len = mtd->erasesize - (offset & (mtd->erasesize - 1));
- if (!mtd->block_isbad(mtd, offset & ~(mtd->erasesize - 1))) + if (!mtd->_block_isbad(mtd, offset & ~(mtd->erasesize - 1))) len_excl_bad += block_len;
*len_incl_bad += block_len;
Dear Maxin,
Can you please check if this patch is still needed with the updated MTD code posted by Heiko [1] - and if so, rebase your patch against Heiko's code base?
Thanks.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/189358
Dear Wolfgang,
On Mon, Jul 07, 2014 at 02:17:09PM +0200, Wolfgang Denk wrote:
Dear Maxin,
Thanks.
Thank you very much for pointing this out. I have tested Heiko's code available here: repo: git://git.denx.de/u-boot-testing.git branch: update-v3-mtd+ubi-linux-v3.14
The build error that was mentioned in this mail is still valid there:
LD drivers/pcmcia/built-in.o drivers/mtd/mtdcore.c: In function 'mtd_get_len_incl_bad': drivers/mtd/mtdcore.c:805:10: error: 'struct mtd_info' has no member named 'block_isbad' drivers/mtd/mtdcore.c:821:11: error: 'struct mtd_info' has no member named 'block_isbad' CC drivers/rtc/date.o make[1]: *** [drivers/mtd/mtdcore.o] Error 1 make: *** [drivers/mtd] Error 2 make: *** Waiting for unfinished jobs....
Also re-created patch against this. Should I send it as a separate patch or would you suggest another branch for this fix ?
Best regards, Wolfgang Denk
Best Regards, Maxin B. John
Hello John,
Am 07.07.2014 15:17, schrieb Maxin B. John:
Dear Wolfgang,
Dear Maxin,
commit dfe64e2c89731a3f9950d7acd8681b68df2bae03 Author: Sergey Lapinslapin@ossfans.org Date: Mon Jan 14 03:46:50 2013 +0000
Thanks.
Please use the patches posted on the ML, not the branch in u-boot-testing.git for testing. Also you tested with an older version, please use the v5 version:
[U-Boot] [PATCH v5 0/5] mtd, ubi, ubifs: resync with Linux-3.14 http://lists.denx.de/pipermail/u-boot/2014-June/182501.html
Patchwork [U-Boot,v5,1/5] lib, rbtree: resync with Linux-3.14 http://patchwork.ozlabs.org/patch/363332/
Patchwork [U-Boot,v5,2/5] lib, list_sort: add list_sort from linux 3.14 http://patchwork.ozlabs.org/patch/363335/
Patchwork [U-Boot,v5,3/5] linux include: add ERR_CAST http://patchwork.ozlabs.org/patch/363334/
Patchwork [U-Boot,v5,4/5] lib, linux: move linux specific defines to linux/compat.h http://patchwork.ozlabs.org/patch/363333/
Patchwork [U-Boot,v5,5/5] mtd, ubi, ubifs: resync with Linux-3.14 waiting for administrator approval http://patchwork.ozlabs.org/patch/363343/
Looked in the v5 patches, yes it seems, there is the same problem, when enabling CONFIG_CMD_MTDPARTS_SPREAD
Please test against the above patches, and resend your patch, thanks for detecting this!
And if you test my v5 patches, feel free to send a "Tested-by" for them to the ML!
bye, Heiko
Dear Maxin,
Thanks for verifying this.
Please send it as patch against Heiko's code, and mention in the comment section that it requires Heiko's update to be applied first.
Thanks a lot!
Heiko Schocher
Maxin B. John
