[U-Boot] [PATCH] ADS5121 Add mem config for current rev4 boards
The following configurations are now supported:
ads5121_config rev 4.1 boards with Elpida memory
ads5121_rev4m_config rev 4 boards with Micron memory
ads5121_rev3_config rev3 boards which also have Micron memory but have the older rev silicon
Signed-off-by: Martha Marx mmarx@silicontkx.com --- Makefile | 8 ++++++ board/ads5121/ads5121.c | 61 ++++++++++++++++++++++++++++++-------------- include/configs/ads5121.h | 28 ++++++++++++++------ 3 files changed, 68 insertions(+), 29 deletions(-)
diff --git a/Makefile b/Makefile index ee82c5d..b77532c 100644 --- a/Makefile +++ b/Makefile @@ -792,11 +792,19 @@ v38b_config: unconfig
ads5121_config \ ads5121_rev2_config \ +ads5121_rev3_config \ +ads5121_rev4m_config \ : unconfig @mkdir -p $(obj)include @if [ "$(findstring rev2,$@)" ] ; then \ echo "#define CONFIG_ADS5121_REV2 1" > $(obj)include/config.h; \ fi + @if [ "$(findstring rev3,$@)" ] ; then \ + echo "#define CONFIG_ADS5121_REV3 1" > $(obj)include/config.h; \ + fi + @if [ "$(findstring rev4m,$@)" ] ; then \ + echo "#define CONFIG_ADS5121_REV4M 1" > $(obj)include/config.h; \ + fi @$(MKCONFIG) -a ads5121 ppc mpc512x ads5121
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 6c40e94..cb607b4 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -182,29 +182,50 @@ long int fixed_sdram (void)
/* Initialize DDR */ for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; +#if defined(CONFIG_ADS5121_REV2) || \ + defined(CONFIG_ADS5121_REV3) || \ + defined(CONFIG_ADS5121_REV4M) + /* Micron init sequence */ im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM2; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EM3; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_OCD_DEFAULT; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_PCHG_ALL; - im->mddrc.ddr_command = CONFIG_SYS_MICRON_NOP; +#else + /* Elpida init sequence */ + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM3; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EN_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RES_DLL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH; + im->mddrc.ddr_command = CONFIG_SYS_ELPIDA_INIT_DEV_OP; + udelay(200); +#endif + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_DEFAULT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_OCD_EXIT; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + for (i = 0; i < 10; i++) + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP;
/* Start MDDRC */ im->mddrc.ddr_time_config0 = CONFIG_SYS_MDDRC_TIME_CFG0_RUN; diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index 8fda3f2..2e6ceef 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -135,24 +135,34 @@ #define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xE8604A00 #define CONFIG_SYS_MDDRC_TIME_CFG1 0x54EC1168 #define CONFIG_SYS_MDDRC_TIME_CFG2 0x35210864 -#else +#elif defined(CONFIG_ADS5121_REV3) || \ + defined(CONFIG_ADS5121_REV4M) #define CONFIG_SYS_MDDRC_SYS_CFG 0xFA804A00 #define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xEA804A00 #define CONFIG_SYS_MDDRC_TIME_CFG1 0x68EC1168 #define CONFIG_SYS_MDDRC_TIME_CFG2 0x34310864 +#else +#define CONFIG_SYS_MDDRC_SYS_CFG 0xFA802b40 +#define CONFIG_SYS_MDDRC_SYS_CFG_RUN 0xEA802b40 +#define CONFIG_SYS_MDDRC_TIME_CFG1 0x690e1189 +#define CONFIG_SYS_MDDRC_TIME_CFG2 0x35410864 #endif #define CONFIG_SYS_MDDRC_SYS_CFG_EN 0xF0000000 +#define CONFIG_SYS_MDDRC_SYS_CFG_CLK_BIT (1 << 29) +#define CONFIG_SYS_MDDRC_SYS_CFG_CKE_BIT (1 << 30) #define CONFIG_SYS_MDDRC_TIME_CFG0 0x00003D2E #define CONFIG_SYS_MDDRC_TIME_CFG0_RUN 0x06183D2E - -#define CONFIG_SYS_MICRON_NOP 0x01380000 -#define CONFIG_SYS_MICRON_PCHG_ALL 0x01100400 -#define CONFIG_SYS_MICRON_EM2 0x01020000 -#define CONFIG_SYS_MICRON_EM3 0x01030000 -#define CONFIG_SYS_MICRON_EN_DLL 0x01010000 -#define CONFIG_SYS_MICRON_RFSH 0x01080000 #define CONFIG_SYS_MICRON_INIT_DEV_OP 0x01000432 -#define CONFIG_SYS_MICRON_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_ELPIDA_INIT_DEV_OP 0x01000842 +#define CONFIG_SYS_DDR_NOP 0x01380000 +#define CONFIG_SYS_DDR_PCHG_ALL 0x01100400 +#define CONFIG_SYS_DDR_EM2 0x01020000 +#define CONFIG_SYS_DDR_EM3 0x01030000 +#define CONFIG_SYS_DDR_EN_DLL 0x01010000 +#define CONFIG_SYS_DDR_RES_DLL 0x01000932 +#define CONFIG_SYS_DDR_RFSH 0x01080000 +#define CONFIG_SYS_DDR_OCD_DEFAULT 0x01010780 +#define CONFIG_SYS_DDR_OCD_EXIT 0x01010400
/* DDR Priority Manager Configuration */ #define CONFIG_SYS_MDDRCGRP_PM_CFG1 0x00077777
Dear John Rigby,
This shall not be done. All possible memory configurations shall be handled by a single binary image of U-Boot.
It makes little sense to me to add new config options for old boards that are EOL and not distributed any more.
- im->mddrc.ddr_command = CONFIG_SYS_DDR_PCHG_ALL;
- im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP;
- im->mddrc.ddr_command = CONFIG_SYS_DDR_RFSH;
While performing such a global rename, please let's get rid of the CONFIG_SYS_ names. These are NOT options that can be changed by the user in the board config file, so they should not look like such.
If I understand correctly, these are the only real changes to the memory init sequence right? This is virtually invisible in the huge number of variable renames. You should split this into two separate patches, one doing the renames only, and one adding the real new configuration.
But as mentioned above - the key point is that we need to come up with a solution to support all used memory types with a single binary image.
I think such a patch cannot go into mainline (even if the formal issues mentioned above were fixed). Can we please have a solution that avoilds an explosin of differnt, incompatible binary images and config options just for minor board modifications like different memory types?
Thanks.
Wolfgang Denk wrote:
Dear John Rigby,
That would be wonderful but Martha has no idea how to do this. Last I heard STX was unwilling to put a board rev in the cpld.
Martha, I'll leave this to you to work out with Wolfgang.
Thanks.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Tuesday, February 17, 2009 5:58 PM To: John Rigby Cc: u-boot@lists.denx.de; Martha Marx Subject: Re: [U-Boot] [PATCH] ADS5121 Add mem config for current rev4 boards
Dear John Rigby,
CONFIG_SYS_ was in there already for all the memory #defs (as of the global rename in October)
IF you look -- the only rename I did was to change _MICRON_ to _DDR_ and it is very appropriate for it to be in this patch.
See comment above.
The memory change was made due to a supply problem .. all new boards will have the new memory but unfortunately there is no new rev (or CPLD reg setting) for these boards (it is not an unwillingness on my part)
I will attempt to create one binary using Micron settings for rev 4.0 and below, Elpida settings for rev 4.1 and beyond and for the small number of 4.1 Micron boards out there I will attempt to have them run with Elpida settings (the memory will run slightly more slowly) I would like to keep an #ifdef in there to force Micron settings, however.
Thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A committee is a group that keeps the minutes and loses hours.
Dear Martha,
Yes, you are right. But as I mentioned - while performing such a global rename, we should use the opportunity and do it right this time.
But if we change the names anyway, we could correct the other mistake as well, right?
See comment above.
In any case: please split this into two patches: one doing the rename only, and another one adding the new functionality.
I understand this. On the other hand, there might be a new supply problem in N days/weeks/months from now, and we definitely don't want to have an ever growing number of incompatible configurations and binary images if it can be avoided (and I'm sure it can be avoided).
Let's try and find a solution that works with only one binary image, without additional target names and #ifdef's.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Wednesday, February 18, 2009 10:00 AM To: mjmarx Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] ADS5121 Add mem config for current rev4 boards
Dear Martha,
As far as my name change -- I DID NOT DO A WHOLESALE RENAME OF THE MEMORY #defs
The init settings that Elpida and Micron share went from _MICRON_ to _DDR_ The setting they don't share stayed as _MICRON_ and now has a counterpart _ELPIDA_ This name change should not be combined with any other name change and belongs in the memory change patch. In fact it will be especially required if I keep one binary.
Code section with elipses
+#if defined(CONFIG_ADS5121_REV2) || \ + defined(CONFIG_ADS5121_REV3) || \ + defined(CONFIG_ADS5121_REV4M) + /* Micron init sequence */ im->mddrc.ddr_command = CONFIG_SYS_MICRON_INIT_DEV_OP; ... + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; + im->mddrc.ddr_command = CONFIG_SYS_DDR_NOP; ... +#else + /* Elpida init sequence */ + im->mddrc.ddr_command = CONFIG_SYS_DDR_EM2; ... + im->mddrc.ddr_command = CONFIG_SYS_ELPIDA_INIT_DEV_OP; + udelay(200); +#endif
See comment above.
I will very much try my darn'dest!!!!!
-Martha
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Engineering without management is art." - Jeff Johnson
John Rigby
mjmarx
