[PATCH v1] board: toradex: colibri-imx(6ull|imx7): Fix missing fdt_fixup boot error
From: Francesco Dolcini francesco.dolcini@toradex.com
In commit 51aaaf5e7975 ("board: toradex: imx: Remove not needed env variables") the empty definition of fdt_fixup variable was removed, however this was still referenced from the boot command leading to boot failures: ## Error: "fdt_fixup" not defined`
Fix this by removing "run fdt_fixup" from the boot command and instead enable CONFIG_OF_ENV_SETUP in the defconfig that would achieve the same but in a more robust way (it works fine even if the variable is not defined).
Fixes: 51aaaf5e7975 ("board: toradex: imx: Remove not needed env variables") Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- configs/colibri-imx6ull_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + include/configs/colibri-imx6ull.h | 2 +- include/configs/colibri_imx7.h | 2 +- 4 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index fc10d7f66a60..4a0ff029ac75 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 +CONFIG_OF_ENV_SETUP=y CONFIG_BOOTCOMMAND="run ubiboot || run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 16f923b07c22..f2802b10fa8a 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -19,6 +19,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 +CONFIG_OF_ENV_SETUP=y CONFIG_BOOTCOMMAND="run ubiboot ; echo ; echo ubiboot failed ; run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile ${soc}-colibri-${fdt_board}.dtb " diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 7c9d633b68d9..8860ceec1a0a 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -53,7 +53,7 @@ "ubi part ubi &&" \ "ubi read ${kernel_addr_r} kernel && " \ "ubi read ${fdt_addr_r} dtb && " \ - "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \
#if defined(CONFIG_TARGET_COLIBRI_IMX6ULL_NAND) /* Run Distro Boot script if ubiboot fails */ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index c34f1f903df6..33133a0b96e1 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -94,7 +94,7 @@ "ubi part ubi && run m4boot && " \ "ubi read ${kernel_addr_r} kernel && " \ "ubi read ${fdt_addr_r} dtb && " \ - "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \
#if defined(CONFIG_TARGET_COLIBRI_IMX7_NAND) #define MODULE_EXTRA_ENV_SETTINGS \
On Tue, Apr 23, 2024 at 12:57 PM Francesco Dolcini francesco@dolcini.it wrote:
Applied, thanks.
Fabio Estevam
Francesco Dolcini
