[U-Boot] [PATCH 00/14] usb: xhci: Add interrupt transfer support and full speed device support
This adds the missing interrupt transfer support to xHCI driver, so that devices like USB keyboard that uses interrupt transfer when CONFIG_SYS_USB_EVENT_POLL is defined can work.
This also adds full speed device support. Unlike low/high/super speed devices, full speed device may report its endpoint 0 max packet size as 8/16/32/64. xHCI driver guesses 64 for the first attempt to get the initial 8 bytes device descriptor, and later adjusts the context for endpoint 0.
This series also made several updates to xHCI driver to conform with the spec.
This series is available at u-boot-x86/xhci-working for testing.
Bin Meng (14): dm: usb: Fix broken usb_stop() dm: usb: Remove no longer needed blk_unbind_all() usb: xhci: Don't assume LS/FS devices are always behind a HS hub usb: Handle audio extension endpoint descriptor in usb_parse_config() usb: xhci: Add interrupt transfer support usb: Only get 64 bytes device descriptor for full speed devices usb: Read device descriptor after device is addressed for xHCI usb: xhci: Fix max packet size for full speed device endpoint 0 usb: hub: Clear port reset before usb_hub_port_connect_change() usb: hub: Clear BH reset status change for a 3.0 hub usb: xhci: Honor endpoint's interval usb: xhci: Program max burst size for endpoint usb: xhci: Set 'Error Count' to 0 for isoch endpoints usb: xhci: Set 'Average TRB Length' to 8 for control endpoints
common/usb.c | 45 +++++--- common/usb_hub.c | 16 ++- drivers/usb/host/usb-uclass.c | 19 +++- drivers/usb/host/xhci-mem.c | 24 +++- drivers/usb/host/xhci.c | 249 ++++++++++++++++++++++++++++++++++++++++-- drivers/usb/host/xhci.h | 5 +- include/linux/usb/ch9.h | 20 ++++ 7 files changed, 336 insertions(+), 42 deletions(-)
At present we only do device_remove() during usb stop. The DM API device_remove() only marks the device state as inactivated, but still keeps its USB topology (eg: parent, children, etc) in the DM device structure. There is no issue if we only start USB subsystem once and never stop it. But a big issue occurs when we do 'usb stop' and 'usb start' multiple times.
Strange things may be observed with current implementation, like: - the enumeration may report only 1 mass storage device is detected, but the total number of USB devices is correct. - USB keyboard does not work anymore after a bunch of 'usb reset' even if 'usb tree' shows it is correctly identified. - read/write flash drive via 'fatload usb' may complain "Bad device"
In fact, every time when USB host controller starts the enumeration process, it takes random time for each USB port to show up online, hence each USB device may appear in a different order from previous enumeration, and gets assigned to a totally different USB address. As a result, we end up using a stale USB topology in the DM device structure which still reflects the previous enumeration result, and it may create an exact same DM device name like generic_bus_0_dev_7 that is already in the DM device structure. And since the DM device structure is there, there is no device_bind() call to bind driver to the device during current enumeration process, eventually creating an inconsistent software representation of the hardware topology, a non-working USB subsystem.
The fix is to clear the unused USB topology in the usb_stop(), by calling device_unbind() on each controller's root hub device, and the unbinding will unbind all of its children automatically.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/usb/host/usb-uclass.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index bc44fc3..e90614f 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -164,6 +164,7 @@ int usb_get_max_xfer_size(struct usb_device *udev, size_t *size) int usb_stop(void) { struct udevice *bus; + struct udevice *rh; struct uclass *uc; struct usb_uclass_priv *uc_priv; int err = 0, ret; @@ -179,6 +180,18 @@ int usb_stop(void) ret = device_remove(bus, DM_REMOVE_NORMAL); if (ret && !err) err = ret; + + /* Locate root hub device */ + device_find_first_child(bus, &rh); + if (rh) { + /* + * All USB devices are children of root hub. + * Unbinding root hub will unbind all of its children. + */ + ret = device_unbind(rh); + if (ret && !err) + err = ret; + } } #ifdef CONFIG_BLK ret = blk_unbind_all(IF_TYPE_USB);
Reviewed-by: Stefan Roese sr@denx.de Tested-by: Stefan Roese sr@denx.de
Thanks, Stefan
With the root hub unbinding in usb_stop(), there is no need to do a blk uclass specific unbind operation.
drivers/usb/host/usb-uclass.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index e90614f..32c8657 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -193,11 +193,7 @@ int usb_stop(void) err = ret; } } -#ifdef CONFIG_BLK - ret = blk_unbind_all(IF_TYPE_USB); - if (ret && !err) - err = ret; -#endif + #ifdef CONFIG_SANDBOX struct udevice *dev;
- if (ret && !err)
err = ret;
-#endif
- #ifdef CONFIG_SANDBOX struct udevice *dev;
Thanks, Stefan
At present xHCI driver assumes LS/FS devices are attached directly to a HS hub. If they are connected to a LS/FS hub, the driver will fail to perform the USB enumeration process on such devices.
This is fixed by looking from the device itself all the way up to the HS hub where the TT that serves the device is located.
drivers/usb/host/xhci-mem.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/xhci-mem.c b/drivers/usb/host/xhci-mem.c index d5eab3a..84982a9 100644 --- a/drivers/usb/host/xhci-mem.c +++ b/drivers/usb/host/xhci-mem.c @@ -786,12 +786,22 @@ void xhci_setup_addressable_virt_dev(struct xhci_ctrl *ctrl, #ifdef CONFIG_DM_USB /* Set up TT fields to support FS/LS devices */ if (speed == USB_SPEED_LOW || speed == USB_SPEED_FULL) { - dev = dev_get_parent_priv(udev->dev); - if (dev->speed == USB_SPEED_HIGH) { - hub = dev_get_uclass_priv(udev->dev); + struct udevice *parent = udev->dev; + + dev = udev; + do { + port_num = dev->portnr; + dev = dev_get_parent_priv(parent); + if (usb_hub_is_root_hub(dev->dev)) + break; + parent = dev->dev->parent; + } while (dev->speed != USB_SPEED_HIGH); + + if (!usb_hub_is_root_hub(dev->dev)) { + hub = dev_get_uclass_priv(dev->dev); if (hub->tt.multi) slot_ctx->dev_info |= cpu_to_le32(DEV_MTT); - slot_ctx->tt_info |= cpu_to_le32(TT_PORT(udev->portnr)); + slot_ctx->tt_info |= cpu_to_le32(TT_PORT(port_num)); slot_ctx->tt_info |= cpu_to_le32(TT_SLOT(dev->slot_id)); } }
dev = udev;
do {
break;
} }slot_ctx->tt_info |= cpu_to_le32(TT_PORT(port_num)); slot_ctx->tt_info |= cpu_to_le32(TT_SLOT(dev->slot_id));
Thanks, Stefan
Normal endpoint descriptor size is 7, but for audio extension it is 9. Handle that correctly when parsing endpoint descriptor.
common/usb.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/usb.c b/common/usb.c index 0904259..6cb92ef 100644 --- a/common/usb.c +++ b/common/usb.c @@ -437,12 +437,13 @@ static int usb_parse_config(struct usb_device *dev, } break; case USB_DT_ENDPOINT: - if (head->bLength != USB_DT_ENDPOINT_SIZE) { + if (head->bLength != USB_DT_ENDPOINT_SIZE && + head->bLength != USB_DT_ENDPOINT_AUDIO_SIZE) { printf("ERROR: Invalid USB EP length (%d)\n", head->bLength); break; } - if (index + USB_DT_ENDPOINT_SIZE > + if (index + head->bLength > dev->config.desc.wTotalLength) { puts("USB EP descriptor overflowed buffer!\n"); break;
Thanks, Stefan
xHCI uses normal TRBs for both bulk and interrupt. This adds the missing interrupt transfer support to xHCI so that devices like USB keyboard that uses interrupt transfer can work.
drivers/usb/host/xhci.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 04eb1eb..4b3d58d 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -890,11 +890,18 @@ unknown: static int _xhci_submit_int_msg(struct usb_device *udev, unsigned long pipe, void *buffer, int length, int interval) { + if (usb_pipetype(pipe) != PIPE_INTERRUPT) { + printf("non-interrupt pipe (type=%lu)", usb_pipetype(pipe)); + return -EINVAL; + } + /* - * TODO: Not addressing any interrupt type transfer requests - * Add support for it later. + * xHCI uses normal TRBs for both bulk and interrupt. When the + * interrupt endpoint is to be serviced, the xHC will consume + * (at most) one TD. A TD (comprised of sg list entries) can + * take several service intervals to transmit. */ - return -EINVAL; + return xhci_bulk_tx(udev, pipe, length, buffer); }
- if (usb_pipetype(pipe) != PIPE_INTERRUPT) {
return -EINVAL;
*/* take several service intervals to transmit.
- return -EINVAL;
Thanks, Stefan
Full speed device endpoint 0 can have 8/16/32/64 bMaxPacketSize0. Other speed devices report fixed value per USB spec. So it only makes sense if we send a get device descriptor with 64 bytes to full speed devices.
While we are here, update the comment block to be within 80 cols.
common/usb.c | 29 +++++++++++++++-------------- 1 file changed, 15 insertions(+), 14 deletions(-)
diff --git a/common/usb.c b/common/usb.c index 6cb92ef..88cee81 100644 --- a/common/usb.c +++ b/common/usb.c @@ -970,23 +970,24 @@ static int usb_setup_descriptor(struct usb_device *dev, bool do_read) dev->epmaxpacketin[0] = dev->descriptor.bMaxPacketSize0; dev->epmaxpacketout[0] = dev->descriptor.bMaxPacketSize0;
- if (do_read) { + if (do_read && dev->speed == USB_SPEED_FULL) { int err;
/* - * Validate we've received only at least 8 bytes, not that we've - * received the entire descriptor. The reasoning is: - * - The code only uses fields in the first 8 bytes, so that's all we - * need to have fetched at this stage. - * - The smallest maxpacket size is 8 bytes. Before we know the actual - * maxpacket the device uses, the USB controller may only accept a - * single packet. Consequently we are only guaranteed to receive 1 - * packet (at least 8 bytes) even in a non-error case. + * Validate we've received only at least 8 bytes, not that + * we've received the entire descriptor. The reasoning is: + * - The code only uses fields in the first 8 bytes, so + * that's all we need to have fetched at this stage. + * - The smallest maxpacket size is 8 bytes. Before we know + * the actual maxpacket the device uses, the USB controller + * may only accept a single packet. Consequently we are only + * guaranteed to receive 1 packet (at least 8 bytes) even in + * a non-error case. * - * At least the DWC2 controller needs to be programmed with the number - * of packets in addition to the number of bytes. A request for 64 - * bytes of data with the maxpacket guessed as 64 (above) yields a - * request for 1 packet. + * At least the DWC2 controller needs to be programmed with + * the number of packets in addition to the number of bytes. + * A request for 64 bytes of data with the maxpacket guessed + * as 64 (above) yields a request for 1 packet. */ err = get_descriptor_len(dev, 64, 8); if (err) @@ -1009,7 +1010,7 @@ static int usb_setup_descriptor(struct usb_device *dev, bool do_read) dev->maxpacketsize = PACKET_SIZE_64; break; default: - printf("usb_new_device: invalid max packet size\n"); + printf("%s: invalid max packet size\n", __func__); return -EIO; }
- if (do_read) {
* a non-error case.
*/ err = get_descriptor_len(dev, 64, 8); if (err)* as 64 (above) yields a request for 1 packet.
return -EIO; }printf("%s: invalid max packet size\n", __func__);
Thanks, Stefan
For xHCI it is not possible to read a device descriptor before it has been assigned an address. That's why usb_setup_descriptor() was called with 'do_read' being false. But we really need try to read the device descriptor before starting any real communication with the default control endpoint.
common/usb.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/common/usb.c b/common/usb.c index 88cee81..8d27bc7 100644 --- a/common/usb.c +++ b/common/usb.c @@ -1052,6 +1052,17 @@ static int usb_prepare_device(struct usb_device *dev, int addr, bool do_read,
mdelay(10); /* Let the SET_ADDRESS settle */
+ /* + * If we haven't read device descriptor before, read it here + * after device is assigned an address. This is only applicable + * to xHCI so far. + */ + if (!do_read) { + err = usb_setup_descriptor(dev, true); + if (err) + return err; + } + return 0; }
* to xHCI so far.
- if (!do_read) {
if (err)
return err;
- return 0; }
Thanks, Stefan
In xhci_check_maxpacket(), the control endpoint 0 max packet size is wrongly taken from the interface's endpoint descriptor. However the default endpoint 0 does not come with an endpoint descriptor hence is not included in the interface structure. Change to use epmaxpacketin[0] instead.
The other bug in this routine is that when setting max packet size to the xHC endpoint 0 context, it does not clear its previous value at all before programming a new one.
drivers/usb/host/xhci.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 4b3d58d..ec82fa6 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -546,16 +546,13 @@ int xhci_check_maxpacket(struct usb_device *udev) int max_packet_size; int hw_max_packet_size; int ret = 0; - struct usb_interface *ifdesc; - - ifdesc = &udev->config.if_desc[0];
out_ctx = ctrl->devs[slot_id]->out_ctx; xhci_inval_cache((uintptr_t)out_ctx->bytes, out_ctx->size);
ep_ctx = xhci_get_ep_ctx(ctrl, out_ctx, ep_index); hw_max_packet_size = MAX_PACKET_DECODED(le32_to_cpu(ep_ctx->ep_info2)); - max_packet_size = usb_endpoint_maxp(&ifdesc->ep_desc[0]); + max_packet_size = udev->epmaxpacketin[0]; if (hw_max_packet_size != max_packet_size) { debug("Max Packet Size for ep 0 changed.\n"); debug("Max packet size in usb_device = %d\n", max_packet_size); @@ -567,7 +564,8 @@ int xhci_check_maxpacket(struct usb_device *udev) ctrl->devs[slot_id]->out_ctx, ep_index); in_ctx = ctrl->devs[slot_id]->in_ctx; ep_ctx = xhci_get_ep_ctx(ctrl, in_ctx, ep_index); - ep_ctx->ep_info2 &= cpu_to_le32(~MAX_PACKET_MASK); + ep_ctx->ep_info2 &= cpu_to_le32(~((0xffff & MAX_PACKET_MASK) + << MAX_PACKET_SHIFT)); ep_ctx->ep_info2 |= cpu_to_le32(MAX_PACKET(max_packet_size));
- max_packet_size = udev->epmaxpacketin[0]; if (hw_max_packet_size != max_packet_size) { debug("Max Packet Size for ep 0 changed.\n"); debug("Max packet size in usb_device = %d\n", max_packet_size);
Thanks, Stefan
During usb_hub_port_connect_change(), a port reset set feature request is issued to the port, and later a port reset clear feature is done to the same port before the function returns. However at the end of usb_scan_port(), we attempt to clear port reset again on a cached port status change variable, which should not be done.
Adjust the call to clear port reset to right before the call to usb_hub_port_connect_change().
common/usb_hub.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 86a3477..a9d21bc 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -489,6 +489,11 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) return 0; }
+ if (portchange & USB_PORT_STAT_C_RESET) { + debug("port %d reset change\n", i + 1); + usb_clear_port_feature(dev, i + 1, USB_PORT_FEAT_C_RESET); + } + /* A new USB device is ready at this point */ debug("devnum=%d port=%d: USB dev found\n", dev->devnum, i + 1);
@@ -543,11 +548,6 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) hub->overcurrent_count[i]); }
- if (portchange & USB_PORT_STAT_C_RESET) { - debug("port %d reset change\n", i + 1); - usb_clear_port_feature(dev, i + 1, USB_PORT_FEAT_C_RESET); - } - /* * We're done with this device, so let's remove this device from * scanning list
- /* A new USB device is ready at this point */ debug("devnum=%d port=%d: USB dev found\n", dev->devnum, i + 1);
- We're done with this device, so let's remove this device from
- scanning list
Thanks, Stefan
USB 3.0 hubs report bit[5] in the port status change response as BH reset. The hub shall set the C_BH_PORT_RESET field for this port.
common/usb_hub.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/common/usb_hub.c b/common/usb_hub.c index a9d21bc..325d16d 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -494,6 +494,12 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) usb_clear_port_feature(dev, i + 1, USB_PORT_FEAT_C_RESET); }
+ if ((portchange & USB_SS_PORT_STAT_C_BH_RESET) && + usb_hub_is_superspeed(dev)) { + debug("port %d BH reset change\n", i + 1); + usb_clear_port_feature(dev, i + 1, USB_SS_PORT_FEAT_C_BH_RESET); + } + /* A new USB device is ready at this point */ debug("devnum=%d port=%d: USB dev found\n", dev->devnum, i + 1);
- if ((portchange & USB_SS_PORT_STAT_C_BH_RESET) &&
Thanks, Stefan
USB endpoint reports the period between consecutive requests to send or receive data as bInverval in its endpoint descriptor. So far this is ignored by xHCI driver and the 'Interval' field in xHC's endpoint context is always programmed to zero which means 1ms for low speed or full speed , or 125us for high speed or super speed. We should honor the interval by getting it from endpoint descriptor.
drivers/usb/host/xhci.c | 195 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/host/xhci.h | 5 +- include/linux/usb/ch9.h | 20 +++++ 3 files changed, 218 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index ec82fa6..8aed428 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -257,6 +257,172 @@ static unsigned int xhci_get_ep_index(struct usb_endpoint_descriptor *desc) return index; }
+/* + * Convert bInterval expressed in microframes (in 1-255 range) to exponent of + * microframes, rounded down to nearest power of 2. + */ +static unsigned int xhci_microframes_to_exponent(unsigned int desc_interval, + unsigned int min_exponent, + unsigned int max_exponent) +{ + unsigned int interval; + + interval = fls(desc_interval) - 1; + interval = clamp_val(interval, min_exponent, max_exponent); + if ((1 << interval) != desc_interval) + debug("rounding interval to %d microframes, "\ + "ep desc says %d microframes\n", + 1 << interval, desc_interval); + + return interval; +} + +static unsigned int xhci_parse_microframe_interval(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc) +{ + if (endpt_desc->bInterval == 0) + return 0; + + return xhci_microframes_to_exponent(endpt_desc->bInterval, 0, 15); +} + +static unsigned int xhci_parse_frame_interval(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc) +{ + return xhci_microframes_to_exponent(endpt_desc->bInterval * 8, 3, 10); +} + +/* + * Convert interval expressed as 2^(bInterval - 1) == interval into + * straight exponent value 2^n == interval. + */ +static unsigned int xhci_parse_exponent_interval(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc) +{ + unsigned int interval; + + interval = clamp_val(endpt_desc->bInterval, 1, 16) - 1; + if (interval != endpt_desc->bInterval - 1) + debug("ep %#x - rounding interval to %d %sframes\n", + endpt_desc->bEndpointAddress, 1 << interval, + udev->speed == USB_SPEED_FULL ? "" : "micro"); + + if (udev->speed == USB_SPEED_FULL) { + /* + * Full speed isoc endpoints specify interval in frames, + * not microframes. We are using microframes everywhere, + * so adjust accordingly. + */ + interval += 3; /* 1 frame = 2^3 uframes */ + } + + return interval; +} + +/* + * Return the polling or NAK interval. + * + * The polling interval is expressed in "microframes". If xHCI's Interval field + * is set to N, it will service the endpoint every 2^(Interval)*125us. + * + * The NAK interval is one NAK per 1 to 255 microframes, or no NAKs if interval + * is set to 0. + */ +static unsigned int xhci_get_endpoint_interval(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc) +{ + unsigned int interval = 0; + + switch (udev->speed) { + case USB_SPEED_HIGH: + /* Max NAK rate */ + if (usb_endpoint_xfer_control(endpt_desc) || + usb_endpoint_xfer_bulk(endpt_desc)) { + interval = xhci_parse_microframe_interval(udev, + endpt_desc); + break; + } + /* Fall through - SS and HS isoc/int have same decoding */ + + case USB_SPEED_SUPER: + if (usb_endpoint_xfer_int(endpt_desc) || + usb_endpoint_xfer_isoc(endpt_desc)) { + interval = xhci_parse_exponent_interval(udev, + endpt_desc); + } + break; + + case USB_SPEED_FULL: + if (usb_endpoint_xfer_isoc(endpt_desc)) { + interval = xhci_parse_exponent_interval(udev, + endpt_desc); + break; + } + /* + * Fall through for interrupt endpoint interval decoding + * since it uses the same rules as low speed interrupt + * endpoints. + */ + + case USB_SPEED_LOW: + if (usb_endpoint_xfer_int(endpt_desc) || + usb_endpoint_xfer_isoc(endpt_desc)) { + interval = xhci_parse_frame_interval(udev, endpt_desc); + } + break; + + default: + BUG(); + } + + return interval; +} + +/* + * The "Mult" field in the endpoint context is only set for SuperSpeed isoc eps. + * High speed endpoint descriptors can define "the number of additional + * transaction opportunities per microframe", but that goes in the Max Burst + * endpoint context field. + */ +static u32 xhci_get_endpoint_mult(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc, + struct usb_ss_ep_comp_descriptor *ss_ep_comp_desc) +{ + if (udev->speed < USB_SPEED_SUPER || + !usb_endpoint_xfer_isoc(endpt_desc)) + return 0; + + return ss_ep_comp_desc->bmAttributes; +} + +/* + * Return the maximum endpoint service interval time (ESIT) payload. + * Basically, this is the maxpacket size, multiplied by the burst size + * and mult size. + */ +static u32 xhci_get_max_esit_payload(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc, + struct usb_ss_ep_comp_descriptor *ss_ep_comp_desc) +{ + int max_burst; + int max_packet; + + /* Only applies for interrupt or isochronous endpoints */ + if (usb_endpoint_xfer_control(endpt_desc) || + usb_endpoint_xfer_bulk(endpt_desc)) + return 0; + + /* SuperSpeed Isoc ep with less than 48k per esit */ + if (udev->speed >= USB_SPEED_SUPER) + return le16_to_cpu(ss_ep_comp_desc->wBytesPerInterval); + + max_packet = usb_endpoint_maxp(endpt_desc); + max_burst = usb_endpoint_maxp_mult(endpt_desc); + + /* A 0 in max burst means 1 transfer per ESIT */ + return max_packet * max_burst; +} + /** * Issue a configure endpoint command or evaluate context command * and wait for it to finish. @@ -324,6 +490,10 @@ static int xhci_set_configuration(struct usb_device *udev) int slot_id = udev->slot_id; struct xhci_virt_device *virt_dev = ctrl->devs[slot_id]; struct usb_interface *ifdesc; + u32 max_esit_payload; + unsigned int interval; + unsigned int mult; + unsigned int avg_trb_len;
out_ctx = virt_dev->out_ctx; in_ctx = virt_dev->in_ctx; @@ -357,10 +527,26 @@ static int xhci_set_configuration(struct usb_device *udev) /* filling up ep contexts */ for (cur_ep = 0; cur_ep < num_of_ep; cur_ep++) { struct usb_endpoint_descriptor *endpt_desc = NULL; + struct usb_ss_ep_comp_descriptor *ss_ep_comp_desc = NULL;
endpt_desc = &ifdesc->ep_desc[cur_ep]; + ss_ep_comp_desc = &ifdesc->ss_ep_comp_desc[cur_ep]; trb_64 = 0;
+ /* + * Get values to fill the endpoint context, mostly from ep + * descriptor. The average TRB buffer lengt for bulk endpoints + * is unclear as we have no clue on scatter gather list entry + * size. For Isoc and Int, set it to max available. + * See xHCI 1.1 spec 4.14.1.1 for details. + */ + max_esit_payload = xhci_get_max_esit_payload(udev, endpt_desc, + ss_ep_comp_desc); + interval = xhci_get_endpoint_interval(udev, endpt_desc); + mult = xhci_get_endpoint_mult(udev, endpt_desc, + ss_ep_comp_desc); + avg_trb_len = max_esit_payload; + ep_index = xhci_get_ep_index(endpt_desc); ep_ctx[ep_index] = xhci_get_ep_ctx(ctrl, in_ctx, ep_index);
@@ -372,6 +558,11 @@ static int xhci_set_configuration(struct usb_device *udev) /*NOTE: ep_desc[0] actually represents EP1 and so on */ dir = (((endpt_desc->bEndpointAddress) & (0x80)) >> 7); ep_type = (((endpt_desc->bmAttributes) & (0x3)) | (dir << 2)); + + ep_ctx[ep_index]->ep_info = + cpu_to_le32(EP_MAX_ESIT_PAYLOAD_HI(max_esit_payload) | + EP_INTERVAL(interval) | EP_MULT(mult)); + ep_ctx[ep_index]->ep_info2 = cpu_to_le32(ep_type << EP_TYPE_SHIFT); ep_ctx[ep_index]->ep_info2 |= @@ -386,6 +577,10 @@ static int xhci_set_configuration(struct usb_device *udev) virt_dev->eps[ep_index].ring->enqueue; ep_ctx[ep_index]->deq = cpu_to_le64(trb_64 | virt_dev->eps[ep_index].ring->cycle_state); + + ep_ctx[ep_index]->tx_info = + cpu_to_le32(EP_MAX_ESIT_PAYLOAD_LO(max_esit_payload) | + EP_AVG_TRB_LENGTH(avg_trb_len)); }
return xhci_configure_endpoints(udev, false); diff --git a/drivers/usb/host/xhci.h b/drivers/usb/host/xhci.h index a497d9d..6deefbf 100644 --- a/drivers/usb/host/xhci.h +++ b/drivers/usb/host/xhci.h @@ -663,8 +663,9 @@ struct xhci_ep_ctx { #define GET_MAX_PACKET(p) ((p) & 0x7ff)
/* tx_info bitmasks */ -#define AVG_TRB_LENGTH_FOR_EP(p) ((p) & 0xffff) -#define MAX_ESIT_PAYLOAD_FOR_EP(p) (((p) & 0xffff) << 16) +#define EP_AVG_TRB_LENGTH(p) ((p) & 0xffff) +#define EP_MAX_ESIT_PAYLOAD_LO(p) (((p) & 0xffff) << 16) +#define EP_MAX_ESIT_PAYLOAD_HI(p) ((((p) >> 16) & 0xff) << 24) #define CTX_TO_MAX_ESIT_PAYLOAD(p) (((p) >> 16) & 0xffff)
/* deq bitmasks */ diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h index 0ad4782..264c971 100644 --- a/include/linux/usb/ch9.h +++ b/include/linux/usb/ch9.h @@ -418,6 +418,12 @@ struct __packed usb_class_report_descriptor { #define USB_ENDPOINT_XFER_INT 3 #define USB_ENDPOINT_MAX_ADJUSTABLE 0x80
+#define USB_ENDPOINT_MAXP_MASK 0x07ff +#define USB_EP_MAXP_MULT_SHIFT 11 +#define USB_EP_MAXP_MULT_MASK (3 << USB_EP_MAXP_MULT_SHIFT) +#define USB_EP_MAXP_MULT(m) \ + (((m) & USB_EP_MAXP_MULT_MASK) >> USB_EP_MAXP_MULT_SHIFT) + /* The USB 3.0 spec redefines bits 5:4 of bmAttributes as interrupt ep type. */ #define USB_ENDPOINT_INTRTYPE 0x30 #define USB_ENDPOINT_INTR_PERIODIC (0 << 4) @@ -625,6 +631,20 @@ static inline int usb_endpoint_maxp(const struct usb_endpoint_descriptor *epd) return __le16_to_cpu(get_unaligned(&epd->wMaxPacketSize)); }
+/** + * usb_endpoint_maxp_mult - get endpoint's transactional opportunities + * @epd: endpoint to be checked + * + * Return @epd's wMaxPacketSize[12:11] + 1 + */ +static inline int +usb_endpoint_maxp_mult(const struct usb_endpoint_descriptor *epd) +{ + int maxp = __le16_to_cpu(epd->wMaxPacketSize); + + return USB_EP_MAXP_MULT(maxp) + 1; +} + static inline int usb_endpoint_interrupt_type( const struct usb_endpoint_descriptor *epd) {
- Convert bInterval expressed in microframes (in 1-255 range) to exponent of
- microframes, rounded down to nearest power of 2.
- unsigned int interval;
- interval = fls(desc_interval) - 1;
- interval = clamp_val(interval, min_exponent, max_exponent);
- if ((1 << interval) != desc_interval)
- return interval;
- struct usb_endpoint_descriptor *endpt_desc)
- if (endpt_desc->bInterval == 0)
- return xhci_microframes_to_exponent(endpt_desc->bInterval, 0, 15);
- return xhci_microframes_to_exponent(endpt_desc->bInterval * 8, 3, 10);
- Convert interval expressed as 2^(bInterval - 1) == interval into
- straight exponent value 2^n == interval.
- interval = clamp_val(endpt_desc->bInterval, 1, 16) - 1;
- if (interval != endpt_desc->bInterval - 1)
- if (udev->speed == USB_SPEED_FULL) {
- return interval;
- Return the polling or NAK interval.
- The polling interval is expressed in "microframes". If xHCI's Interval field
- is set to N, it will service the endpoint every 2^(Interval)*125us.
- The NAK interval is one NAK per 1 to 255 microframes, or no NAKs if interval
- is set to 0.
- unsigned int interval = 0;
- switch (udev->speed) {
- case USB_SPEED_HIGH:
/* Max NAK rate */
endpt_desc);
break;
- case USB_SPEED_SUPER:
endpt_desc);
break;
- case USB_SPEED_FULL:
endpt_desc);
break;
* endpoints.
- case USB_SPEED_LOW:
break;
- default:
BUG();
- return interval;
- The "Mult" field in the endpoint context is only set for SuperSpeed isoc eps.
- High speed endpoint descriptors can define "the number of additional
- transaction opportunities per microframe", but that goes in the Max Burst
- endpoint context field.
- struct usb_endpoint_descriptor *endpt_desc,
- struct usb_ss_ep_comp_descriptor *ss_ep_comp_desc)
- if (udev->speed < USB_SPEED_SUPER ||
- return ss_ep_comp_desc->bmAttributes;
- Return the maximum endpoint service interval time (ESIT) payload.
- Basically, this is the maxpacket size, multiplied by the burst size
- and mult size.
- int max_burst;
- int max_packet;
- /* Only applies for interrupt or isochronous endpoints */
- if (usb_endpoint_xfer_control(endpt_desc) ||
- /* SuperSpeed Isoc ep with less than 48k per esit */
- if (udev->speed >= USB_SPEED_SUPER)
- max_packet = usb_endpoint_maxp(endpt_desc);
- max_burst = usb_endpoint_maxp_mult(endpt_desc);
- /* A 0 in max burst means 1 transfer per ESIT */
- return max_packet * max_burst;
- Issue a configure endpoint command or evaluate context command
- and wait for it to finish.
unsigned int mult;
trb_64 = 0;
ss_ep_comp_desc);
ss_ep_comp_desc);
- ep_ctx[ep_index]->ep_info2 = cpu_to_le32(ep_type << EP_TYPE_SHIFT); ep_ctx[ep_index]->ep_info2 |=
- (((m) & USB_EP_MAXP_MULT_MASK) >> USB_EP_MAXP_MULT_SHIFT)
- /* The USB 3.0 spec redefines bits 5:4 of bmAttributes as interrupt ep type. */ #define USB_ENDPOINT_INTRTYPE 0x30 #define USB_ENDPOINT_INTR_PERIODIC (0 << 4)
- usb_endpoint_maxp_mult - get endpoint's transactional opportunities
- @epd: endpoint to be checked
- Return @epd's wMaxPacketSize[12:11] + 1
- int maxp = __le16_to_cpu(epd->wMaxPacketSize);
- return USB_EP_MAXP_MULT(maxp) + 1;
- static inline int usb_endpoint_interrupt_type( const struct usb_endpoint_descriptor *epd) {
Thanks, Stefan
The 'Max Burst Size' indicates to the xHC the maximum number of consecutive USB transactions that should be executed per scheduling opportunity. This is a “zero-based” value, where 0 to 15 represents burst sizes of 1 to 16, but at present this is always set to zero. Let's program the required value according to real needs.
drivers/usb/host/xhci.c | 21 ++++++++++++++++++++- 1 file changed, 20 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 8aed428..dfb188d 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -395,6 +395,22 @@ static u32 xhci_get_endpoint_mult(struct usb_device *udev, return ss_ep_comp_desc->bmAttributes; }
+static u32 xhci_get_endpoint_max_burst(struct usb_device *udev, + struct usb_endpoint_descriptor *endpt_desc, + struct usb_ss_ep_comp_descriptor *ss_ep_comp_desc) +{ + /* Super speed and Plus have max burst in ep companion desc */ + if (udev->speed >= USB_SPEED_SUPER) + return ss_ep_comp_desc->bMaxBurst; + + if (udev->speed == USB_SPEED_HIGH && + (usb_endpoint_xfer_isoc(endpt_desc) || + usb_endpoint_xfer_int(endpt_desc))) + return usb_endpoint_maxp_mult(endpt_desc) - 1; + + return 0; +} + /* * Return the maximum endpoint service interval time (ESIT) payload. * Basically, this is the maxpacket size, multiplied by the burst size @@ -493,6 +509,7 @@ static int xhci_set_configuration(struct usb_device *udev) u32 max_esit_payload; unsigned int interval; unsigned int mult; + unsigned int max_burst; unsigned int avg_trb_len;
out_ctx = virt_dev->out_ctx; @@ -545,6 +562,8 @@ static int xhci_set_configuration(struct usb_device *udev) interval = xhci_get_endpoint_interval(udev, endpt_desc); mult = xhci_get_endpoint_mult(udev, endpt_desc, ss_ep_comp_desc); + max_burst = xhci_get_endpoint_max_burst(udev, endpt_desc, + ss_ep_comp_desc); avg_trb_len = max_esit_payload;
ep_index = xhci_get_ep_index(endpt_desc); @@ -570,7 +589,7 @@ static int xhci_set_configuration(struct usb_device *udev) (get_unaligned(&endpt_desc->wMaxPacketSize)));
ep_ctx[ep_index]->ep_info2 |= - cpu_to_le32(((0 & MAX_BURST_MASK) << MAX_BURST_SHIFT) | + cpu_to_le32(MAX_BURST(max_burst) | ((3 & ERROR_COUNT_MASK) << ERROR_COUNT_SHIFT));
trb_64 = (uintptr_t)
- /* Super speed and Plus have max burst in ep companion desc */
- if (udev->speed == USB_SPEED_HIGH &&
ss_ep_comp_desc);
Thanks, Stefan
Per xHCI spec, 'Error Count' should be set to 0 for isoch endpoints.
drivers/usb/host/xhci.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index dfb188d..93737b0 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -511,6 +511,7 @@ static int xhci_set_configuration(struct usb_device *udev) unsigned int mult; unsigned int max_burst; unsigned int avg_trb_len; + unsigned int err_count = 0;
out_ctx = virt_dev->out_ctx; in_ctx = virt_dev->in_ctx; @@ -588,9 +589,12 @@ static int xhci_set_configuration(struct usb_device *udev) cpu_to_le32(MAX_PACKET (get_unaligned(&endpt_desc->wMaxPacketSize)));
+ /* Allow 3 retries for everything but isoc, set CErr = 3 */ + if (!usb_endpoint_xfer_isoc(endpt_desc)) + err_count = 3; ep_ctx[ep_index]->ep_info2 |= cpu_to_le32(MAX_BURST(max_burst) | - ((3 & ERROR_COUNT_MASK) << ERROR_COUNT_SHIFT)); + ERROR_COUNT(err_count));
trb_64 = (uintptr_t) virt_dev->eps[ep_index].ring->enqueue;
ep_ctx[ep_index]->ep_info2 |= cpu_to_le32(MAX_BURST(max_burst) |err_count = 3;
Thanks, Stefan
Update the codes to conform with xHCI spec chapter 6.2.3.
drivers/usb/host/xhci-mem.c | 6 ++++++ drivers/usb/host/xhci.c | 6 ++++++ 2 files changed, 12 insertions(+)
diff --git a/drivers/usb/host/xhci-mem.c b/drivers/usb/host/xhci-mem.c index 84982a9..0582a9b 100644 --- a/drivers/usb/host/xhci-mem.c +++ b/drivers/usb/host/xhci-mem.c @@ -850,6 +850,12 @@ void xhci_setup_addressable_virt_dev(struct xhci_ctrl *ctrl, trb_64 = (uintptr_t)virt_dev->eps[0].ring->first_seg->trbs; ep0_ctx->deq = cpu_to_le64(trb_64 | virt_dev->eps[0].ring->cycle_state);
+ /* + * xHCI spec 6.2.3: + * software shall set 'Average TRB Length' to 8 for control endpoints. + */ + ep0_ctx->tx_info = cpu_to_le32(EP_AVG_TRB_LENGTH(8)); + /* Steps 7 and 8 were done in xhci_alloc_virt_device() */
xhci_flush_cache((uintptr_t)ep0_ctx, sizeof(struct xhci_ep_ctx)); diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 93737b0..4673738 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -601,6 +601,12 @@ static int xhci_set_configuration(struct usb_device *udev) ep_ctx[ep_index]->deq = cpu_to_le64(trb_64 | virt_dev->eps[ep_index].ring->cycle_state);
+ /* + * xHCI spec 6.2.3: + * 'Average TRB Length' should be 8 for control endpoints. + */ + if (usb_endpoint_xfer_control(endpt_desc)) + avg_trb_len = 8; ep_ctx[ep_index]->tx_info = cpu_to_le32(EP_MAX_ESIT_PAYLOAD_LO(max_esit_payload) | EP_AVG_TRB_LENGTH(avg_trb_len));
* xHCI spec 6.2.3:
* xHCI spec 6.2.3:
ep_ctx[ep_index]->tx_info = cpu_to_le32(EP_MAX_ESIT_PAYLOAD_LO(max_esit_payload) | EP_AVG_TRB_LENGTH(avg_trb_len));avg_trb_len = 8;
Thanks, Stefan
Looks good to me. Stefan, can you please give A-B/R-B on the series ? I'd like to pick it for 2017.09 :)
That would be 2017.11, right?
Sure, I'll review and test this series most likely tomorrow.
Thanks, Stefan
Yes :)
Thanks
Thanks, Stefan
Hi Bin,
I did a quick test and most really looks very good. Thanks for all this great work on this xHCI stuff.
BUT, issuing a few commands, I was able to hang my board. This sequence is reproducible on my board:
U-Boot 2017.09-00246-g28758a2992 (Sep 18 2017 - 17:29:52 +0200)
CPU: x86_64, vendor Intel, device 30679h DRAM: 4 GiB MMC: pci_mmc: 0, pci_mmc: 1, pci_mmc: 2 SF: Detected w25q64cv with page size 256 Bytes, erase size 4 KiB, total 8 MiB Model: theadorable-x86-DFI-BT700 Net: No ethernet found. scanning bus for devices... Target spinup took 0 ms. SATA link 1 timeout. AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x3 impl SATA mode flags: 64bit ncq stag pm led clo pio slum part sxs Device 0: (0:0) Vendor: ATA Prod.: SanDisk Ultra II Rev: X411 Type: Hard Disk Capacity: 457862.8 MB = 447.1 GB (937703088 x 512) 960138 bytes read in 72 ms (12.7 MiB/s) Video: 800x600x16 Hit any key to stop autoboot: 0 => => => usb reset resetting USB... USB0: Register 7000820 NbrPorts 7 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... cannot reset port 1!? 7 USB Device(s) found scanning usb for storage devices... 2 Storage Device(s) found => usb tree USB device tree: 1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | | | +-5 Hub (12 Mb/s, 100mA) | +-3 Hub (480 Mb/s, 2mA) | | | +-6 Mass Storage (480 Mb/s, 98mA) | | USBest Technology USB Mass Storage Device 09092207fbf0c4 | | | +-7 Mass Storage (480 Mb/s, 500mA) | General USB Flash Disk 000000000000034B | +-4 Vendor specific (5 Gb/s, 64mA) Realtek USB 10/100/1000 LAN 000002000000
=> ls usb 1 System Volume Information/ 16779264 PRIME-B350-PLUS-ASUS-0613.CAP 16779264 PRIME-B350-PLUS-ASUS-0805.CAP
3 file(s), 1 dir(s)
=> usb tree USB device tree: 1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Hub (480 Mb/s, 100mA) | | | +-5 Hub (12 Mb/s, 100mA) | +-3 Hub (480 Mb/s, 2mA) | | | +-6 Mass Storage (480 Mb/s, 98mA) | | USBest Technology USB Mass Storage Device 09092207fbf0c4 | | | +-7 Mass Storage (480 Mb/s, 500mA) | | General USB Flash Disk 000000000000034B | | | |General Protection EIP: 0010:[<7b56f724>] EFLAGS: 00010246 Original EIP :[<fff1e724>] EAX: 7b33ac18 EBX: 00000000 ECX: ffffffbf EDX: 7b33ac18 ESI: 7b33ad30 EDI: 00000006 EBP: 7b37b188 ESP: 7b33ac08 DS: 0018 ES: 0018 FS: 0020 GS: 0018 SS: 0018 CR0: 00000033 CR2: 00000000 CR3: 00000000 CR4: 00000600 DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff0ff0 DR7: 00000400 Stack: 0x7b33ac48 : 0x7b37b160 0x7b33ac44 : 0x00000000 0x7b33ac40 : 0x00000000 0x7b33ac3c : 0x00000000 0x7b33ac38 : 0x00000000 0x7b33ac34 : 0x20202020 0x7b33ac30 : 0x52474d54 0x7b33ac2c : 0x7b37baa8 0x7b33ac28 : 0x7b37baa8 0x7b33ac24 : 0x7b33ad30 0x7b33ac20 : 0x7b5aa84e 0x7b33ac1c : 0x7b55f008 0x7b33ac18 : 0xffffffbf 0x7b33ac14 : 0xcc0a06e4 0x7b33ac10 : 0xc0e88a40 0x7b33ac0c : 0x568ad686 --->0x7b33ac08 : 0x7b56f776 0x7b33ac04 : 0x00010246 0x7b33ac00 : 0x00000010 0x7b33abfc : 0x7b56f724 ### ERROR ### Please RESET the board ###
Are you able to reproduce this on your board(s) as well? Any ideas on this? Please let me know if I can do any further tests.
Thanks, Stefan
Hi Stefan,
On Mon, Sep 18, 2017 at 11:38 PM, Stefan Roese sr@denx.de wrote:
Hi Bin,
3 file(s), 1 dir(s)
This is an known issue of 'usb info' and 'usb tree' command. See previous patch on ML @ http://patchwork.ozlabs.org/patch/810732/. However, that patch has serious issues and needs rework. I can rework that patch and include it as part of v2 if you like.
Regards, Bin
Hi Bin,
Hi Bin,
3 file(s), 1 dir(s)
Ah, thanks. I had noticed this patch but was not aware of the severity here.
I've tested with the v2 and it seems to work just fine now.
Thanks, Stefan
Hi Stefan,
On Tue, Sep 19, 2017 at 12:54 PM, Stefan Roese sr@denx.de wrote:
Hi Bin,
Hi Bin,
3 file(s), 1 dir(s)
Yep, I posted some comments to that v2 patch.
For this xHCI series, I've moved the patch state back to "New".
Regards, Bin
Bin Meng
Stefan Roese
