[U-Boot] [PATCH V2 1/2] imx: mx6: add more entry for mxc_ccm_reg
Add more entries for structure mxc_ccm_reg.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Eric Nelson eric@nelint.com Cc: Stefano Babic sbabic@denx.de ---
Changes V2: Address Eric'c comments. Add Comments and rename registers from PMU with prefix pmu.
arch/arm/include/asm/arch-mx6/crm_regs.h | 91 ++++++++++++++++++++++++++++++++ 1 file changed, 91 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 13e0a3d..f6ec09d 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -103,6 +103,97 @@ struct mxc_ccm_reg { u32 analog_pfd_528_set; u32 analog_pfd_528_clr; u32 analog_pfd_528_tog; + /* PMU Memory Map/Register Definition */ + u32 pmu_reg_1p1; + u32 pmu_reg_1p1_set; + u32 pmu_reg_1p1_clr; + u32 pmu_reg_1p1_tog; + u32 pmu_reg_3p0; + u32 pmu_reg_3p0_set; + u32 pmu_reg_3p0_clr; + u32 pmu_reg_3p0_tog; + u32 pmu_reg_2p5; + u32 pmu_reg_2p5_set; + u32 pmu_reg_2p5_clr; + u32 pmu_reg_2p5_tog; + u32 pmu_reg_core; + u32 pmu_reg_core_set; + u32 pmu_reg_core_clr; + u32 pmu_reg_core_tog; + u32 pmu_misc0; + u32 pmu_misc0_set; + u32 pmu_misc0_clr; + u32 pmu_misc0_tog; + u32 pmu_misc1; + u32 pmu_misc1_set; + u32 pmu_misc1_clr; + u32 pmu_misc1_tog; + u32 pmu_misc2; + u32 pmu_misc2_set; + u32 pmu_misc2_clr; + u32 pmu_misc2_tog; + /* TEMPMON Memory Map/Register Definition */ + u32 tempsense0; + u32 tempsense0_set; + u32 tempsense0_clr; + u32 tempsense0_tog; + u32 tempsense1; + u32 tempsense1_set; + u32 tempsense1_clr; + u32 tempsense1_tog; + /* USB Analog Memory Map/Register Definition */ + u32 usb1_vbus_detect; + u32 usb1_vbus_detect_set; + u32 usb1_vbus_detect_clr; + u32 usb1_vbus_detect_tog; + u32 usb1_chrg_detect; + u32 usb1_chrg_detect_set; + u32 usb1_chrg_detect_clr; + u32 usb1_chrg_detect_tog; + u32 usb1_vbus_det_stat; + u32 usb1_vbus_det_stat_set; + u32 usb1_vbus_det_stat_clr; + u32 usb1_vbus_det_stat_tog; + u32 usb1_chrg_det_stat; + u32 usb1_chrg_det_stat_set; + u32 usb1_chrg_det_stat_clr; + u32 usb1_chrg_det_stat_tog; + u32 usb1_loopback; + u32 usb1_loopback_set; + u32 usb1_loopback_clr; + u32 usb1_loopback_tog; + u32 usb1_misc; + u32 usb1_misc_set; + u32 usb1_misc_clr; + u32 usb1_misc_tog; + u32 usb2_vbus_detect; + u32 usb2_vbus_detect_set; + u32 usb2_vbus_detect_clr; + u32 usb2_vbus_detect_tog; + u32 usb2_chrg_detect; + u32 usb2_chrg_detect_set; + u32 usb2_chrg_detect_clr; + u32 usb2_chrg_detect_tog; + u32 usb2_vbus_det_stat; + u32 usb2_vbus_det_stat_set; + u32 usb2_vbus_det_stat_clr; + u32 usb2_vbus_det_stat_tog; + u32 usb2_chrg_det_stat; + u32 usb2_chrg_det_stat_set; + u32 usb2_chrg_det_stat_clr; + u32 usb2_chrg_det_stat_tog; + u32 usb2_loopback; + u32 usb2_loopback_set; + u32 usb2_loopback_clr; + u32 usb2_loopback_tog; + u32 usb2_misc; + u32 usb2_misc_set; + u32 usb2_misc_clr; + u32 usb2_misc_tog; + u32 digprog; + u32 reserved1[7]; + /* For i.MX 6SoloLite */ + u32 digprog_sololite; }; #endif
Check "Figure 19-5. BUS clock generation" of i.MX 6SoloX Applications Processor Reference Manual and "Figure 18-5. BUS clock generation" of i.MX 6UltraLite Applications Processor Reference Manual. If mmdc clk sources from pll4_main_clk(pll_audio), the calculation is wrong.
Fix mmdc_ch0 clk calculation. Also add PLL_AUDIO/VIDEO support for decode_pll.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de ---
Changes V2: Address Eric's comemnts about indent format. Use pmu_misc2_audio_div, but not misc2_audio_div. Define macro to simplify c code.
arch/arm/cpu/armv7/mx6/clock.c | 61 +++++++++++++++++++++++++++++--- arch/arm/include/asm/arch-mx6/crm_regs.h | 12 +++++++ 2 files changed, 69 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 64514b1..27a3f2f 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -18,6 +18,8 @@ enum pll_clocks { PLL_BUS, /* System Bus PLL*/ PLL_USBOTG, /* OTG USB PLL */ PLL_ENET, /* ENET PLL */ + PLL_AUDIO, /* AUDIO PLL */ + PLL_VIDEO, /* AUDIO PLL */ };
struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -204,7 +206,7 @@ int enable_spi_clk(unsigned char enable, unsigned spi_num) } static u32 decode_pll(enum pll_clocks pll, u32 infreq) { - u32 div; + u32 div, test_div, pll_num, pll_denom;
switch (pll) { case PLL_SYS: @@ -227,6 +229,44 @@ static u32 decode_pll(enum pll_clocks pll, u32 infreq) div &= BM_ANADIG_PLL_ENET_DIV_SELECT;
return 25000000 * (div + (div >> 1) + 1); + case PLL_AUDIO: + div = __raw_readl(&imx_ccm->analog_pll_audio); + if (!(div & BM_ANADIG_PLL_AUDIO_ENABLE)) + return 0; + /* BM_ANADIG_PLL_AUDIO_BYPASS_CLK_SRC is ignored */ + if (div & BM_ANADIG_PLL_AUDIO_BYPASS) + return MXC_HCLK; + pll_num = __raw_readl(&imx_ccm->analog_pll_audio_num); + pll_denom = __raw_readl(&imx_ccm->analog_pll_audio_denom); + test_div = (div & BM_ANADIG_PLL_AUDIO_TEST_DIV_SELECT) >> + BP_ANADIG_PLL_AUDIO_TEST_DIV_SELECT; + div &= BM_ANADIG_PLL_AUDIO_DIV_SELECT; + if (test_div == 3) { + debug("Error test_div\n"); + return 0; + } + test_div = 1 << (2 - test_div); + + return infreq * (div + pll_num / pll_denom) / test_div; + case PLL_VIDEO: + div = __raw_readl(&imx_ccm->analog_pll_video); + if (!(div & BM_ANADIG_PLL_VIDEO_ENABLE)) + return 0; + /* BM_ANADIG_PLL_AUDIO_BYPASS_CLK_SRC is ignored */ + if (div & BM_ANADIG_PLL_VIDEO_BYPASS) + return MXC_HCLK; + pll_num = __raw_readl(&imx_ccm->analog_pll_video_num); + pll_denom = __raw_readl(&imx_ccm->analog_pll_video_denom); + test_div = (div & BM_ANADIG_PLL_VIDEO_POST_DIV_SELECT) >> + BP_ANADIG_PLL_VIDEO_POST_DIV_SELECT; + div &= BM_ANADIG_PLL_VIDEO_DIV_SELECT; + if (test_div == 3) { + debug("Error test_div\n"); + return 0; + } + test_div = 1 << (2 - test_div); + + return infreq * (div + pll_num / pll_denom) / test_div; default: return 0; } @@ -437,7 +477,7 @@ static u32 get_mmdc_ch0_clk(void) u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); u32 cbcdr = __raw_readl(&imx_ccm->cbcdr);
- u32 freq, podf, per2_clk2_podf; + u32 freq, podf, per2_clk2_podf, pmu_misc2_audio_div;
if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL) || is_cpu_type(MXC_CPU_MX6SL)) { @@ -472,8 +512,21 @@ static u32 get_mmdc_ch0_clk(void) freq = mxc_get_pll_pfd(PLL_BUS, 0); break; case 3: - /* static / 2 divider */ - freq = mxc_get_pll_pfd(PLL_BUS, 2) / 2; + pmu_misc2_audio_div = PMU_MISC2_AUDIO_DIV(__raw_readl(&imx_ccm->pmu_misc2)); + switch (pmu_misc2_audio_div) { + case 0: + case 2: + pmu_misc2_audio_div = 1; + break; + case 1: + pmu_misc2_audio_div = 2; + break; + case 3: + pmu_misc2_audio_div = 4; + break; + } + freq = decode_pll(PLL_AUDIO, MXC_HCLK) / + pmu_misc2_audio_div; break; } } diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index f6ec09d..d9254ba 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -1227,4 +1227,16 @@ struct mxc_ccm_reg {
#define BM_ANADIG_ANA_MISC0_REFTOP_SELBIASOFF 0x00000008
+#define BM_PMU_MISC2_AUDIO_DIV_MSB (1 << 23) +#define BP_PMU_MISC2_AUDIO_DIV_MSB 23 + +#define BM_PMU_MISC2_AUDIO_DIV_LSB (1 << 15) +#define BP_PMU_MISC2_AUDIO_DIV_LSB 15 + +#define PMU_MISC2_AUDIO_DIV(v) \ + (((v & BM_PMU_MISC2_AUDIO_DIV_MSB) >> \ + (BP_PMU_MISC2_AUDIO_DIV_MSB - 1)) | \ + ((v & BM_PMU_MISC2_AUDIO_DIV_LSB) >> \ + BP_PMU_MISC2_AUDIO_DIV_LSB)) + #endif /*__ARCH_ARM_MACH_MX6_CCM_REGS_H__ */
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Nice. Thanks.
Eric Nelson
Peng Fan
Stefano Babic
