[PATCH] rockchip: Restore support for boot scripts in legacy image format
Use of CONFIG_SPL_FIT_SIGNATURE=y cause CONFIG_LEGACY_IMAGE_FORMAT=n as default, this prevent boot scripts in legacy image format from working and was an unintended change in the listed fixes commits:
Wrong image format for "source" command
Add CONFIG_LEGACY_IMAGE_FORMAT=y to defconfig for affected boards to restore support for boot scripts in legacy image format.
Fixes: 3bf8e4080763 ("board: rockchip: add Radxa ROCK5B Rk3588 board") Fixes: cf777572ca31 ("rockchip: rockpro64: Use SDMA to boost eMMC performance") Fixes: 6e2b8344d60c ("rockchip: rock-pi-4: Use SDMA to boost eMMC performance") Fixes: 1bf49d5a4a7c ("rockchip: rk3566-radxa-cm3-io: Update defconfig") Fixes: 703c170b40f2 ("rockchip: rk3568-evb: Update defconfig") Fixes: 68000f750acd ("rockchip: rk3568-rock-3a: Update defconfig") Fixes: 6fb02589a608 ("rockchip: rk3588-evb: Update defconfig") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- configs/evb-rk3568_defconfig | 1 + configs/evb-rk3588_defconfig | 1 + configs/radxa-cm3-io-rk3566_defconfig | 1 + configs/rock-3a-rk3568_defconfig | 1 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rock5b-rk3588_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + 7 files changed, 7 insertions(+)
diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index 07819d105441..5f3fab7304c2 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig index d5f1c4b9ebc7..f49c2ca686a8 100644 --- a/configs/evb-rk3588_defconfig +++ b/configs/evb-rk3588_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-evb1-v10.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index 56802d85cc25..488723dfaa30 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-radxa-cm3-io.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 616499f2f82b..753d03914d90 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -27,6 +27,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-rock-3a.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 4b984adc6ef8..466868d80b03 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -20,6 +20,7 @@ CONFIG_PCI=y CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4a.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index c1155c20efa8..17205a56cd99 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -29,6 +29,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-rock-5b.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index f41c03067903..dc4392c7451c 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -23,6 +23,7 @@ CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_LTO=y CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_USE_PREBOOT=y
Hi Jonas,
What is the legacy image format, does these boards really use than?
I think most of the board using linux distro image.
Thanks,
- Kever
Hi Kever,
On 2023-06-29 12:51, Kever Yang wrote:
Hi Jonas,
The legacy image format it the normal boot script format, in the documentation it is called Legacy U-Boot image, see [1].
i.e. boot scripts compiled with:
mkimage -T script -n 'Test script' -d boot.txt boot.scr
Such boot scripts are used by some linux distro, e.g. Armbian.
[1] https://u-boot.readthedocs.io/en/latest/usage/cmd/source.html#legacy-u-boot-...
Regards, Jonas
Thanks,
- Kever
Hi:
在 2023-06-29 22:07:05,"Jonas Karlman" jonas@kwiboo.se 写道:
Hi Kever,
Hi Jonas,
Yes, this is a common use case, I also run into this case a few weeks ago on armbian[2]:
The code handle this logic in u-boot is image_locate_script.
[2 ]https://github.com/armbian/build/blob/main/config/bootscripts/boot-rockchip....
Regards, Jonas
Thanks,
- Kever
Andy Yan
Jonas Karlman
Kever Yang
