Re: [PATCH 1/2] Revert "riscv: Allow use of reset drivers"
Hi Bin
From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Thursday, July 16, 2020 9:36 AM To: Sean Anderson Cc: Rick Jian-Zhi Chen(陳建志); Tom Rini; U-Boot Mailing List; Bin Meng Subject: Re: [PATCH 1/2] Revert "riscv: Allow use of reset drivers"
Hi Rick,
On Wed, Jul 8, 2020 at 3:04 PM Sean Anderson seanga2@gmail.com wrote:
On 7/8/20 2:44 AM, Bin Meng wrote:
This reverts commit 958a3f464c7f8ef7e10db9feb663e9e80445ce2f.
A more appropriate change below is already in mainline. Commit fd31e4fd184f ("riscv: Do not build reset.c if SYSRESET is on")
Revert this patch, so that U-Boot can be built successfully for SiFive Fu540 board.
Signed-off-by: Bin Meng bin.meng@windriver.com
arch/riscv/lib/reset.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/riscv/lib/reset.c b/arch/riscv/lib/reset.c index 6008bbe..8779c61 100644 --- a/arch/riscv/lib/reset.c +++ b/arch/riscv/lib/reset.c @@ -7,7 +7,6 @@ #include <command.h> #include <hang.h>
-#ifndef CONFIG_SYSRESET int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { printf("resetting ...\n"); @@ -17,4 +16,3 @@ int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
} -#endif
Reviewed-by: Sean Anderson seanga2@gmail.com
Could we get this series applied soon? thanks!
OK.
But [PATCH 2/2] Revert "Revert "riscv: sifive: fu540: Add gpio-restart support"" seem conflict with Pragnesh's [PATCH 2/2] riscv: sifive: fu540: Enable SiFive PWM driver.
Would you please rebase with u-boot-riscv/master and send again ?
Thanks, Rick
Regards, Bin
Hi Rick,
On Thu, Jul 16, 2020 at 3:06 PM Rick Chen rickchen36@gmail.com wrote:
Hi Bin
Hi Rick,
} -#endif
OK.
Sure will rebase.
Regards, Bin
Bin Meng
Rick Chen
