[PATCH] doc: fix typos
Fix a few typos spot during a first read of the contribution process.
Signed-off-by: Maxim Cournoyer maxim.cournoyer@savoirfairelinux.com ---
doc/develop/process.rst | 4 ++-- doc/develop/sending_patches.rst | 6 +++--- doc/develop/system_configuration.rst | 6 +++--- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/doc/develop/process.rst b/doc/develop/process.rst index 0fa0143bf3..ba864bc40b 100644 --- a/doc/develop/process.rst +++ b/doc/develop/process.rst @@ -165,7 +165,7 @@ document. https://www.kernel.org/doc/html/latest/process/submitting-patches.html#using-reported-by-tested-by-reviewed-by-suggested-by-and-fixes`_ and similar additional tags.
-* Reviewed-by: The patch has been reviewed and found acceptible according to +* Reviewed-by: The patch has been reviewed and found acceptable according to the `Reveiwer's statement of oversight https://www.kernel.org/doc/html/latest/process/submitting-patches.html#reviewer-s-statement-of-oversight`_. A *Reviewed-by:* tag is a statement of opinion that the patch is an @@ -251,7 +251,7 @@ like this: workflows and environments however.
#. Although a custodian is supposed to perform their own tests it is a - well-known and accepted fact that they needs help from other developers who + well-known and accepted fact that they need help from other developers who - for example - have access to the required hardware or other relevant environments. Custodians are expected to ask for assistance with testing when required. diff --git a/doc/develop/sending_patches.rst b/doc/develop/sending_patches.rst index 173075687e..49374f14ff 100644 --- a/doc/develop/sending_patches.rst +++ b/doc/develop/sending_patches.rst @@ -20,8 +20,8 @@ LWN article `How to Get Your Change Into the Linux Kernel Using patman ------------
-You can use a tool called patman to prepare, check and sent patches. It creates -change logs, cover letters and patch notes. It also simplified the process of +You can use a tool called patman to prepare, check and send patches. It creates +change logs, cover letters and patch notes. It also simplifies the process of sending multiple versions of a series.
See more details at :doc:`patman`. @@ -312,7 +312,7 @@ Notes 2. All code must follow the :doc:`codingstyle` requirements.
3. Before sending the patch, you *must* run some form of local testing. - Submitting a patch that does not build or function correct is a mistake. For + Submitting a patch that does not build or function correctly is a mistake. For non-trivial patches, either building a number of platforms locally or making use of :doc:`ci_testing` is strongly encouraged in order to avoid problems that can be found when attempting to merge the patch. diff --git a/doc/develop/system_configuration.rst b/doc/develop/system_configuration.rst index 52e4e1df15..40be46b082 100644 --- a/doc/develop/system_configuration.rst +++ b/doc/develop/system_configuration.rst @@ -86,12 +86,12 @@ When to use each mechanism ^^^^^^^^^^^^^^^^^^^^^^^^^^
While there are some cases where it should be fairly obvious where to use each -mechanism, as for example a command would done via Kconfig, a new I2C driver +mechanism, as for example a command would be done via Kconfig, a new I2C driver should use Kconfig and be configured via driver model and a header of values generated by an external tool should be ``CFG``, there will be cases where it's less clear and one needs to take care when implementing it. In general, configuration *options* should be done in Kconfig and configuration *settings* -should done in driver model or ``CFG``. Let us discuss things to keep in mind +should be done in driver model or ``CFG``. Let us discuss things to keep in mind when picking the appropriate mechanism.
A thing to keep in mind is that we have a strong preference for using Kconfig as @@ -122,7 +122,7 @@ to use Kconfig in this case, it would result in using calculated rather than constructed values, resulting in less clear code. Consider the example of a set of register values for a memory controller. Defining this as a series of logical ORs and shifts based on other defines is more clear than the Kconfig entry that -set the calculated value alone. +sets the calculated value alone.
When it has been determined that the practical solution is to utilize the ``CFG`` mechanism, the next decision is where to place these settings. It is
base-commit: 9bd3d354a1a0712ac27c717df9ad60566b0406ee
Le 17 décembre 2022 03:09:40 GMT+01:00, Maxim Cournoyer maxim.cournoyer@gmail.com a écrit :
Somehow you missed "Reveiwer" :)
I will consider this when merging.
Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
Heinrich Schuchardt heinrich.schuchardt@canonical.com writes:
Oh, I just saw that. I'll leave it to you then, thank you!
Hi Julien,
Julien Lepiller julien@lepiller.eu writes:
Haha, thanks for reviewing patches I mistakenly (also) sent to guix-patches@gnu.org (I was experimenting with 'patman', and forgot to add a 'Series-to:' commit message tag, so it used my default).
I'll send a v2.
Thanks,
Maxim
Julien Lepiller
Maxim Cournoyer
