[PATCH] dt-bindings: leds: import common led bindings from linux 5.17
This allows usage of LED_COLOR_ID_RGB macro in DTS files.
Signed-off-by: Pali Rohár pali@kernel.org --- include/dt-bindings/leds/common.h | 48 ++++++++++++++++++++++++------- 1 file changed, 37 insertions(+), 11 deletions(-)
diff --git a/include/dt-bindings/leds/common.h b/include/dt-bindings/leds/common.h index 9e1256a7c1bf..3be89a7c20a9 100644 --- a/include/dt-bindings/leds/common.h +++ b/include/dt-bindings/leds/common.h @@ -6,6 +6,7 @@ * Author: Jacek Anaszewski j.anaszewski@samsung.com * * Copyright (C) 2019 Jacek Anaszewski jacek.anaszewski@gmail.com + * Copyright (C) 2020 Pavel Machek pavel@ucw.cz */
#ifndef __DT_BINDINGS_LEDS_H @@ -29,19 +30,51 @@ #define LED_COLOR_ID_VIOLET 5 #define LED_COLOR_ID_YELLOW 6 #define LED_COLOR_ID_IR 7 -#define LED_COLOR_ID_MAX 8 +#define LED_COLOR_ID_MULTI 8 /* For multicolor LEDs */ +#define LED_COLOR_ID_RGB 9 /* For multicolor LEDs that can do arbitrary color, + so this would include RGBW and similar */ +#define LED_COLOR_ID_MAX 10
/* Standard LED functions */ +/* Keyboard LEDs, usually it would be input4::capslock etc. */ +/* Obsolete equivalent: "shift-key-light" */ +#define LED_FUNCTION_CAPSLOCK "capslock" +#define LED_FUNCTION_SCROLLLOCK "scrolllock" +#define LED_FUNCTION_NUMLOCK "numlock" +/* Obsolete equivalents: "tpacpi::thinklight" (IBM/Lenovo Thinkpads), + "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ +#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" + +/* System LEDs, usually found on system body. + platform::mute (etc) is sometimes seen, :mute would be better */ +#define LED_FUNCTION_POWER "power" +#define LED_FUNCTION_DISK "disk" + +/* Obsolete: "platform:*:charging" (allwinner sun50i) */ +#define LED_FUNCTION_CHARGING "charging" +/* Used RGB notification LEDs common on phones. + Obsolete equivalents: "status-led:{red,green,blue}" (Motorola Droid 4), + "lp5523:{r,g,b}" (Nokia N900) */ +#define LED_FUNCTION_STATUS "status" + +#define LED_FUNCTION_MICMUTE "micmute" +#define LED_FUNCTION_MUTE "mute" + +/* Used for player LEDs as found on game controllers from e.g. Nintendo, Sony. */ +#define LED_FUNCTION_PLAYER1 "player-1" +#define LED_FUNCTION_PLAYER2 "player-2" +#define LED_FUNCTION_PLAYER3 "player-3" +#define LED_FUNCTION_PLAYER4 "player-4" +#define LED_FUNCTION_PLAYER5 "player-5" + +/* Miscelleaus functions. Use functions above if you can. */ #define LED_FUNCTION_ACTIVITY "activity" #define LED_FUNCTION_ALARM "alarm" #define LED_FUNCTION_BACKLIGHT "backlight" #define LED_FUNCTION_BLUETOOTH "bluetooth" #define LED_FUNCTION_BOOT "boot" #define LED_FUNCTION_CPU "cpu" -#define LED_FUNCTION_CAPSLOCK "capslock" -#define LED_FUNCTION_CHARGING "charging" #define LED_FUNCTION_DEBUG "debug" -#define LED_FUNCTION_DISK "disk" #define LED_FUNCTION_DISK_ACTIVITY "disk-activity" #define LED_FUNCTION_DISK_ERR "disk-err" #define LED_FUNCTION_DISK_READ "disk-read" @@ -50,21 +83,14 @@ #define LED_FUNCTION_FLASH "flash" #define LED_FUNCTION_HEARTBEAT "heartbeat" #define LED_FUNCTION_INDICATOR "indicator" -#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" #define LED_FUNCTION_LAN "lan" #define LED_FUNCTION_MAIL "mail" #define LED_FUNCTION_MTD "mtd" -#define LED_FUNCTION_MICMUTE "micmute" -#define LED_FUNCTION_MUTE "mute" -#define LED_FUNCTION_NUMLOCK "numlock" #define LED_FUNCTION_PANIC "panic" #define LED_FUNCTION_PROGRAMMING "programming" -#define LED_FUNCTION_POWER "power" #define LED_FUNCTION_RX "rx" #define LED_FUNCTION_SD "sd" -#define LED_FUNCTION_SCROLLLOCK "scrolllock" #define LED_FUNCTION_STANDBY "standby" -#define LED_FUNCTION_STATUS "status" #define LED_FUNCTION_TORCH "torch" #define LED_FUNCTION_TX "tx" #define LED_FUNCTION_USB "usb"
Pali Rohár
