[PATCH 0/4] rockchip: Read cpuid and generate MAC address from efuse for RK3328 and RK3399
Hi folks,
This series enables ROCKCHIP_EFUSE and MISC_INIT_R by default for RK3328 and RK3399 so that the cpuid is read from the efuse and used to generate a serial number and MAC addresses for all boards.
This stacks on top of the recent defconfig update series [1] from Jonas.
[1] https://lore.kernel.org/u-boot/20240207000301.3270722-1-jonas@kwiboo.se/
Chen-Yu Tsai (4): rockchip: rk3328: Read cpuid and generate MAC address from efuse rockchip: rk3399: Read cpuid and generate MAC address from efuse rockchip: rk3328: regenerate defconfigs rockchip: rk3399: regenerate defconfigs
arch/arm/mach-rockchip/Kconfig | 4 ++++ configs/chromebook_bob_defconfig | 2 -- configs/chromebook_kevin_defconfig | 2 -- configs/evb-rk3328_defconfig | 2 -- configs/firefly-rk3399_defconfig | 2 -- configs/nanopi-r2c-plus-rk3328_defconfig | 2 -- configs/nanopi-r2c-rk3328_defconfig | 2 -- configs/nanopi-r2s-rk3328_defconfig | 2 -- configs/nanopi-r4s-rk3399_defconfig | 2 -- configs/orangepi-r1-plus-lts-rk3328_defconfig | 2 -- configs/orangepi-r1-plus-rk3328_defconfig | 2 -- configs/pinebook-pro-rk3399_defconfig | 2 -- configs/pinephone-pro-rk3399_defconfig | 2 -- configs/puma-rk3399_defconfig | 2 -- configs/roc-cc-rk3328_defconfig | 2 -- configs/roc-pc-mezzanine-rk3399_defconfig | 2 -- configs/roc-pc-rk3399_defconfig | 2 -- configs/rock-4c-plus-rk3399_defconfig | 3 --- configs/rock-4se-rk3399_defconfig | 3 --- configs/rock-pi-4-rk3399_defconfig | 3 --- configs/rock-pi-4c-rk3399_defconfig | 3 --- configs/rock-pi-e-rk3328_defconfig | 2 -- configs/rock-pi-n10-rk3399pro_defconfig | 1 - configs/rock64-rk3328_defconfig | 2 -- configs/rock960-rk3399_defconfig | 1 - configs/rockpro64-rk3399_defconfig | 2 -- 26 files changed, 4 insertions(+), 52 deletions(-)
The rockchip-efuse driver supports the efuse found on RK3328. This hardware block is part of the SoC and contains the CPUID, which can be used to generate stable serial numbers and MAC addresses.
Enable the driver and reading cpuid by default for RK3328.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/mach-rockchip/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 1bc7ee904275..20670fb57376 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -189,6 +189,8 @@ config ROCKCHIP_RK3328 select ENABLE_ARM_SOC_BOOT0_HOOK select DEBUG_UART_BOARD_INIT select SYS_NS16550 + imply ROCKCHIP_EFUSE + imply MISC_INIT_R help The Rockchip RK3328 is a ARM-based SoC with a quad-core Cortex-A53. including NEON and GPU, 1MB L2 cache, Mali-T7 graphics, two
The rockchip-efuse driver supports the efuse found on RK3399. This hardware block is part of the SoC and contains the CPUID, which can be used to generate stable serial numbers and MAC addresses.
Enable the driver and reading cpuid by default for RK3399.
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 20670fb57376..2558d956b8c6 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -269,6 +269,8 @@ config ROCKCHIP_RK3399 imply SYS_BOOTCOUNT_SINGLEWORD if BOOTCOUNT_LIMIT imply BOOTSTD_FULL imply CMD_BOOTCOUNT if BOOTCOUNT_LIMIT + imply ROCKCHIP_EFUSE + imply MISC_INIT_R help The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 and quad-core Cortex-A53.
Regenerate RK3328 defconfigs after adding imply statements.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/evb-rk3328_defconfig | 2 -- configs/nanopi-r2c-plus-rk3328_defconfig | 2 -- configs/nanopi-r2c-rk3328_defconfig | 2 -- configs/nanopi-r2s-rk3328_defconfig | 2 -- configs/orangepi-r1-plus-lts-rk3328_defconfig | 2 -- configs/orangepi-r1-plus-rk3328_defconfig | 2 -- configs/roc-cc-rk3328_defconfig | 2 -- configs/rock-pi-e-rk3328_defconfig | 2 -- configs/rock64-rk3328_defconfig | 2 -- 9 files changed, 18 deletions(-)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 995bfd0558b1..004cbd33e80a 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -30,7 +30,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -71,7 +70,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2c-plus-rk3328_defconfig b/configs/nanopi-r2c-plus-rk3328_defconfig index 1cb0ed855398..2f0d253b4b7c 100644 --- a/configs/nanopi-r2c-plus-rk3328_defconfig +++ b/configs/nanopi-r2c-plus-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2c-plus.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -73,7 +72,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 59801328deda..ca13eb873a72 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2c.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -73,7 +72,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 61914b1650d2..619707436130 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2s.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -73,7 +72,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig index 968110c8cd6f..8e9a9411a763 100644 --- a/configs/orangepi-r1-plus-lts-rk3328_defconfig +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus-lts.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -78,7 +77,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig index 7038f09f202c..240fcdeb221f 100644 --- a/configs/orangepi-r1-plus-rk3328_defconfig +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -78,7 +77,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 7d81a715ef25..f734116f847e 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-roc-cc.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -74,7 +73,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_REALTEK=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index ddd482dd0195..5ccdc02d4c86 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -32,7 +32,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock-pi-e.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -74,7 +73,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_REALTEK=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 01e447448513..81284c6697a5 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -78,7 +77,6 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y
Regenerate RK3399 defconfigs after adding imply statements.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/chromebook_bob_defconfig | 2 -- configs/chromebook_kevin_defconfig | 2 -- configs/firefly-rk3399_defconfig | 2 -- configs/nanopi-r4s-rk3399_defconfig | 2 -- configs/pinebook-pro-rk3399_defconfig | 2 -- configs/pinephone-pro-rk3399_defconfig | 2 -- configs/puma-rk3399_defconfig | 2 -- configs/roc-pc-mezzanine-rk3399_defconfig | 2 -- configs/roc-pc-rk3399_defconfig | 2 -- configs/rock-4c-plus-rk3399_defconfig | 3 --- configs/rock-4se-rk3399_defconfig | 3 --- configs/rock-pi-4-rk3399_defconfig | 3 --- configs/rock-pi-4c-rk3399_defconfig | 3 --- configs/rock-pi-n10-rk3399pro_defconfig | 1 - configs/rock960-rk3399_defconfig | 1 - configs/rockpro64-rk3399_defconfig | 2 -- 16 files changed, 34 deletions(-)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index b5a5ae737e52..bffa0d33b75c 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -27,7 +27,6 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 @@ -68,7 +67,6 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_I2C_MUX=y CONFIG_CROS_EC_KEYB=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index 20913d2cf0fe..e14fc358c504 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -28,7 +28,6 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-kevin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 @@ -69,7 +68,6 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_I2C_MUX=y CONFIG_CROS_EC_KEYB=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index b7c8e95b7b89..b01b1a327896 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -20,7 +20,6 @@ CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -46,7 +45,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index cacaab14d21f..18a1e68aa049 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-r4s.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -42,7 +41,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_ROCKCHIP_OTP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index de357415fbe4..6b83daf07945 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -26,7 +26,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinebook-pro.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -61,7 +60,6 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_SPL_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y diff --git a/configs/pinephone-pro-rk3399_defconfig b/configs/pinephone-pro-rk3399_defconfig index d08224fe536b..96316c4b303f 100644 --- a/configs/pinephone-pro-rk3399_defconfig +++ b/configs/pinephone-pro-rk3399_defconfig @@ -25,7 +25,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinephone-pro.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -60,7 +59,6 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index c2aa02ec74bd..f39d352c7890 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -68,7 +67,6 @@ CONFIG_SPL_GPIO_HOG=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index de6539bedf48..64103eada8cf 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -26,7 +26,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc-mezzanine.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -56,7 +55,6 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 7123a7a07299..61991e8868b3 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -27,7 +27,6 @@ CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -56,7 +55,6 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-4c-plus-rk3399_defconfig b/configs/rock-4c-plus-rk3399_defconfig index 18525c8bf504..12587b1eba10 100644 --- a/configs/rock-4c-plus-rk3399_defconfig +++ b/configs/rock-4c-plus-rk3399_defconfig @@ -8,7 +8,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-4c-plus" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y @@ -21,7 +20,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-4c-plus.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -53,7 +51,6 @@ CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-4se-rk3399_defconfig b/configs/rock-4se-rk3399_defconfig index 171de23ec8f6..16a58a10d7e3 100644 --- a/configs/rock-4se-rk3399_defconfig +++ b/configs/rock-4se-rk3399_defconfig @@ -8,7 +8,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-4se" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y @@ -23,7 +22,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-4se.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -54,7 +52,6 @@ CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 83fc4ad7dabc..fe3705e3672c 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -8,7 +8,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4a" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y @@ -23,7 +22,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4a.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -55,7 +53,6 @@ CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index 089344097e0c..f37a09710b9e 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -8,7 +8,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4c" -CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y @@ -21,7 +20,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4c.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -53,7 +51,6 @@ CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index dc4b3b40380a..9a8beaa81ddf 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -22,7 +22,6 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index b93dda56593b..80b41b061bdb 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -20,7 +20,6 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" CONFIG_SYS_PBSIZE=1052 CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 711541f84627..c37d858c2c66 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -28,7 +28,6 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -64,7 +63,6 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
Hi Chen-Yu,
[snip]
This patch seems to also remove a few OF_LIBFDT_OVERLAY, guessing this was unintentional?
If you are re-spinning this series, please also include change to: - add CONFIG_MISC=y to ficus-rk3399_defconfig, its required for efuse - drop CONFIG_ROCKCHIP_OTP=y from nanopi-r4s-rk3399_defconfig, soc have efuse or otp and on rk3399 it is efuse
And possible also drop CONFIG_NET_RANDOM_ETHADDR=y from: - evb-rk3399_defconfig - ficus-rk3399_defconfig - khadas-edge-captain-rk3399_defconfig - khadas-edge-v-rk3399_defconfig now that these boards will have proper ethaddr.
Regards, Jonas
On Sun, Feb 11, 2024 at 3:49 AM Jonas Karlman jonas@kwiboo.se wrote:
Hi Chen-Yu,
[snip]
Yeah, that was unintentional. I have a local patch that enables OF_LIBFDT_OVERLAY for ARCH_ROCKCHIP by default.
I suppose we should just also imply CONFIG_MISC.
Will add a cleanup.
Will add a separate cleanup.
ChenYu
Hi Chen-Yu,
On 2/10/24 07:32, Chen-Yu Tsai wrote:
[Some people who received this message don't often get email from wens@kernel.org. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
Reviewed-by: Quentin Schulz quentin.schulz@theobroma-systems.com
Thanks, Quentin
Hi Chen-Yu,
For the entire series:
Reviewed-by: Christopher Obbard chris.obbard@collabora.com
On 10 February 2024 06:32:46 GMT, Chen-Yu Tsai wens@kernel.org wrote:
Hi folks,
-- 2.39.2
The entire series is looking good to me!
Reviewed-by: Dragan Simic dsimic@manjaro.org
On Sat, 10 Feb 2024 at 06:32, Chen-Yu Tsai wens@kernel.org wrote:
Hi folks,
For the series: Reviewed-by: Peter Robinson pbrobinson@gmail.com
-- 2.39.2
Hi folks,
Thanks. I just sent out v2. Could you reply there as well?
participants (6)
Chen-Yu Tsai
Christopher Obbard
Dragan Simic
Jonas Karlman
Peter Robinson
Quentin Schulz
