[U-Boot-Users] Booting MPC8266ads kernel
Hello,
I am trying to find anyone who has had success in using u-boot to boot an MPC8266ads kernel to give me a pointer or 2 in the right direction. I have rsync'd the latest 2.4 development kernel from penguinppc.org as it contains the appropriate drivers etc. for the board and have u-boot running on the board now. However, when I tftp the kernel to the board and try to bootm, I get:
Uncompressing Kernel Image ... OK
and then no progress from there. Looking through the users list and the README file, I noticed that the the bd_info has to be the same between u-boot.h and the kernel's appropriate header file; there is also some recommendations with regards to the "clocks_in_mhz" option and the synchronization of IMAP_ADDR and CFG_IMMR. I have also built the kernel by hand using the system detailed in the u-boot README file, with the objcopy;gzip -9; mkimage, all to no avail. If anyone has any insight in this regard, I would very much appreciate it.
Thanks in advance,
Currie Reid
U-Boot 0.3.0 (Jun 15 2003 - 18:36:34)
MPC8260 Reset Status: Check Stop, External Soft, External Hard
MPC8260 Clock Configuration - Bus-to-Core Mult 3x, VCO Div 2, 60x Bus Freq 33-100, Core Freq 100-300 - dfbrg 0, corecnf 0x08, busdf 3, cpmdf 1, plldf 0, pllmf 1 - vco_out 266666664, scc_clk 66666666, brg_clk 66666666 - cpu_clk 199999998, cpm_clk 133333332, bus_clk 66666666
CPU: MPC8260 (Rev 14, Mask unknown [immr=0x0062,k=0x002d]) at 199.999 MHz Board: Motorola MPC8266ADS I2C: ready DRAM: SDRAM configuration read from SPD Size per side = 16MB Organization: 1 sides, 2 banks, 9 Columns, 11 Rows, Data width = 64 bits Refresh rate = 16, CAS latency = 3 Total size: 16 MB FLASH: 8 MB In: serial Out: serial Err: serial Net: FCC2 ETHERNET => tftp ARP broadcast 1 TFTP from server 47.129.82.27; our IP address is 47.129.82.129 Filename '/tftpboot/uImage.MPC8266'. Load address: 0x100000 Loading: ################################################################# ################################################ done Bytes transferred = 575660 (8c8ac hex) => printenv bootdelay=5 serial#=MCP8266ADS-PCI 0210 ethaddr=4A:DC:16:9D:37:D8 baudrate=57600 hostname=pcary3h5 bootfile=/tftpboot/uImage.MPC8266 rootpath=/export/47.129.82.129 filesize=8c8b0 gatewayip=47.129.82.1 netmask=255.255.255.0 ipaddr=47.129.82.129 serverip=47.129.82.27 bootargs=root=/dev/nfs rw nfsroot=$(serverip):$(rootpath) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname)::off stdin=serial stdout=serial stderr=serial clocks_in_mhz=1 => bootm ## Booting image at 00100000 ... Image Name: Linux 2.4.21 - MPC8266ads Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 575596 Bytes = 562.1 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Currie Reid
