[U-Boot] [v2][PATCH] Added P1020 Processor Support.
P1020 is another member of QorIQ series of processors which falls in ULE category. It is an e500 based dual core SOC. Being a scaled down version of P2020 it has following differences from P2020: - 533MHz - 800MHz core frequency. - 256Kbyte L2 cache - Ethernet controllers with classification capabilities. Also the SOC is pin compatible with P2020
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- - based of 2009.08-rc1 - depends on the patch "[PATCH 1/2] Refactored common cpu specific code for 85xx and 86xx into one file." - Changes over v1: Incorporated Wolfgang's comments cpu/mpc85xx/Makefile | 3 ++- cpu/mpc8xxx/cpu.c | 2 ++ drivers/misc/fsl_law.c | 2 +- include/asm-ppc/processor.h | 2 ++ 4 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc85xx/Makefile b/cpu/mpc85xx/Makefile index 8809302..1477eac 100644 --- a/cpu/mpc85xx/Makefile +++ b/cpu/mpc85xx/Makefile @@ -48,8 +48,9 @@ COBJS-$(CONFIG_MPC8544) += ddr-gen2.o # supports ddr1/2/3 COBJS-$(CONFIG_MPC8572) += ddr-gen3.o COBJS-$(CONFIG_MPC8536) += ddr-gen3.o -COBJS-$(CONFIG_P2020) += ddr-gen3.o COBJS-$(CONFIG_MPC8569) += ddr-gen3.o +COBJS-$(CONFIG_P2020) += ddr-gen3.o +COBJS-$(CONFIG_P1020) += ddr-gen3.o
COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS = traps.o cpu.o cpu_init.o speed.o interrupts.o tlb.o \ diff --git a/cpu/mpc8xxx/cpu.c b/cpu/mpc8xxx/cpu.c index 781741a..7212c64 100644 --- a/cpu/mpc8xxx/cpu.c +++ b/cpu/mpc8xxx/cpu.c @@ -66,6 +66,8 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(8572, 8572_E, 2), CPU_TYPE_ENTRY(P2020, P2020, 2), CPU_TYPE_ENTRY(P2020, P2020_E, 2), + CPU_TYPE_ENTRY(P1020, P1020, 2), + CPU_TYPE_ENTRY(P1020, P1020_E, 2), #elif defined(CONFIG_MPC86xx) CPU_TYPE_ENTRY(8610, 8610, 1), CPU_TYPE_ENTRY(8641, 8641, 2), diff --git a/drivers/misc/fsl_law.c b/drivers/misc/fsl_law.c index f7d454d..af7b729 100644 --- a/drivers/misc/fsl_law.c +++ b/drivers/misc/fsl_law.c @@ -39,7 +39,7 @@ DECLARE_GLOBAL_DATA_PTR; defined(CONFIG_MPC8641) || defined(CONFIG_MPC8610) #define FSL_HW_NUM_LAWS 10 #elif defined(CONFIG_MPC8536) || defined(CONFIG_MPC8572) || \ - defined(CONFIG_P2020) + defined(CONFIG_P2020) || defined(CONFIG_P1020) #define FSL_HW_NUM_LAWS 12 #else #error FSL_HW_NUM_LAWS not defined for this platform diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index f9e17cd..64137bf 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -1009,6 +1009,8 @@ #define SVR_8572_E 0x80E800 #define SVR_P2020 0x80E200 #define SVR_P2020_E 0x80EA00 +#define SVR_P1020 0x80E400 +#define SVR_P1020_E 0x80EC00
#define SVR_8610 0x80A000 #define SVR_8641 0x809000
- 256Kbyte L2 cache
- Changes over v1:
applied to 85xx next
- k
Kumar Gala
Poonam Aggrwal
