[U-Boot] [PATCH v2 1/2] APM82xxx: Add CPU and other peripheral support
APM82XXX is a new line of SoCs which are derivatives of PPC44X family of processors.
This patch adds support of CPU, cache, tlb, 32k ocm, bootstraps, PLB AHB bus, DDR and Some common register definitions.
Signed-off-by: Tirumala R Marri tmarri@apm.com --- V1: * Squash some of the patches. * add space between "||" and "". * Add spaces around operators. * Unsigned int to u32. * Add empty line which was removed. * remove warning "unused variable" in cpu_init.c V2: * Removed Defines added to 405ex. --- arch/powerpc/cpu/ppc4xx/cpu.c | 35 ++++++++++++- arch/powerpc/cpu/ppc4xx/cpu_init.c | 8 ++- arch/powerpc/cpu/ppc4xx/speed.c | 85 ++++++++++++++++++++++++++++++- arch/powerpc/cpu/ppc4xx/start.S | 10 +++- arch/powerpc/include/asm/ppc4xx-ebc.h | 4 ++ arch/powerpc/include/asm/ppc4xx-isram.h | 8 ++- arch/powerpc/include/asm/ppc4xx-sdram.h | 12 ++-- arch/powerpc/include/asm/ppc4xx-uic.h | 5 +- arch/powerpc/include/asm/processor.h | 1 + include/ppc440.h | 57 ++++++++++++++++++++- include/ppc4xx.h | 7 ++- 11 files changed, 207 insertions(+), 25 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/cpu.c b/arch/powerpc/cpu/ppc4xx/cpu.c index 851065c..5fe5d8c 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu.c +++ b/arch/powerpc/cpu/ppc4xx/cpu.c @@ -80,7 +80,8 @@ static int pci_async_enabled(void) #endif /* CONFIG_PCI */
#if defined(CONFIG_PCI) && !defined(CONFIG_IOP480) && \ - !defined(CONFIG_405) && !defined(CONFIG_405EX) + !defined(CONFIG_405) && !defined(CONFIG_405EX) && \ + !defined(CONFIG_APM82XXX) int pci_arbiter_enabled(void) { #if defined(CONFIG_405GP) @@ -250,6 +251,21 @@ static char *bootstrap_str[] = { }; static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'G', 'F', 'H' }; #endif +#if defined(CONFIG_APM82XXX) +#define SDR0_PINSTP_SHIFT 29 +static char *bootstrap_str[] = { + "RESERVED", + "RESERVED", + "RESERVED", + "NAND (8 bits)", + "NOR (8 bits)", + "NOR (8 bits) w/PLL Bypassed", + "I2C (Addr 0x54)", + "I2C (Addr 0x52)", +}; +static char bootstrap_char[] = { 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H' }; +#endif +
#if defined(SDR0_PINSTP_SHIFT) static int bootstrap_option(void) @@ -285,7 +301,7 @@ int checkcpu (void) uint pvr = get_pvr(); ulong clock = gd->cpu_clk; char buf[32]; -#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || defined(CONFIG_APM82XXX) u32 reg; #endif
@@ -304,6 +320,8 @@ int checkcpu (void)
#if defined(CONFIG_XILINX_440) puts("IBM PowerPC 4"); +#elif defined(CONFIG_APM82XXX) + puts("APM PowerPC APM82"); #else puts("AMCC PowerPC 4"); #endif @@ -316,7 +334,7 @@ int checkcpu (void) #if defined(CONFIG_440) #if defined(CONFIG_460EX) || defined(CONFIG_460GT) puts("60"); -#else +#elif !defined(CONFIG_APM82XXX) puts("40"); #endif #endif @@ -598,7 +616,18 @@ int checkcpu (void) puts("GX Rev. A"); strcpy(addstr, "No Security support"); break; +#if defined(CONFIG_APM82XXX) + case PVR_APM82XXX_RA: + mfsdr(SDR0_ECID3, reg); + if (reg & 0x00200000) + puts("181 Rev. A");
+ if (reg & 0x00100000) + strcpy(addstr, "No Security support"); + else + strcpy(addstr, "Security support"); + break; +#endif case PVR_VIRTEX5: puts("x5 VIRTEX5"); break; diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index c04eede..8765059 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -222,13 +222,15 @@ void reconfigure_pll(u32 new_cpu_freq) void cpu_init_f (void) { -#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || defined(CONFIG_460EX) +#if defined(CONFIG_WATCHDOG) || defined(CONFIG_440GX) || \ + defined(CONFIG_460EX) u32 val; #endif
reconfigure_pll(CONFIG_SYS_PLL_RECONFIG);
-#if (defined(CONFIG_405EP) || defined (CONFIG_405EX)) && !defined(CONFIG_SYS_4xx_GPIO_TABLE) +#if (defined(CONFIG_405EP) || defined(CONFIG_405EX)) && \ + !defined(CONFIG_SYS_4xx_GPIO_TABLE) && !defined(CONFIG_APM82XXX) /* * GPIO0 setup (select GPIO or alternate function) */ @@ -384,7 +386,7 @@ cpu_init_f (void) #if defined(CONFIG_405EX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) /* * Set PLB4 arbiter (Segment 0 and 1) to 4 deep pipeline read */ diff --git a/arch/powerpc/cpu/ppc4xx/speed.c b/arch/powerpc/cpu/ppc4xx/speed.c index 906face..b613275 100644 --- a/arch/powerpc/cpu/ppc4xx/speed.c +++ b/arch/powerpc/cpu/ppc4xx/speed.c @@ -189,7 +189,7 @@ ulong get_PCI_freq (void) #elif defined(CONFIG_440)
#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) static u8 pll_fwdv_multi_bits[] = { /* values for: 1 - 16 */ 0x00, 0x01, 0x0f, 0x04, 0x09, 0x0a, 0x0d, 0x0e, 0x03, 0x0c, @@ -250,6 +250,88 @@ u32 get_cpr0_fbdv(unsigned long cpr_reg_fbdv) return 0; }
+#if defined(CONFIG_APM82XXX) + +/* + * Specific for APM82XXX + * Change: + * PLL registers reflect the current PLL setting of the chip. + * So unlike previous implementation that reads bootstrap + * registers to determine system clocking information, this + * implementation directly extracts the information from + * current PLL registers values. + */ +void get_sys_info(sys_info_t *sysInfo) +{ + unsigned long plld; + unsigned long temp; + unsigned long mul; + unsigned long cpudv; + unsigned long plb2dv; + unsigned long ddr2dv; + + /* Calculate Forward divisor A and Feeback divisor */ + mfcpr(CPR0_PLLD, plld); + + temp = CPR0_PLLD_FWDVA(plld); + sysInfo->pllFwdDivA = get_cpr0_fwdv(temp); + + temp = CPR0_PLLD_FDV(plld); + sysInfo->pllFbkDiv = get_cpr0_fbdv(temp); + + /* Calculate OPB clock divisor */ + mfcpr(CPR0_OPBD, temp); + temp = CPR0_OPBD_OPBDV(temp); + sysInfo->pllOpbDiv = temp ? temp : 4; + + /* Calculate Peripheral clock divisor */ + mfcpr(CPR0_PERD, temp); + temp = CPR0_PERD_PERDV(temp); + sysInfo->pllExtBusDiv = temp ? temp : 4; + + /* Calculate CPU clock divisor */ + mfcpr(CPR0_CPUD, temp); + temp = CPR0_CPUD_CPUDV(temp); + cpudv = temp ? temp : 8; + + /* Calculate PLB2 clock divisor */ + mfcpr(CPR0_PLB2D, temp); + temp = CPR0_PLB2D_PLB2DV(temp); + plb2dv = temp ? temp : 4; + + /* Calculate DDR2 clock divisor */ + mfcpr(CPR0_DDR2D, temp); + temp = CPR0_DDR2D_DDR2DV(temp); + ddr2dv = temp ? temp : 4; + + /* Calculate 'M' based on feedback source */ + mfcpr(CPR0_PLLC, temp); + temp = CPR0_PLLC_SEL(temp); + if (temp == 0) { + /* PLL internal feedback */ + mul = sysInfo->pllFbkDiv; + } else { + /* PLL PerClk feedback */ + mul = sysInfo->pllFwdDivA * sysInfo->pllFbkDiv * cpudv + * plb2dv * 2 * sysInfo->pllOpbDiv * + sysInfo->pllExtBusDiv; + } + + /* Now calculate the individual clocks */ + sysInfo->freqVCOMhz = (mul * CONFIG_SYS_CLK_FREQ) + (mul >> 1); + sysInfo->freqProcessor = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv; + sysInfo->freqPLB = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / plb2dv / 2; + sysInfo->freqOPB = sysInfo->freqPLB / sysInfo->pllOpbDiv; + sysInfo->freqEBC = sysInfo->freqOPB / sysInfo->pllExtBusDiv; + sysInfo->freqDDR = sysInfo->freqVCOMhz / + sysInfo->pllFwdDivA / cpudv / ddr2dv / 2; + sysInfo->freqUART = sysInfo->freqPLB; +} + +#else + /* * AMCC_TODO: verify this routine against latest EAS, cause stuff changed * with latest EAS @@ -307,6 +389,7 @@ void get_sys_info (sys_info_t * sysInfo)
return; } +#endif
#elif defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 5296dad..e3210b0 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -700,7 +700,8 @@ _start: defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460SX) mtdcr L2_CACHE_CFG,r0 /* Ensure L2 Cache is off */ -#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX) lis r1, 0x0000 ori r1,r1,0x0008 /* Set L2_CACHE_CFG[RDBW]=1 */ mtdcr L2_CACHE_CFG,r1 @@ -728,7 +729,8 @@ _start: lis r1, 0x8003 ori r1,r1, 0x0980 /* fourth 64k */ mtdcr ISRAM0_SB3CR,r1 -#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_440SPE) || defined(CONFIG_460EX) || \ + defined(CONFIG_460GT) || defined(CONFIG_APM82XXX) lis r1,0x0000 /* BAS = X_0000_0000 */ ori r1,r1,0x0984 /* first 64k */ mtdcr ISRAM0_SB0CR,r1 @@ -752,7 +754,11 @@ _start: mtdcr ISRAM1_PMEG,r1
lis r1,0x0004 /* BAS = 4_0004_0000 */ +#if defined(CONFIG_APM82XXX) /* APM82XXX only has 32KB of OCM */ + ori r1,r1,0x0784 /* 32k */ +#else ori r1,r1,0x0984 /* 64k */ +#endif mtdcr ISRAM1_SB0CR,r1 #endif #elif defined(CONFIG_460SX) diff --git a/arch/powerpc/include/asm/ppc4xx-ebc.h b/arch/powerpc/include/asm/ppc4xx-ebc.h index 9c17e46..245e487 100644 --- a/arch/powerpc/include/asm/ppc4xx-ebc.h +++ b/arch/powerpc/include/asm/ppc4xx-ebc.h @@ -73,6 +73,10 @@ #define EBC_NUM_BANKS 3 #endif
+#if defined(CONFIG_APM82XXX) +#define EBC_NUM_BANKS 3 +#endif + /* Bank Configuration Register */ #define EBC_BXCR(n) (n) #define EBC_BXCR_BANK_SIZE(n) (0x100000 << (((n) & EBC_BXCR_BS_MASK) >> 17)) diff --git a/arch/powerpc/include/asm/ppc4xx-isram.h b/arch/powerpc/include/asm/ppc4xx-isram.h index d6d17ac..fa9e164 100644 --- a/arch/powerpc/include/asm/ppc4xx-isram.h +++ b/arch/powerpc/include/asm/ppc4xx-isram.h @@ -25,7 +25,8 @@ /* * Internal SRAM */ -#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_APM82XXX) #define ISRAM0_DCR_BASE 0x380 #else #define ISRAM0_DCR_BASE 0x020 @@ -42,7 +43,8 @@ #define ISRAM0_REVID (ISRAM0_DCR_BASE+0x09) /* SRAM bus revision id reg */ #define ISRAM0_DPC (ISRAM0_DCR_BASE+0x0a) /* SRAM data parity check reg */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX) #define ISRAM1_DCR_BASE 0x0B0 #define ISRAM1_SB0CR (ISRAM1_DCR_BASE+0x00) /* SRAM1 bank config 0*/ #define ISRAM1_BEAR (ISRAM1_DCR_BASE+0x04) /* SRAM1 bus error addr reg */ @@ -60,7 +62,7 @@ #if defined (CONFIG_440GX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) #define L2_CACHE_BASE 0x030 #define L2_CACHE_CFG (L2_CACHE_BASE+0x00) /* L2 Cache Config */ #define L2_CACHE_CMD (L2_CACHE_BASE+0x01) /* L2 Cache Command */ diff --git a/arch/powerpc/include/asm/ppc4xx-sdram.h b/arch/powerpc/include/asm/ppc4xx-sdram.h index 4ec1ef8..fcda187 100644 --- a/arch/powerpc/include/asm/ppc4xx-sdram.h +++ b/arch/powerpc/include/asm/ppc4xx-sdram.h @@ -292,7 +292,7 @@ */ #if defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) #define SDRAM_RXBAS_SDBA_MASK 0xFFE00000 /* Base address */ #define SDRAM_RXBAS_SDBA_ENCODE(n) ((u32)(((phys_size_t)(n) >> 2) & 0xFFE00000)) #define SDRAM_RXBAS_SDBA_DECODE(n) ((((phys_size_t)(n)) & 0xFFE00000) << 2) @@ -365,7 +365,7 @@ /* * Memory controller registers */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM82XXX) #define SDRAM_BESR 0x00 /* PLB bus error status (read/clear) */ #define SDRAM_BESRT 0x01 /* PLB bus error status (test/set) */ #define SDRAM_BEARL 0x02 /* PLB bus error address low */ @@ -375,9 +375,9 @@ #define SDRAM_PLBOPT 0x08 /* PLB slave options */ #define SDRAM_PUABA 0x09 /* PLB upper address base */ #define SDRAM_MCSTAT 0x1F /* memory controller status */ -#else /* CONFIG_405EX */ +#else /* CONFIG_405EX || CONFIG_APM82XXX */ #define SDRAM_MCSTAT 0x14 /* memory controller status */ -#endif /* CONFIG_405EX */ +#endif /* CONFIG_405EX || CONFIG_APM82XXX */ #define SDRAM_MCOPT1 0x20 /* memory controller options 1 */ #define SDRAM_MCOPT2 0x21 /* memory controller options 2 */ #define SDRAM_MODT0 0x22 /* on die termination for bank 0 */ @@ -423,12 +423,12 @@ #define SDRAM_MEMODE 0x89 /* memory extended mode */ #define SDRAM_ECCES 0x98 /* ECC error status */ #define SDRAM_CID 0xA4 /* core ID */ -#ifndef CONFIG_405EX +#if !defined(CONFIG_405EX) && !defined(CONFIG_APM82XXX) #define SDRAM_RID 0xA8 /* revision ID */ #endif #define SDRAM_FCSR 0xB0 /* feedback calibration status */ #define SDRAM_RTSR 0xB1 /* run time status tracking */ -#ifdef CONFIG_405EX +#if defined(CONFIG_405EX) || defined(CONFIG_APM82XXX) #define SDRAM_RID 0xF8 /* revision ID */ #endif
diff --git a/arch/powerpc/include/asm/ppc4xx-uic.h b/arch/powerpc/include/asm/ppc4xx-uic.h index 782d045..787e9f7 100644 --- a/arch/powerpc/include/asm/ppc4xx-uic.h +++ b/arch/powerpc/include/asm/ppc4xx-uic.h @@ -31,7 +31,7 @@ */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) #define UIC_MAX 4 #elif defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EX) @@ -252,7 +252,8 @@ #define VECNUM_ETH0 (32 + 28) #endif /* CONFIG_440SPE */
-#if defined(CONFIG_460EX) || defined(CONFIG_460GT) +#if defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX) /* UIC 0 */ #define VECNUM_UIC2NCI 10 #define VECNUM_UIC2CI 11 diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 84a1e2e..c58492d 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -916,6 +916,7 @@ #define PVR_460SX_RA_V1 0x13541801 /* 460SX rev A Variant 1 Security disabled */ #define PVR_460GX_RA 0x13541802 /* 460GX rev A */ #define PVR_460GX_RA_V1 0x13541803 /* 460GX rev A Variant 1 Security disabled */ +#define PVR_APM82XXX_RA 0x12C41C80 /* APM82XXX rev A */ #define PVR_601 0x00010000 #define PVR_602 0x00050000 #define PVR_603 0x00030000 diff --git a/include/ppc440.h b/include/ppc440.h index c807dda..b5c1832 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -58,6 +58,25 @@ | Clocking Controller +----------------------------------------------------------------------------*/ /* values for clkcfga register - indirect addressing of these regs */ +#if defined(CONFIG_APM82XXX) +#define CPR0_CLKUPD 0x0020 +#define CPR0_PLLC 0x0040 +#define CPR0_PLLC_SEL(pllc) (((pllc) & 0x01000000) >> 24) +#define CPR0_PLLD 0x0060 +#define CPR0_PLLD_FDV(plld) (((plld) & 0xff000000) >> 24) +#define CPR0_PLLD_FWDVA(plld) (((plld) & 0x000f0000) >> 16) +#define CPR0_CPUD 0x0080 +#define CPR0_CPUD_CPUDV(cpud) (((cpud) & 0x07000000) >> 24) +#define CPR0_PLB2D 0x00a0 +#define CPR0_PLB2D_PLB2DV(plb2d) (((plb2d) & 0x06000000) >> 25) +#define CPR0_OPBD 0x00c0 +#define CPR0_OPBD_OPBDV(opbd) (((opbd) & 0x03000000) >> 24) +#define CPR0_PERD 0x00e0 +#define CPR0_PERD_PERDV(perd) (((perd) & 0x03000000) >> 24) +#define CPR0_DDR2D 0x0100 +#define CPR0_DDR2D_DDR2DV(ddr2d) (((ddr2d) & 0x06000000) >> 25) +#define CLK_ICFG 0x0140 +#else #define CPR0_PLLC 0x0040 #define CPR0_PLLD 0x0060 #define CPR0_PRIMAD0 0x0080 @@ -67,6 +86,7 @@ #define CPR0_MALD 0x0100 #define CPR0_SPCID 0x0120 #define CPR0_ICFG 0x0140 +#endif /*if defined(CONFIG_APM82XXX) */
/* 440EPX boot strap options */ #define BOOT_STRAP_OPTION_A 0x00000000 @@ -1275,7 +1295,36 @@ #define SDR0_AHB_CFG 0x370 #define SDR0_USB2HOST_CFG 0x371 #endif /* CONFIG_460EX || CONFIG_460GT */ +#if defined(CONFIG_APM82XXX) + +#define SDR0_DDR0 0x00E1 +#define SDR0_DDR0_DDRM_ENCODE(n) ((((u32)(n)) & 0x03) << 29) +#define SDR0_DDR0_DDRM_DECODE(n) ((((u32)(n)) >> 29) & 0x03) +#define SDR0_DDR0_TUNE_ENCODE(n) ((((u32)(n)) & 0x2FF) <<0) +#define SDR0_DDR0_TUNE_DECODE(n) ((((u32)(n)) >> 0) & 0x2FF) + +#define SDR_SDSTP1_RL_DECODE(x) (((x) & 0x000C0000) >> 18) +#define SDR_SDSTP1_RL_EBC 0x0 +#define SDR_SDSTP1_RL_NDFC 0x2 + +/* ECID */ +#define SDR0_ECID0 0x0080 +#define SDR0_ECID1 0x0081 +#define SDR0_ECID2 0x0082 +#define SDR0_ECID3 0x0083 + +/* AHB config. */ +#define AHB_TOP 0xA4 +#define AHB_BOT 0xA5 +#define SDR0_AHB_CFG 0x370 + +/* DDR SDRAM Controller clock (CPR register)*/ +#define SDR0_DDRCE 0x00E0 /* SDR register */ +#define CPR0_DDR2D 0x0100 /* CPR register */ +#define CPR0_DDR2D_DDR2DV_ENCODE(n) ((((u32)(n)) & 0x03) << 25) +#define CPR0_DDR2D_DDR2DV_DECODE(n) ((((u32)(n)) >> 25) & 0x03)
+#endif #define SDR0_SDCS_SDD (0x80000000 >> 31)
#if defined(CONFIG_440GP) @@ -1517,7 +1566,8 @@ #define SDR0_EBC0 0x00000100 #define SDR0_SDSTP2 0x00004001 #define SDR0_SDSTP3 0x00004001 -#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) +#elif defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX)
#define SDR0_SRST0 SDR0_SRST /* for compatability reasons */ #define SDR0_SRST0_BGO 0x80000000 /* PLB to OPB bridge */ @@ -1909,9 +1959,12 @@
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_460EX) || defined(CONFIG_460GT) + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX) #define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000B00) +#if !defined(CONFIG_APM82XXX) #define GPIO1_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000C00) +#endif
#define GPIO0_OR (GPIO0_BASE+0x0) #define GPIO0_TCR (GPIO0_BASE+0x4) diff --git a/include/ppc4xx.h b/include/ppc4xx.h index ee30a4c..3224d5f 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -44,14 +44,15 @@ #if defined(CONFIG_405EX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX) #define CONFIG_SDRAM_PPC4xx_IBM_DDR2 /* IBM DDR(2) controller */ #endif
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ - defined(CONFIG_460EX) || defined(CONFIG_460GT) + defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ + defined(CONFIG_APM82XXX) #define CONFIG_NAND_NDFC #endif
@@ -61,7 +62,7 @@ defined(CONFIG_440GR) || defined(CONFIG_440GRX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ - defined(CONFIG_460SX) + defined(CONFIG_460SX) || defined(CONFIG_APM82XXX)
#define PLB_ARBITER_BASE 0x80
Dear tmarri@apm.com,
- puts("APM PowerPC APM82");
Hm... is this APM82? Official press releases refer to this as APM821xx? Or ist it APM82xxx?
On the other hand, this seems to be a 464 core, so should we not print 464 here?
This gets confusing.
If you don't decide to print "64" here, then please pull all the APM82??? code into a separate #ifdef block.
Why do you modify this line? Coding style fixes should go separate.
- !defined(CONFIG_SYS_4xx_GPIO_TABLE) && !defined(CONFIG_APM82XXX)
Please keep list sorted.
- Specific for APM82XXX
- Change:
- PLL registers reflect the current PLL setting of the chip.
- So unlike previous implementation that reads bootstrap
- registers to determine system clocking information, this
- implementation directly extracts the information from
- current PLL registers values.
Please remove references to "previous implementation" which is unknown here anyway.
lis r1,0x0000 /* BAS = X_0000_0000 */ ori r1,r1,0x0984 /* first 64k */defined(CONFIG_460GT) || defined(CONFIG_APM82XXX)
Should the size be adjusted here, too?
- ori r1,r1,0x0784 /* 32k */
Please get rid of these magic numbers and add a #define for a symbolic constant so the code becomes readable, and the selection can be done on a per-CPU base, i. e. without needing #ifdef's here.
Hm... you are adding a number of large blocks of code, all #ifdef'ed.
This is ugly, difficult to read and difficult to maintain.
Why not adding a new file include/apm82xxx.h instead?
Mr Wolfgang,
[Marri] Interesting point, For all other processors we were printing SoC name not the CPU core name. APM82xxx is SoC name.
[Marri] If we create new file it would cause too many changes in the common files. When more and more APM8xxxx processors with new registers definitions being released At that point we can create separate file. Please suggest ?
Regards, Marri
Dear Tirumala Marri,
OK.
Hm.., the whole CPU ID code in "arch/powerpc/cpu/ppc4xx/cpu.c" has become a mess.
Stefan:
is there any deeper logic for the repeated #ifdef's there, when we finally do a switch on the PVR anyway?
Instead of painstakingly concatenating "AMCC PowerPC 4" with "05" and later "GP Rev. B" we could shrink this into a plain
case PVR_405GP_RB: puts("AMCC PowerPC 405GP Rev. B"); break; Or am I missing something?
Let's get rid of all these nested #ifdef's...
If there are plans for more and more APM8xxxx processors with new registers definitions to be released we should not create a mess now and later go into efforts to clean it up again, but start with a separate register definitions file apm82xxx.h now.
Hi Wolfgang,
Stefan:
IIRC, then the main reason for this is the code size reduction. Using your version would increase the code size quite a bit. But I concur, it would be much better readable. So just let me know, and I'll try to come up with a patch cleaning this up a bit.
As described in some comments, the problem is that some SoC's have the same PVR (for example 440EP rev C and 440GR rev B have same PVR). I have no idea how this identification could be solved without such ifdef's.
But you are right. Some of the ifdef's can be removed. Again, this would also result in a bigger image size though.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
Maybe some common parts (like "AMCC PowerPC ") could be split off.
For the rest, the compelex code needs also space, so I'm not sure about the end result.
I see.
Really? We should measure the effect.
Hi Wolfgang,
On Friday 03 September 2010 10:32:53 Wolfgang Denk wrote:
Dear Stefan Roese,
Yes, this would help a bit. I'll add this on list.
I see.
I'll work on this a bit in the near future and will post my findings.
Cheers, Stefan
Mr Wolfgang,
[Marri] You are correct APM821XX is right name.
[Marri] Sure will do.
[Marri] No, It is same as other SoCs.
[Marri] I will define CONFIG_SYS_OCM_SIZE . But for now this is only added
Bluestone.h. I need to remove "#if defined(CONFIG_APM821XX) I will have to Add CONFIG_SYS_OCM_SIZE to all the board config files which are based on 460Ex and 460GT. I think that would be completely different patch.
[Marri] I will work on this .
Regards, Marri
Hi Marri,
+#else
[Marri] I will define CONFIG_SYS_OCM_SIZE . But for now this is only added Bluestone.h. I need to remove "#if defined(CONFIG_APM821XX) I will have to Add CONFIG_SYS_OCM_SIZE to all the board config files which are based on 460Ex and 460GT. I think that would be completely different patch.
Since the OCM size is SoC specific, I would prefer not to put such a define in each and every board config header, but in a SoC header. There you could automatically select the OCM size depending on the SoC type. No change in the board config header needed.
Cheers, Stefan
Stefan Roese
Tirumala Marri
tmarriļ¼ apm.com
