[PATCH v1] imx: imx8qxp: imx8qxp_mek switch to binman
Switch to use binman pack images
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com --- arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi | 127 +++++++++++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 1 + board/freescale/imx8qxp_mek/imximage.cfg | 3 +- configs/imx8qxp_mek_defconfig | 2 + doc/board/nxp/imx8qxp_mek.rst | 2 +- 5 files changed, 132 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi index ae037c7550..073a401a1c 100644 --- a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi @@ -3,6 +3,133 @@ * Copyright 2018, 2021 NXP */
+/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + u-boot-spl-ddr { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8image -e 0x100000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + fit,fdt-list = "of-list"; + #address-cells = <1>; + + images { + uboot { + arch = "arm64"; + compression = "none"; + description = "U-Boot (64-bit)"; + load = <CONFIG_SYS_TEXT_BASE>; + type = "standalone"; + + uboot-blob { + filename = "u-boot-nodtb.bin"; + type = "blob-ext"; + }; + }; + + atf { + arch = "arm64"; + compression = "none"; + description = "ARM Trusted Firmware"; + entry = <0x00910000>; + load = <0x00091000>; + type = "firmware"; + + atf-blob { + filename = "bl31.bin"; + type = "atf-bl31"; + }; + }; + + scfw { + arch = "arm64"; + compression = "none"; + description = "System Controler Firmware"; + type = "firmware"; + + scfw_blob { + filename = "mx8qx-mek-scfw-tcm.bin"; + type = "blob-ext"; + }; + }; + + seco { + arch = "arm64"; + compression = "none"; + description = "Seco Firmware"; + type = "firmware"; + + seco_blob { + filename = "mx8qxc0-ahab-container.img"; + type = "blob-ext"; + }; + }; + + fdt { + type = "flat_dt"; + compression = "none"; + + uboot-fdt-blob { + filename = "u-boot.dtb"; + type = "blob-ext"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + fdt = "fdt"; + firmware = "uboot"; + loadables = "atf"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl { + filename = "spl.bin"; + offset = <0x0>; + type = "blob-ext"; + }; + }; +}; + &{/imx8qx-pm} {
u-boot,dm-spl; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index d423cf8563..23a7fcf361 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -90,6 +90,7 @@ config TARGET_IMX8QM_ROM7720_A1
config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" + select BINMAN select BOARD_LATE_INIT select IMX8QXP select FSL_CAAM diff --git a/board/freescale/imx8qxp_mek/imximage.cfg b/board/freescale/imx8qxp_mek/imximage.cfg index 89a4736ab7..88d6955a9e 100644 --- a/board/freescale/imx8qxp_mek/imximage.cfg +++ b/board/freescale/imx8qxp_mek/imximage.cfg @@ -7,8 +7,7 @@ */
-/* Boot from SD, sector size 0x400 */ -BOOT_FROM SD 0x400 +BOOT_FROM sd /* SoC type IMX8QX */ SOC_TYPE IMX8QX /* Append seco container image */ diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 73600c5a8c..0e22f13c7f 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -23,6 +23,8 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/doc/board/nxp/imx8qxp_mek.rst b/doc/board/nxp/imx8qxp_mek.rst index 215627cfa6..708db1952e 100644 --- a/doc/board/nxp/imx8qxp_mek.rst +++ b/doc/board/nxp/imx8qxp_mek.rst @@ -50,7 +50,7 @@ Build U-Boot .. code-block:: bash
$ make imx8qxp_mek_defconfig - $ make flash.bin + $ make
Flash the binary into the SD card ---------------------------------
- Copyright 2018, 2021 NXP
- binman: binman {
multiple-images;
+&binman {
- u-boot-spl-ddr {
align = <4>;
align-size = <4>;
pad-byte = <0xff>;
u-boot-spl {
align-end = <4>;
- spl {
mkimage {
blob {
- itb {
fit {
images {
uboot {
arch = "arm64";
uboot-blob {
type = "blob-ext";
atf {
arch = "arm64";
type = "firmware";
atf-blob {
type = "atf-bl31";
scfw {
arch = "arm64";
type = "firmware";
scfw_blob {
type = "blob-ext";
seco {
arch = "arm64";
type = "firmware";
seco_blob {
type = "blob-ext";
fdt {
type = "flat_dt";
uboot-fdt-blob {
type = "blob-ext";
configurations {
default = "conf";
conf {
fdt = "fdt";
firmware = "uboot";
loadables = "atf";
- imx-boot {
pad-byte = <0x00>;
spl {
offset = <0x0>;
type = "blob-ext";
&{/imx8qx-pm} {
- select BINMAN select BOARD_LATE_INIT select IMX8QXP select FSL_CAAM
- $ make flash.bin
- $ make
This needs switch to use imx container for binman in the end, but it should be ok for now to use FIT to pack the images.
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Oliver Graute
Peng Fan
