[PATCH] ARM: dts: Fix node status to "okay" on TI boards
As per Device Tree core schema [1], status parameter of nodes can be either "okay" or "disabled".
U-boot Driver Model does not recognize status="ok" and treats the node as disabled.
Signed-off-by: Roger Quadros rogerq@kernel.org --- arch/arm/dts/am3517-evm-ui.dtsi | 4 ++-- arch/arm/dts/am3517-evm.dts | 2 +- arch/arm/dts/am437x-gp-evm.dts | 2 +- arch/arm/dts/am43x-epos-evm.dts | 2 +- arch/arm/dts/am57xx-beagle-x15-common.dtsi | 6 +++--- arch/arm/dts/da850-evm.dts | 2 +- arch/arm/dts/dra7-evm.dts | 2 +- arch/arm/dts/dra72-evm-common.dtsi | 6 +++--- arch/arm/dts/keystone-k2e-evm.dts | 2 +- arch/arm/dts/keystone-k2hk-evm.dts | 2 +- arch/arm/dts/keystone-k2l-evm.dts | 2 +- arch/arm/dts/omap3-beagle-xm.dts | 4 ++-- arch/arm/dts/omap3-beagle.dts | 6 +++--- arch/arm/dts/omap3-igep0020-common.dtsi | 2 +- arch/arm/dts/omap3-panel-sharp-ls037v7dw01.dtsi | 2 +- arch/arm/dts/omap34xx.dtsi | 2 +- arch/arm/dts/omap36xx.dtsi | 2 +- arch/arm/dts/omap4-panda-common.dtsi | 6 +++--- arch/arm/dts/omap4-sdp.dts | 8 ++++---- arch/arm/dts/omap5-board-common.dtsi | 4 ++-- 20 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/am3517-evm-ui.dtsi b/arch/arm/dts/am3517-evm-ui.dtsi index e841918c1c..54aa2522aa 100644 --- a/arch/arm/dts/am3517-evm-ui.dtsi +++ b/arch/arm/dts/am3517-evm-ui.dtsi @@ -186,14 +186,14 @@ };
&mcbsp1 { - status = "ok"; + status = "okay"; #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcbsp1_pins>; };
&mcbsp2 { - status = "ok"; + status = "okay"; #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcbsp2_pins>; diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts index 3527c0f2df..935c471c97 100644 --- a/arch/arm/dts/am3517-evm.dts +++ b/arch/arm/dts/am3517-evm.dts @@ -193,7 +193,7 @@ };
&dss { - status = "ok"; + status = "okay";
pinctrl-names = "default"; pinctrl-0 = <&dss_dpi_pins>; diff --git a/arch/arm/dts/am437x-gp-evm.dts b/arch/arm/dts/am437x-gp-evm.dts index 3c500d52db..21f7691f49 100644 --- a/arch/arm/dts/am437x-gp-evm.dts +++ b/arch/arm/dts/am437x-gp-evm.dts @@ -742,7 +742,7 @@ };
pinctrl-names = "default"; pinctrl-0 = <&dss_pins>; diff --git a/arch/arm/dts/am43x-epos-evm.dts b/arch/arm/dts/am43x-epos-evm.dts index 65f157ed59..b940bc6ccf 100644 --- a/arch/arm/dts/am43x-epos-evm.dts +++ b/arch/arm/dts/am43x-epos-evm.dts @@ -752,7 +752,7 @@ };
pinctrl-names = "default"; pinctrl-0 = <&dss_pins>; diff --git a/arch/arm/dts/am57xx-beagle-x15-common.dtsi b/arch/arm/dts/am57xx-beagle-x15-common.dtsi index d6b94d528f..1912ea9a15 100644 --- a/arch/arm/dts/am57xx-beagle-x15-common.dtsi +++ b/arch/arm/dts/am57xx-beagle-x15-common.dtsi @@ -528,13 +528,13 @@ };
vdda_video-supply = <&ldoln_reg>; };
&hdmi { - status = "ok"; + status = "okay"; vdda-supply = <&ldo4_reg>;
port { @@ -545,7 +545,7 @@ };
&pcie1_rc { - status = "ok"; + status = "okay"; gpios = <&gpio2 8 GPIO_ACTIVE_LOW>; };
diff --git a/arch/arm/dts/da850-evm.dts b/arch/arm/dts/da850-evm.dts index f04bc3e153..b331cefd18 100644 --- a/arch/arm/dts/da850-evm.dts +++ b/arch/arm/dts/da850-evm.dts @@ -405,7 +405,7 @@ &aemif { pinctrl-names = "default"; pinctrl-0 = <&nand_pins>; - status = "ok"; + status = "okay"; cs3 { #address-cells = <2>; #size-cells = <1>; diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index 43de9638e3..8e9a1a80a8 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -501,7 +501,7 @@ };
&dcan1 { - status = "ok"; + status = "okay"; pinctrl-names = "default", "sleep", "active"; pinctrl-0 = <&dcan1_pins_sleep>; pinctrl-1 = <&dcan1_pins_sleep>; diff --git a/arch/arm/dts/dra72-evm-common.dtsi b/arch/arm/dts/dra72-evm-common.dtsi index 2e485a13df..964e5e9b90 100644 --- a/arch/arm/dts/dra72-evm-common.dtsi +++ b/arch/arm/dts/dra72-evm-common.dtsi @@ -430,7 +430,7 @@ };
&dcan1 { - status = "ok"; + status = "okay"; pinctrl-names = "default", "sleep", "active"; pinctrl-0 = <&dcan1_pins_sleep>; pinctrl-1 = <&dcan1_pins_sleep>; @@ -499,11 +499,11 @@ };
&dss { - status = "ok"; + status = "okay"; };
port { hdmi_out: endpoint { diff --git a/arch/arm/dts/keystone-k2e-evm.dts b/arch/arm/dts/keystone-k2e-evm.dts index 9288df21ce..bb197e133e 100644 --- a/arch/arm/dts/keystone-k2e-evm.dts +++ b/arch/arm/dts/keystone-k2e-evm.dts @@ -142,7 +142,7 @@ };
&mdio { - status = "ok"; + status = "okay"; ethphy0: ethernet-phy@0 { compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; reg = <0>; diff --git a/arch/arm/dts/keystone-k2hk-evm.dts b/arch/arm/dts/keystone-k2hk-evm.dts index 84c58d75ad..acfcaff0a8 100644 --- a/arch/arm/dts/keystone-k2hk-evm.dts +++ b/arch/arm/dts/keystone-k2hk-evm.dts @@ -170,7 +170,7 @@ };
&mdio { - status = "ok"; + status = "okay"; ethphy0: ethernet-phy@0 { compatible = "marvell,88E1111", "ethernet-phy-ieee802.3-c22"; reg = <0>; diff --git a/arch/arm/dts/keystone-k2l-evm.dts b/arch/arm/dts/keystone-k2l-evm.dts index 91cefdf2aa..ca049ba81b 100644 --- a/arch/arm/dts/keystone-k2l-evm.dts +++ b/arch/arm/dts/keystone-k2l-evm.dts @@ -119,7 +119,7 @@ };
&mdio { - status = "ok"; + status = "okay"; ethphy0: ethernet-phy@0 { compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; reg = <0>; diff --git a/arch/arm/dts/omap3-beagle-xm.dts b/arch/arm/dts/omap3-beagle-xm.dts index 0349fcc9dc..8461159baf 100644 --- a/arch/arm/dts/omap3-beagle-xm.dts +++ b/arch/arm/dts/omap3-beagle-xm.dts @@ -379,7 +379,7 @@ };
pinctrl-names = "default"; pinctrl-0 = < @@ -396,7 +396,7 @@ };
&venc { - status = "ok"; + status = "okay";
vdda-supply = <&vdac>;
diff --git a/arch/arm/dts/omap3-beagle.dts b/arch/arm/dts/omap3-beagle.dts index 3ca8991a6c..4ceee2ba19 100644 --- a/arch/arm/dts/omap3-beagle.dts +++ b/arch/arm/dts/omap3-beagle.dts @@ -353,7 +353,7 @@ };
pinctrl-names = "default"; pinctrl-0 = <&dss_dpi_pins>; @@ -367,7 +367,7 @@ };
@@ -380,7 +380,7 @@ };
&gpmc { - status = "ok"; + status = "okay"; ranges = <0 0 0x30000000 0x1000000>; /* CS0 space, 16MB */
/* Chip select 0 */ diff --git a/arch/arm/dts/omap3-igep0020-common.dtsi b/arch/arm/dts/omap3-igep0020-common.dtsi index ecbec23af4..d62481dacd 100644 --- a/arch/arm/dts/omap3-igep0020-common.dtsi +++ b/arch/arm/dts/omap3-igep0020-common.dtsi @@ -248,7 +248,7 @@ };
port { dpi_out: endpoint { diff --git a/arch/arm/dts/omap3-panel-sharp-ls037v7dw01.dtsi b/arch/arm/dts/omap3-panel-sharp-ls037v7dw01.dtsi index b8b9fcc41e..2dbb687d4d 100644 --- a/arch/arm/dts/omap3-panel-sharp-ls037v7dw01.dtsi +++ b/arch/arm/dts/omap3-panel-sharp-ls037v7dw01.dtsi @@ -46,7 +46,7 @@ };
&dss { - status = "ok"; + status = "okay"; port { dpi_out: endpoint { remote-endpoint = <&lcd_in>; diff --git a/arch/arm/dts/omap34xx.dtsi b/arch/arm/dts/omap34xx.dtsi index ac4f8795b7..a703d09736 100644 --- a/arch/arm/dts/omap34xx.dtsi +++ b/arch/arm/dts/omap34xx.dtsi @@ -69,7 +69,7 @@ };
&ssi { - status = "ok"; + status = "okay";
clocks = <&ssi_ssr_fck>, <&ssi_sst_fck>, diff --git a/arch/arm/dts/omap36xx.dtsi b/arch/arm/dts/omap36xx.dtsi index 6fb23ada1f..52e1b8ce0f 100644 --- a/arch/arm/dts/omap36xx.dtsi +++ b/arch/arm/dts/omap36xx.dtsi @@ -153,7 +153,7 @@ };
clocks = <&ssi_ssr_fck>, <&ssi_sst_fck>, diff --git a/arch/arm/dts/omap4-panda-common.dtsi b/arch/arm/dts/omap4-panda-common.dtsi index 55ea8b6189..c124b20d46 100644 --- a/arch/arm/dts/omap4-panda-common.dtsi +++ b/arch/arm/dts/omap4-panda-common.dtsi @@ -546,7 +546,7 @@ };
port { dpi_out: endpoint { @@ -557,12 +557,12 @@ };
&dsi2 { - status = "ok"; + status = "okay"; vdd-supply = <&vcxio>; };
&hdmi { - status = "ok"; + status = "okay"; vdda-supply = <&vdac>;
port { diff --git a/arch/arm/dts/omap4-sdp.dts b/arch/arm/dts/omap4-sdp.dts index 91480ac1f3..28b989cfdb 100644 --- a/arch/arm/dts/omap4-sdp.dts +++ b/arch/arm/dts/omap4-sdp.dts @@ -648,11 +648,11 @@ };
&dsi1 { - status = "ok"; + status = "okay"; vdd-supply = <&vcxio>;
port { @@ -677,7 +677,7 @@ };
port { @@ -702,7 +702,7 @@ };
port { diff --git a/arch/arm/dts/omap5-board-common.dtsi b/arch/arm/dts/omap5-board-common.dtsi index 68ac04641b..1eedd8d706 100644 --- a/arch/arm/dts/omap5-board-common.dtsi +++ b/arch/arm/dts/omap5-board-common.dtsi @@ -743,11 +743,11 @@ };
/* vdda-supply populated in board specific dts file */
Did you miss: [1] https://github.com/devicetree-org/devicetree-specification/releases/tag/v0.3
Also, I think it might be better to refer to the specification than the schema implementation of the specification.
&mcbsp1 {
- status = "ok";
- status = "okay"; #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcbsp1_pins>;
&mcbsp2 {
- status = "ok";
- status = "okay"; #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcbsp2_pins>;
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&hdmi {
- status = "ok";
port {
&pcie1_rc {
- status = "ok";
- status = "okay"; gpios = <&gpio2 8 GPIO_ACTIVE_LOW>;
- status = "ok";
- status = "okay"; cs3 { #address-cells = <2>; #size-cells = <1>;
&dcan1 {
- status = "ok";
- status = "okay"; pinctrl-names = "default", "sleep", "active"; pinctrl-0 = <&dcan1_pins_sleep>; pinctrl-1 = <&dcan1_pins_sleep>;
&dcan1 {
- status = "ok";
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
&mdio {
- status = "ok";
- status = "okay"; ethphy0: ethernet-phy@0 { compatible = "marvell,88E1514", "marvell,88E1510", "ethernet-phy-ieee802.3-c22"; reg = <0>;
&mdio {
- status = "ok";
- status = "okay"; ethphy0: ethernet-phy@0 { compatible = "marvell,88E1111", "ethernet-phy-ieee802.3-c22"; reg = <0>;
&mdio {
- status = "ok";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&gpmc {
- status = "ok";
/* Chip select 0 */
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
- status = "okay"; port { dpi_out: endpoint { remote-endpoint = <&lcd_in>;
&ssi {
- status = "ok";
status = "okay";
&ssi {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dsi2 {
- status = "ok";
- status = "okay"; vdd-supply = <&vcxio>;
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&dsi1 {
- status = "ok";
port {
&dsi2 {
- status = "ok";
port {
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
-- 2.17.1
Hi Roger,
Is Kernel DTS updated? The idea is to not deviate from Kernel dts as much as possible.
Thanks and regards, Lokesh
&mcbsp1 {
- status = "ok";
&mcbsp2 {
- status = "ok";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&hdmi {
- status = "ok";
port {
&pcie1_rc {
- status = "ok";
- status = "ok";
&dcan1 {
- status = "ok";
&dcan1 {
- status = "ok";
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
&mdio {
- status = "ok";
&mdio {
- status = "ok";
&mdio {
- status = "ok";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&gpmc {
- status = "ok";
/* Chip select 0 */
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
&ssi {
- status = "ok";
status = "okay";
&ssi {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dsi2 {
- status = "ok";
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&dsi1 {
- status = "ok";
port {
&dsi2 {
- status = "ok";
port {
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
Hi Lokesh,
On 23/08/2021 09:23, Lokesh Vutla wrote:
Hi Roger,
Yes, on kernel side, most nodes have been updated. There were a few stray left overs which I have sent patches for. I will send v2 of this series to address Nishanth's comment.
cheers, -roger
&mcbsp1 {
- status = "ok";
&mcbsp2 {
- status = "ok";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&hdmi {
- status = "ok";
port {
&pcie1_rc {
- status = "ok";
- status = "ok";
&dcan1 {
- status = "ok";
&dcan1 {
- status = "ok";
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
&mdio {
- status = "ok";
&mdio {
- status = "ok";
&mdio {
- status = "ok";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&venc {
- status = "ok";
status = "okay";
&gpmc {
- status = "ok";
/* Chip select 0 */
&dss {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
&ssi {
- status = "ok";
status = "okay";
&ssi {
- status = "ok";
status = "okay";
&dss {
- status = "ok";
status = "okay";
&dsi2 {
- status = "ok";
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&dsi1 {
- status = "ok";
port {
&dsi2 {
- status = "ok";
port {
&hdmi {
- status = "ok";
port {
&dss {
- status = "ok";
- status = "okay";
&hdmi {
- status = "ok";
status = "okay";
Lokesh Vutla
Nishanth Menon
Roger Quadros
