[U-Boot] [PATCH v2] config.mk: disable -fstack-usage for blackfin and m68k
Currently gcc does not seem to support -fstack-usage option for some targets, such as blackfin and m68k.
If -fstack-usage option is given for those targets, gcc displays a warning message as follows:
warning: -fstack-usage not supported for this target [enabled by default]
But it still exits with status 0.
So,
# Report stack usage if supported CFLAGS_STACK := $(call cc-option,-fstack-usage) CFLAGS += $(CFLAGS_STACK)
does not work as we expect because cc-option sees exit status to judge whether the given option is supported or not.
Adding -Werror option to cc-option function does not work either, because gcc always succeeds in compiling /dev/null input with -fstack-usage option. We cannot rely on cc-option.
To suppress warnings for such targets that -fstack-usage is not supported, this commit surrounds the concerned lines with ifdef CONFIG_CC_STACKUSAGE .. endif. And it adds CONFIG_CC_STACKUSAGE=y to arch/${ARCH}/config.mk except blackfin and m68k.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Tom Rini trini@ti.com Cc: Michal Simek monstr@monstr.eu Cc: Jeroen Hofstee jeroen@myspectrum.nl --- arch/arm/config.mk | 2 ++ arch/avr32/config.mk | 2 ++ arch/microblaze/config.mk | 2 ++ arch/mips/config.mk | 2 ++ arch/nds32/config.mk | 2 ++ arch/nios2/config.mk | 2 ++ arch/openrisc/config.mk | 2 ++ arch/powerpc/config.mk | 2 ++ arch/sandbox/config.mk | 2 ++ arch/sh/config.mk | 2 ++ arch/sparc/config.mk | 2 ++ arch/x86/config.mk | 2 ++ config.mk | 6 +++--- 13 files changed, 27 insertions(+), 3 deletions(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index bdabcf4..f63336d 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -103,3 +103,5 @@ ALL-y += checkarmreloc # such usage by requiring word relocations. PLATFORM_CPPFLAGS += $(call cc-option, -mword-relocations) endif + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/avr32/config.mk b/arch/avr32/config.mk index 4ab4745..39776fc 100644 --- a/arch/avr32/config.mk +++ b/arch/avr32/config.mk @@ -13,3 +13,5 @@ PLATFORM_RELFLAGS += -ffixed-r5 -fPIC -mno-init-got -mrelax PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections
LDFLAGS_u-boot = --gc-sections --relax + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/microblaze/config.mk b/arch/microblaze/config.mk index fc545a9..84a2325 100644 --- a/arch/microblaze/config.mk +++ b/arch/microblaze/config.mk @@ -15,3 +15,5 @@ CONFIG_STANDALONE_LOAD_ADDR ?= 0x80F00000 PLATFORM_CPPFLAGS += -ffixed-r31 -D__microblaze__
LDSCRIPT ?= $(SRCTREE)/$(CPUDIR)/u-boot.lds + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/mips/config.mk b/arch/mips/config.mk index c3f81b5..c182956 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -51,3 +51,5 @@ PLATFORM_LDFLAGS += -G 0 -static -n -nostdlib $(ENDIANNESS) PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections LDFLAGS_FINAL += --gc-sections -pie OBJCFLAGS += --remove-section=.dynsym + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/nds32/config.mk b/arch/nds32/config.mk index e93e3a8..97cb937 100644 --- a/arch/nds32/config.mk +++ b/arch/nds32/config.mk @@ -17,3 +17,5 @@ PLATFORM_RELFLAGS += -gdwarf-2 PLATFORM_CPPFLAGS += -DCONFIG_NDS32 -D__nds32__ -G0 -ffixed-10 -fpie
LDFLAGS_u-boot = --gc-sections --relax + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index 7d546ef..7ca6323 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -15,3 +15,5 @@ PLATFORM_CPPFLAGS += -G0
LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/openrisc/config.mk b/arch/openrisc/config.mk index 13015eb..8694c1c 100644 --- a/arch/openrisc/config.mk +++ b/arch/openrisc/config.mk @@ -14,3 +14,5 @@ PLATFORM_CPPFLAGS += -DCONFIG_OPENRISC -D__OR1K__ -ffixed-r10 CONFIG_STANDALONE_LOAD_ADDR ?= 0x40000
LDSCRIPT ?= $(SRCTREE)/$(CPUDIR)/u-boot.lds + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index e6bb935..33fcc16 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -34,3 +34,5 @@ endif ifneq ($(CONFIG_SPL_BUILD),y) ALL-y += checkgcc4 endif + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index 6142dd4..49919f9 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -7,3 +7,5 @@ PLATFORM_LIBS += -lrt
# Support generic board on sandbox __HAVE_ARCH_GENERIC_BOARD := y + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/sh/config.mk b/arch/sh/config.mk index 758c070..10da053 100644 --- a/arch/sh/config.mk +++ b/arch/sh/config.mk @@ -15,3 +15,5 @@ endif PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ PLATFORM_LDFLAGS += -e $(CONFIG_SYS_TEXT_BASE) --defsym reloc_dst=$(CONFIG_SYS_TEXT_BASE) LDFLAGS_FINAL = --gc-sections + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/sparc/config.mk b/arch/sparc/config.mk index e94e7cb..c7a1b89 100644 --- a/arch/sparc/config.mk +++ b/arch/sparc/config.mk @@ -10,3 +10,5 @@ CROSS_COMPILE ?= sparc-elf- CONFIG_STANDALONE_LOAD_ADDR ?= 0x00000000 -L $(gcclibdir) -T sparc.lds
PLATFORM_CPPFLAGS += -DCONFIG_SPARC -D__sparc__ + +CONFIG_CC_STACKUSAGE=y diff --git a/arch/x86/config.mk b/arch/x86/config.mk index b22959f..3a3b723 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -35,3 +35,5 @@ NORMAL_LIBGCC = $(shell $(CC) $(CFLAGS) -print-libgcc-file-name) PREFIXED_LIBGCC = $(OBJTREE)/arch/$(ARCH)/lib/$(shell basename $(NORMAL_LIBGCC))
export USE_PRIVATE_LIBGCC=$(shell dirname $(PREFIXED_LIBGCC)) + +CONFIG_CC_STACKUSAGE=y diff --git a/config.mk b/config.mk index 3441387..811c10f 100644 --- a/config.mk +++ b/config.mk @@ -278,9 +278,9 @@ CFLAGS_WARN := $(call cc-option,-Wno-format-nonliteral) \ $(call cc-option,-Wno-format-security) CFLAGS += $(CFLAGS_WARN)
-# Report stack usage if supported -CFLAGS_STACK := $(call cc-option,-fstack-usage) -CFLAGS += $(CFLAGS_STACK) +ifdef CONFIG_CC_STACKUSAGE +CFLAGS += $(call cc-option,-fstack-usage) +endif
BCURDIR = $(subst $(SRCTREE)/,,$(CURDIR:$(obj)%=%))
Hi Masahiro,
On Tue, 15 Oct 2013 17:24:17 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
So,
Please keep the commit message to a (short) description of the patch, and move the rationale to a comment below the '---' line.
Also: what is the benefit of creating an elaborate mechanism to hide a warning message that says the option is useless, IOW, wouldn't it be simpler to only specify -fstack-usage to the arches that support it?
Amicalement,
Hello.
After I posted v2, I changed my mind. Adding a new script to test -fstack-usage support seems smarter, I think.
I posted version 3 config.mk: fix -fstack-usage support test
Albert,
When posting a patch I keep it in my mind to describe the reason or background in as much detail as possible especially when it is not clear at a glance. A comment below the '---' line is dropped after the patch is applied.
But I understand what you said.
I posted v3 and I kept its commit message in short. Better?
Best Regards Masahiro Yamada
Albert ARIBAUD
Masahiro Yamada
