[PATCH v2 1/1] efi_driver: don't bind internal block devices
UEFI block devices can either mirror U-Boot's internal devices or be provided by an EFI application like iPXE.
When ConnectController() is invoked for the EFI_BLOCK_IO_PROTOCOL interface for such an application provided device we create a virtual U-Boot block device of type "efi_blk".
Currently we do not call ConnectController() when handles for U-Boot's internal block devices are created. If an EFI application calls ConnectController() for a handle relating to an internal block device, we erroneously create an extra "efi_blk" block device.
E.g. the UEFI shell has a command 'connect -r' which calls ConnectController() for all handles.
In the Supported() method of our EFI_DRIVER_BINDING_PROTOCOL return EFI_ALREADY_STARTED when dealing with an U-Boot internal device.
Reported-by: Etienne Carriere etienne.carriere@linaro.org Fixes: b406eb04c360 ("efi_loader: disk: a helper function to delete efi_disk objects") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Etienne Carriere etienne.carriere@linaro.org Tested-by: Etienne Carriere etienne.carriere@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- v2: add a code comment --- lib/efi_driver/efi_uclass.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/lib/efi_driver/efi_uclass.c b/lib/efi_driver/efi_uclass.c index b01ce89c84..1d7a0f57e3 100644 --- a/lib/efi_driver/efi_uclass.c +++ b/lib/efi_driver/efi_uclass.c @@ -71,6 +71,15 @@ static efi_status_t EFIAPI efi_uc_supported( EFI_ENTRY("%p, %p, %ls", this, controller_handle, efi_dp_str(remaining_device_path));
+ /* + * U-Boot internal devices install protocols interfaces without calling + * ConnectController(). Hence we should not bind an extra driver. + */ + if (controller_handle->dev) { + ret = EFI_ALREADY_STARTED; + goto out; + } + ret = EFI_CALL(systab.boottime->open_protocol( controller_handle, bp->ops->protocol, &interface, this->driver_binding_handle,
Not exactly. ConnectController() will be called against handles which hold DevicePathProtocol.
No. EFI_ALREADY_STARTED is not the right return value for "ordinary block devices" since this driver does not manage those devices under the current implementation. Return EFI_UNSUPPORTED instead.
ALREADY_STARTED is a right one for EFI-app driver. You must distinguish the two cases. That is why I said that efi_uc_supported() should have a stricter check.
NAK. The bug, "erroneously create an extra "efi_blk" block device", has existed since you introduced efi_driver/efi_block_device.c.
Use 'Fixes: commit 05ef48a2484b ("efi_driver: EFI block driver")'.
-Takahiro Akashi
- if (controller_handle->dev) {
goto out;
- ret = EFI_CALL(systab.boottime->open_protocol( controller_handle, bp->ops->protocol, &interface, this->driver_binding_handle,
-- 2.37.2
Thanks for reviewing. I will take these changes when merging.
Best regards
Heinrich
-Takahiro Akashi
goto out;
-- 2.37.2
AKASHI Takahiro
