[U-Boot] [PATCH V2] ARM: tegra: amend pmc.h for Tegra114+
Tegra114 and later's PMC module removes the pwrgate_timer_on register and replaces it with a clamp_status register. Adjust pmc.h to reflect this, and update any code affected by the change.
The cpu.c change in this patch was extracted from a much larger patch by Jimmy Zhang. The pmc.h change was written from scratch, but inspired by related changes made by Tom Warren.
There could well be other differences in the PMC register set for chips after Tegra20/30. However, they don't affect the code in U-Boot at present, so I haven't attempted an exhaustive update of pmc.h.
Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Thierry Reding treding@nvidia.com Acked-by: Thierry Reding treding@nvidia.com Tested-by: Thierry Reding treding@nvidia.com --- v2: Fix typo in register offset --- arch/arm/cpu/arm720t/tegra114/cpu.c | 4 ++-- arch/arm/include/asm/arch-tegra/pmc.h | 6 +++++- 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c index 51ecff794fb7..7a1747a3beb8 100644 --- a/arch/arm/cpu/arm720t/tegra114/cpu.c +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -219,8 +219,8 @@ static int is_clamp_enabled(u32 mask) struct pmc_ctlr *pmc = (struct pmc_ctlr *)NV_PA_PMC_BASE; u32 reg;
- /* Get clamp status. TODO: Add pmc_clamp_status alias to pmc.h */ - reg = readl(&pmc->pmc_pwrgate_timer_on); + /* Get clamp status. */ + reg = readl(&pmc->pmc_clamp_status); return (reg & mask) == mask; }
diff --git a/arch/arm/include/asm/arch-tegra/pmc.h b/arch/arm/include/asm/arch-tegra/pmc.h index ba22236ee3b7..6e5f61e7fa4c 100644 --- a/arch/arm/include/asm/arch-tegra/pmc.h +++ b/arch/arm/include/asm/arch-tegra/pmc.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2010,2011 + * (C) Copyright 2010,2011,2014 * NVIDIA Corporation <www.nvidia.com> * * SPDX-License-Identifier: GPL-2.0+ @@ -21,7 +21,11 @@ struct pmc_ctlr { uint pmc_dpd_sample; /* _DPD_PADS_SAMPLE_0, offset 20 */ uint pmc_dpd_enable; /* _DPD_PADS_ENABLE_0, offset 24 */ uint pmc_pwrgate_timer_off; /* _PWRGATE_TIMER_OFF_0, offset 28 */ +#if defined(CONFIG_TEGRA20) || defined(CONFIG_TEGRA30) uint pmc_pwrgate_timer_on; /* _PWRGATE_TIMER_ON_0, offset 2C */ +#else + uint pmc_clamp_status; /* _CLAMP_STATUS_0, offset 2C */ +#endif uint pmc_pwrgate_toggle; /* _PWRGATE_TOGGLE_0, offset 30 */ uint pmc_remove_clamping; /* _REMOVE_CLAMPING_CMD_0, offset 34 */ uint pmc_pwrgate_status; /* _PWRGATE_STATUS_0, offset 38 */
Stephen Warren
