[U-Boot] [PATCH] ARM change name of defines for AT91 arm926ejs
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich aehrlich@taskit.de --- board/atmel/at91cap9adk/at91cap9adk.c | 2 +- board/atmel/at91sam9261ek/at91sam9261ek.c | 2 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 2 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 2 +- board/esd/otc570/otc570.c | 2 +- board/ronetix/pm9261/pm9261.c | 2 +- board/ronetix/pm9263/pm9263.c | 2 +- cpu/arm926ejs/at91/clock.c | 2 +- cpu/arm926ejs/at91/cpu.c | 8 ++++---- include/asm-arm/arch-at91/at91cap9.h | 2 +- include/asm-arm/arch-at91/at91rm9200.h | 2 +- include/asm-arm/arch-at91/at91sam9260.h | 4 ++-- include/asm-arm/arch-at91/at91sam9261.h | 2 +- include/asm-arm/arch-at91/at91sam9263.h | 2 +- include/asm-arm/arch-at91/at91sam9g45.h | 2 +- include/asm-arm/arch-at91/at91sam9rl.h | 2 +- include/configs/afeb9260.h | 2 +- include/configs/at91cap9adk.h | 2 +- include/configs/at91sam9260ek.h | 2 +- include/configs/at91sam9261ek.h | 2 +- include/configs/at91sam9263ek.h | 2 +- include/configs/at91sam9m10g45ek.h | 2 +- include/configs/at91sam9rlek.h | 2 +- include/configs/cpu9260.h | 2 +- include/configs/pm9261.h | 4 ++-- include/configs/pm9263.h | 2 +- include/configs/sbc35_a9g20.h | 2 +- include/configs/tny_a9260.h | 2 +- 29 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index 9f73df6..258d1ea 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -282,7 +282,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 7ead2b8..de5cfae 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -217,7 +217,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 8ab45af..5cd7aa7 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -218,7 +218,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 45a14a9..edfb627 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -217,7 +217,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 7013ba2..e374917 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -157,7 +157,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/esd/otc570/otc570.c b/board/esd/otc570/otc570.c index 056df37..3fe28cb 100644 --- a/board/esd/otc570/otc570.c +++ b/board/esd/otc570/otc570.c @@ -219,7 +219,7 @@ void lcd_show_board_info(void) nand_size += nand_info[i].size;
lcd_printf("\n%s\n", U_BOOT_VERSION); - lcd_printf("%s CPU at %s MHz\n", AT91_CPU_NAME, + lcd_printf("%s CPU at %s MHz\n", CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate())); lcd_printf(" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index 6915b9b..8662339 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -189,7 +189,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2009 Ronetix GmbH\n"); lcd_printf ("support@ronetix.at\n"); lcd_printf ("%s CPU at %s MHz", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 29555f8..23ea154 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -304,7 +304,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2009 Ronetix GmbH\n"); lcd_printf ("support@ronetix.at\n"); lcd_printf ("%s CPU at %s MHz", - AT91_CPU_NAME, + CONFIG_SYS_AT91_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; diff --git a/cpu/arm926ejs/at91/clock.c b/cpu/arm926ejs/at91/clock.c index 7e03907..444d42d 100644 --- a/cpu/arm926ejs/at91/clock.c +++ b/cpu/arm926ejs/at91/clock.c @@ -147,7 +147,7 @@ int at91_clock_init(unsigned long main_clock) { unsigned freq, mckr; at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; -#ifndef AT91_MAIN_CLOCK +#ifndef CONFIG_SYS_AT91_MAIN_CLOCK unsigned tmp; /* * When the bootloader initialized the main oscillator correctly, diff --git a/cpu/arm926ejs/at91/cpu.c b/cpu/arm926ejs/at91/cpu.c index 993b299..1094f8c 100644 --- a/cpu/arm926ejs/at91/cpu.c +++ b/cpu/arm926ejs/at91/cpu.c @@ -31,13 +31,13 @@ #include <asm/arch/clk.h> #include <asm/arch/io.h>
-#ifndef AT91_MAIN_CLOCK -#define AT91_MAIN_CLOCK 0 +#ifndef CONFIG_SYS_AT91_MAIN_CLOCK +#define CONFIG_SYS_AT91_MAIN_CLOCK 0 #endif
int arch_cpu_init(void) { - return at91_clock_init(AT91_MAIN_CLOCK); + return at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK); }
#if defined(CONFIG_DISPLAY_CPUINFO) @@ -45,7 +45,7 @@ int print_cpuinfo(void) { char buf[32];
- printf("CPU: %s\n", AT91_CPU_NAME); + printf("CPU: %s\n", CONFIG_SYS_AT91_CPU_NAME); printf("Crystal frequency: %8s MHz\n", strmhz(buf, get_main_clk_rate())); printf("CPU clock : %8s MHz\n", diff --git a/include/asm-arm/arch-at91/at91cap9.h b/include/asm-arm/arch-at91/at91cap9.h index 658124b..5af6fdc 100644 --- a/include/asm-arm/arch-at91/at91cap9.h +++ b/include/asm-arm/arch-at91/at91cap9.h @@ -145,6 +145,6 @@ /* * Cpu Name */ -#define AT91_CPU_NAME "AT91CAP9" +#define CONFIG_SYS_AT91_CPU_NAME "AT91CAP9"
#endif diff --git a/include/asm-arm/arch-at91/at91rm9200.h b/include/asm-arm/arch-at91/at91rm9200.h index 990f5a6..1bee6f2 100644 --- a/include/asm-arm/arch-at91/at91rm9200.h +++ b/include/asm-arm/arch-at91/at91rm9200.h @@ -130,6 +130,6 @@ #define AT91_PMX_CA_NCS7 0x00002000 #define AT91_PMX_CA_D16_31 0xFFFF0000
-#define AT91_CPU_NAME "AT91RM9200" +#define CONFIG_SYS_AT91_CPU_NAME "AT91RM9200"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9260.h b/include/asm-arm/arch-at91/at91sam9260.h index 7ca6078..a60a081 100644 --- a/include/asm-arm/arch-at91/at91sam9260.h +++ b/include/asm-arm/arch-at91/at91sam9260.h @@ -139,9 +139,9 @@ * Cpu Name */ #if defined(CONFIG_AT91SAM9260) -#define AT91_CPU_NAME "AT91SAM9260" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9260" #elif defined(CONFIG_AT91SAM9G20) -#define AT91_CPU_NAME "AT91SAM9G20" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G20" #endif
#endif diff --git a/include/asm-arm/arch-at91/at91sam9261.h b/include/asm-arm/arch-at91/at91sam9261.h index 1d8cab6..2952292 100644 --- a/include/asm-arm/arch-at91/at91sam9261.h +++ b/include/asm-arm/arch-at91/at91sam9261.h @@ -114,6 +114,6 @@ /* * Cpu Name */ -#define AT91_CPU_NAME "AT91SAM9261" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9261"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9263.h b/include/asm-arm/arch-at91/at91sam9263.h index b26b7b4..c177bd0 100644 --- a/include/asm-arm/arch-at91/at91sam9263.h +++ b/include/asm-arm/arch-at91/at91sam9263.h @@ -147,6 +147,6 @@ /* * Cpu Name */ -#define AT91_CPU_NAME "AT91SAM9263" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9263"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9g45.h b/include/asm-arm/arch-at91/at91sam9g45.h index 99c03f7..445f4b2 100644 --- a/include/asm-arm/arch-at91/at91sam9g45.h +++ b/include/asm-arm/arch-at91/at91sam9g45.h @@ -147,6 +147,6 @@ /* * Cpu Name */ -#define AT91_CPU_NAME "AT91SAM9G45" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G45"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9rl.h b/include/asm-arm/arch-at91/at91sam9rl.h index 12054f6..8eb0d4f 100644 --- a/include/asm-arm/arch-at91/at91sam9rl.h +++ b/include/asm-arm/arch-at91/at91sam9rl.h @@ -125,6 +125,6 @@ /* * Cpu Name */ -#define AT91_CPU_NAME "AT91SAM9RL" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9RL"
#endif diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 9f8c567..24484fd 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -29,7 +29,7 @@ #define CONFIG_AT91_LEGACY
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 18429952 /* from 18.432 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18429952 /* from 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 9da5846..44c2870 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -30,7 +30,7 @@ #define CONFIG_AT91_LEGACY
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index ff1e5b3..b89242b 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -30,7 +30,7 @@ #define CONFIG_AT91_LEGACY
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 63b55d2..df8181b 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -30,7 +30,7 @@ #define CONFIG_AT91_LEGACY
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 5a46d6a..5cafa1e 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -28,7 +28,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index ce21831..44c5496 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -30,7 +30,7 @@ #define CONFIG_AT91_LEGACY
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 95f3d6c..e8fcd66 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -30,7 +30,7 @@ #define CONFIG_AT91_LEGACY
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index 38f34c2..fb6f79a 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -35,7 +35,7 @@
#define CONFIG_DISPLAY_CPUINFO 1
-#define AT91_MAIN_CLOCK 18432000 +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 8ee132b..47bb8c0 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -31,14 +31,14 @@ #define CONFIG_AT91_LEGACY
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91SAM9261" +#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9261"
#define CONFIG_DISPLAY_BOARDINFO
#define MASTER_PLL_DIV 15 #define MASTER_PLL_MUL 162 #define MAIN_PLL_DIV 2 -#define AT91_MAIN_CLOCK 18432000 +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000
diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index a6fdcaa..807dba8 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -37,7 +37,7 @@ #define MASTER_PLL_DIV 6 #define MASTER_PLL_MUL 65 #define MAIN_PLL_DIV 2 /* 2 or 4 */ -#define AT91_MAIN_CLOCK 18432000 +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000
diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index 1f2ff9e..b9f27cc 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -41,7 +41,7 @@ #endif
/* ARM asynchronous clock */ -#define AT91_MAIN_CLOCK 12000000 /* 12.000 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12.000 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ diff --git a/include/configs/tny_a9260.h b/include/configs/tny_a9260.h index a159a40..5af2af3 100644 --- a/include/configs/tny_a9260.h +++ b/include/configs/tny_a9260.h @@ -51,7 +51,7 @@ #endif
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention:
Thank you. I have pushed this to arm/master Tom
Achim Ehrlich
Tom
