[PATCH 0/2] doc: env sub-commands, env list of aliases
* sort env sub-commands alphabetically * update list of aliases for the env command
Heinrich Schuchardt (2): doc: sort env sub-commands alphabetically doc: update list of aliases for the env command
doc/usage/cmd/env.rst | 35 ++++++++++++++++++----------------- 1 file changed, 18 insertions(+), 17 deletions(-)
The 'env' man-page is currently only partially sorted.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/usage/cmd/env.rst | 34 +++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/doc/usage/cmd/env.rst b/doc/usage/cmd/env.rst index a7e21693a67..60a294328e8 100644 --- a/doc/usage/cmd/env.rst +++ b/doc/usage/cmd/env.rst @@ -16,18 +16,18 @@ Synopsis env default [-f] (-a | var [...]) env delete [-f] var [...] env edit name + env erase env exists name env export [-t | -b | -c] [-s size] addr [var ...] env flags env grep [-e] [-n | -v | -b] string [...] env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] env info [-d] [-p] [-q] + env load env print [-a | name ...] env print -e [-guid guid] [-n] [name ...] env run var [...] env save - env erase - env load env select [target] env set [-f] name [value] env set -e [-nv][-bs][-rt][-at][-a][-i addr:size][-v] name [value] @@ -40,11 +40,11 @@ the UEFI variables.
The next commands are kept as alias and for compatibility:
++ *askenv* = *env ask* + *editenv* = *env edit* + *grepenv* = *env grep* -+ *setenv* = *env set* -+ *askenv* = *env ask* + *run* = *env run* ++ *setenv* = *env set*
Ask ~~~ @@ -103,6 +103,11 @@ The *env edit* command edits an environment variable. name name of the variable.
+Erase +~~~~~ + +The *env erase* command erases the U-Boot environment. + Exists ~~~~~~
@@ -204,6 +209,11 @@ environment information. quiet output, use only for command result, by example with 'test' command.
+Load +~~~~ + +The *env load* command loads the U-Boot environment from persistent storage. + Print ~~~~~
@@ -235,16 +245,6 @@ Save
The *env save* command saves the U-Boot environment in persistent storage.
-Erase -~~~~~ - -The *env erase* command erases the U-Boot environment. - -Load -~~~~ - -The *env load* command loads the U-Boot environment from persistent storage. - Select ~~~~~~
@@ -350,15 +350,15 @@ edit exists CONFIG_CMD_ENV_EXISTS
-flags - CONFIG_CMD_ENV_FLAGS - erase CONFIG_CMD_ERASEENV
export CONFIG_CMD_EXPORTENV
+flags + CONFIG_CMD_ENV_FLAGS + grep CONFIG_CMD_GREPENV, CONFIG_REGEX for '-e' option
* add link to askenv man-page * add printenv
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/usage/cmd/env.rst | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/doc/usage/cmd/env.rst b/doc/usage/cmd/env.rst index 60a294328e8..040076bcc03 100644 --- a/doc/usage/cmd/env.rst +++ b/doc/usage/cmd/env.rst @@ -40,9 +40,10 @@ the UEFI variables.
-+ *askenv* = *env ask* ++ :doc:`askenv <askenv>` = *env ask* + *editenv* = *env edit* + *grepenv* = *env grep* ++ :doc:`printenv <printenv>` = *env print* + *run* = *env run* + *setenv* = *env set*
