[U-Boot] [PATCH 1/2] cmd: Kconfig: Add a Kconfig options for a few CMD
Add the following CMD options to Kconfig:
CMD_BOOTZ CMD_ASKENV CMD_GREPENV CMD_USB_MASS_STORAGE CMD_FAT CMD_MII CMD_CACHE CMD_DFU CMD_EXT2 CMD_EXT4 CMD_EXT4_WRITE CMD_FS_GENERIC CMD_MMC
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- cmd/Kconfig | 78 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 78 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index fe8b4f0..82d5d20 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -160,6 +160,11 @@ config CMD_BOOTM help Boot an application image from the memory.
+config CMD_BOOTZ + bool "bootz" + help + Boot the Linux zImage + config CMD_BOOTEFI bool "bootefi" depends on EFI_LOADER @@ -210,6 +215,11 @@ endmenu
menu "Environment commands"
+config CMD_ASKENV + bool "ask for env variable" + help + Ask for environment variable + config CMD_EXPORTENV bool "env export" default y @@ -228,6 +238,11 @@ config CMD_EDITENV help Edit environment variable.
+config CMD_GREPENV + bool "search env" + help + Allow for searching environment variables + config CMD_SAVEENV bool "saveenv" default y @@ -341,6 +356,11 @@ config CMD_ARMFLASH help ARM Ltd reference designs flash partition access
+config CMD_MMC + bool "mmc" + help + MMC memory mapped support. + config CMD_NAND bool "nand" help @@ -366,6 +386,19 @@ config CMD_USB help USB support.
+config CMD_DFU + depends on CMD_USB + bool "dfu" + help + Enables the command "dfu" which is used to have U-Boot create a DFU + class device via USB. + +config CMD_USB_MASS_STORAGE + depends on CMD_USB + bool "UMS usb mass storage" + help + USB mass storage support + config CMD_FPGA bool "fpga" default y @@ -454,6 +487,11 @@ config CMD_NFS help Boot image via network using NFS protocol.
+config CMD_MII + bool "mii" + help + Enable MII utility commands. + config CMD_PING bool "ping" help @@ -508,6 +546,17 @@ config CMD_BLOCK_CACHE during development, but also allows the cache to be disabled when it might hurt performance (e.g. when using the ums command).
+config CMD_CACHE + bool "icache or dcache" + help + Enable the "icache" and "dcache" commands + +config CMD_DFU + bool "dfu" + help + Enables the command "dfu" which is used to have U-Boot create a DFU + class device via USB. + config CMD_TIME bool "time" help @@ -612,4 +661,33 @@ config CMD_TPM_TEST
endmenu
+menu "Filesystem commands" +config CMD_EXT2 + bool "ext2 command support" + help + Enables EXT2 FS command + +config CMD_EXT4 + bool "ext4 command support" + help + Enables EXT4 FS command + +config CMD_EXT4_WRITE + depends on CMD_EXT4 + bool "ext4 write command support" + help + Enables EXT4 FS write command + +config CMD_FAT + bool "FAT command support" + help + Support for the FAT fs + +config CMD_FS_GENERIC + bool "filesystem commands" + help + Enables filesystem commands (e.g. load, ls) that work for multiple + fs types. +endmenu + endmenu
Move common config options like these to socfpga_*_defconfig:
CONFIG_CMD_ASKENV CONFIG_CMD_BOOTZ CONFIG_CMD_CACHE CONFIG_CMD_DHCP CONFIG_CMD_EXT4 CONFIG_CMD_EXT4_WRITE CONFIG_CMD_FAT CONFIG_CMD_FS_GENERIC CONFIG_CMD_GREPENV CONFIG_CMD_MEMTEST CONFIG_CMD_MII CONFIG_CMD_MMC CONFIG_CMD_PING CONFIG_CMD_SF CONFIG_CMD_SPI CONFIG_CMD_TIME
to avoid defining them in individual SoCFPGA config files.
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- v2: move most defconfig options to socfpga_*_defconfig update commit message --- configs/socfpga_arria5_defconfig | 15 +++++++++++++++ configs/socfpga_cyclone5_defconfig | 15 +++++++++++++++ configs/socfpga_de0_nano_soc_defconfig | 15 +++++++++++++++ configs/socfpga_mcvevk_defconfig | 15 +++++++++++++++ configs/socfpga_sockit_defconfig | 15 +++++++++++++++ configs/socfpga_socrates_defconfig | 15 +++++++++++++++ configs/socfpga_sr1500_defconfig | 14 ++++++++++++++ include/configs/socfpga_arria5_socdk.h | 22 ---------------------- include/configs/socfpga_common.h | 5 +++++ include/configs/socfpga_cyclone5_socdk.h | 22 ---------------------- include/configs/socfpga_de0_nano_soc.h | 22 ---------------------- include/configs/socfpga_mcvevk.h | 22 ---------------------- include/configs/socfpga_sockit.h | 22 ---------------------- include/configs/socfpga_socrates.h | 22 ---------------------- include/configs/socfpga_sr1500.h | 25 ------------------------- 15 files changed, 109 insertions(+), 157 deletions(-)
diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 087d6f1..e28afcd 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -28,3 +28,18 @@ CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DFU=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index cef644e..cc343b5 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -28,3 +28,18 @@ CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DFU=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index c0ffad2..8f73969 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -23,3 +23,18 @@ CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index e01282c..b1627f6 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -23,3 +23,18 @@ CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8feb5a3..12ff4a7 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -28,3 +28,18 @@ CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 1b3c3df..91a7fd6 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -27,3 +27,18 @@ CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_MMC=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index ec57746..ef6e891 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CMD_GPIO CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y @@ -24,3 +25,16 @@ CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_USB=y CONFIG_USB_GADGET=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PING=y diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 153f9f8..9c282b8 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -8,28 +8,6 @@
#include <asm/arch/base_addr_ac5.h>
-/* U-Boot Commands */ -#define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION -#define CONFIG_FAT_WRITE -#define CONFIG_HW_WATCHDOG - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCDK */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 3e50892..4d14025 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -6,6 +6,11 @@ #ifndef __CONFIG_SOCFPGA_COMMON_H__ #define __CONFIG_SOCFPGA_COMMON_H__
+/* U-Boot Commands */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_HW_WATCHDOG
/* Virtual target or real hardware */ #undef CONFIG_SOCFPGA_VIRTUAL_TARGET diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index d7c339e..d8280c7 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -8,28 +8,6 @@
diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 314b9bf..0807ce6 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -8,28 +8,6 @@
-/* U-Boot Commands */ -#define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION -#define CONFIG_FAT_WRITE -#define CONFIG_HW_WATCHDOG - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB */
diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index f260a64..3d18993 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -8,28 +8,6 @@
-/* U-Boot Commands */ -#define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION -#define CONFIG_FAT_WRITE -#define CONFIG_HW_WATCHDOG - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on MCV */
diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 07cfcbf..ec47be5 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -8,28 +8,6 @@
diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index 02ea0c5..0e7ad76 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -8,28 +8,6 @@
-/* U-Boot Commands */ -#define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION -#define CONFIG_FAT_WRITE -#define CONFIG_HW_WATCHDOG - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB -#define CONFIG_CMD_USB_MASS_STORAGE - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCrates */
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index e43b5cf..9c2bca4 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -10,31 +10,6 @@
#define CONFIG_BOARD_EARLY_INIT_F
-#define CONFIG_SYS_NO_FLASH -#define CONFIG_DOS_PARTITION -#define CONFIG_FAT_WRITE - -#define CONFIG_HW_WATCHDOG - -/* U-Boot Commands */ -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GPIO -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MEMTEST -#define CONFIG_CMD_MII -#define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TIME - /* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SR1500 */
Hi Dinh,
As for the sr1500 part:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
So this is the tricky part, yes. You need to be able to use moveconfig.py to update _everyone_ and this easily conflicts (so don't do it right now, I have some stuff to push out that would cause it to conflict). I think I'll see if I can do this part, globally instead after applying your 1/2. Thanks!
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Ok, let me resend 1/2 because I noticed that it had a duplicate defconfi g.
Thanks, Dinh
Hi Dinh,
Can you also please use the moveconfig script to convert all boards?
Dinh Nguyen
Stefan Roese
