[PATCH v1 0/5] Implement fastboot multiresponce
Currently u-boot fastboot can only send one message back to host, so if there is a need to print more than one line messages must be kept sending until all the required data is obtained. This behavior can be adjusted using multiresponce ability (getting multiple lines of response) proposed in this patch set.
Implementation of multiresponce leads to ability to dump content of console buffer which, with use of "oem run", allows to entirely avoid need in UART.
Ion Agorria (5): fastboot: multiresponse support fastboot: implement "getvar all" commonn: console: introduce overflow and isempty calls lib: membuff: fix readline not returning line in case of overflow fastboot: add oem console command support
boot/bootmeth_extlinux.c | 2 +- common/console.c | 17 +++++-- doc/android/fastboot-protocol.rst | 3 ++ doc/android/fastboot.rst | 1 + drivers/fastboot/Kconfig | 7 +++ drivers/fastboot/fb_command.c | 52 +++++++++++++++++++++ drivers/fastboot/fb_getvar.c | 75 +++++++++++++++++++++++++------ drivers/usb/gadget/f_fastboot.c | 29 ++++++++++++ include/console.h | 14 ++++++ include/fastboot-internal.h | 7 +++ include/fastboot.h | 9 ++++ include/membuff.h | 5 ++- lib/membuff.c | 4 +- net/fastboot_udp.c | 25 ++++++++--- test/ut.c | 9 ++-- 15 files changed, 226 insertions(+), 33 deletions(-)
Currently u-boot fastboot can only send one message back to host, so if there is a need to print more than one line messages must be kept sending until all the required data is obtained. This behavior can be adjusted using multiresponce ability (getting multiple lines of response) proposed in this patch.
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/fastboot/fb_command.c | 10 ++++++++++ drivers/usb/gadget/f_fastboot.c | 29 +++++++++++++++++++++++++++++ include/fastboot.h | 8 ++++++++ net/fastboot_udp.c | 25 +++++++++++++++++++------ 4 files changed, 66 insertions(+), 6 deletions(-)
diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index 5fcadcdf50..ab72d8c781 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -5,6 +5,7 @@
#include <common.h> #include <command.h> +#include <console.h> #include <env.h> #include <fastboot.h> #include <fastboot-internal.h> @@ -152,6 +153,15 @@ int fastboot_handle_command(char *cmd_string, char *response) return -1; }
+void fastboot_multiresponse(int cmd, char *response) +{ + switch (cmd) { + default: + fastboot_fail("Unknown multiresponse command", response); + break; + } +} + /** * okay() - Send bare OKAY response * diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 741775a7bc..7d8c22b948 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -497,6 +497,25 @@ static void do_bootm_on_complete(struct usb_ep *ep, struct usb_request *req) do_exit_on_complete(ep, req); }
+int multiresponse_cmd = -1; +static void multiresponse_on_complete(struct usb_ep *ep, struct usb_request *req) +{ + char response[FASTBOOT_RESPONSE_LEN] = {0}; + + if (multiresponse_cmd == -1) + return; + + /* Call handler to obtain next response */ + fastboot_multiresponse(multiresponse_cmd, response); + fastboot_tx_write_str(response); + + /* If response is not an INFO disconnect this handler and unset cmd */ + if (strncmp("INFO", response, 4) != 0) { + multiresponse_cmd = -1; + fastboot_func->in_req->complete = fastboot_complete; + } +} + static void do_acmd_complete(struct usb_ep *ep, struct usb_request *req) { /* When usb dequeue complete will be called @@ -524,6 +543,16 @@ static void rx_handler_command(struct usb_ep *ep, struct usb_request *req) fastboot_fail("buffer overflow", response); }
+ if (!strncmp("MORE", response, 4)) { + multiresponse_cmd = cmd; + fastboot_multiresponse(multiresponse_cmd, response); + + /* Only add if first is a INFO */ + if (!strncmp("INFO", response, 4)) { + fastboot_func->in_req->complete = multiresponse_on_complete; + } + } + if (!strncmp("DATA", response, 4)) { req->complete = rx_handler_dl_image; req->length = rx_bytes_expected(ep); diff --git a/include/fastboot.h b/include/fastboot.h index 296451f89d..d1a2b74b2f 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -172,5 +172,13 @@ void fastboot_data_download(const void *fastboot_data, */ void fastboot_data_complete(char *response);
+/** + * fastboot_handle_multiresponse() - Called for each response to send + * + * @cmd: Command id that requested multiresponse + * @response: Pointer to fastboot response buffer + */ +void fastboot_multiresponse(int cmd, char *response); + void fastboot_acmd_complete(void); #endif /* _FASTBOOT_H_ */ diff --git a/net/fastboot_udp.c b/net/fastboot_udp.c index d690787478..ca3278f7b4 100644 --- a/net/fastboot_udp.c +++ b/net/fastboot_udp.c @@ -42,16 +42,15 @@ static int fastboot_remote_port; static int fastboot_our_port;
/** - * fastboot_udp_send_info() - Send an INFO packet during long commands. + * fastboot_udp_send_response() - Send an response into UDP * - * @msg: String describing the reason for waiting + * @response: Response to send */ -static void fastboot_udp_send_info(const char *msg) +static void fastboot_udp_send_response(const char *response) { uchar *packet; uchar *packet_base; int len = 0; - char response[FASTBOOT_RESPONSE_LEN] = {0};
struct fastboot_header response_header = { .id = FASTBOOT_FASTBOOT, @@ -66,7 +65,6 @@ static void fastboot_udp_send_info(const char *msg) memcpy(packet, &response_header, sizeof(response_header)); packet += sizeof(response_header); /* Write response */ - fastboot_response("INFO", response, "%s", msg); memcpy(packet, response, strlen(response)); packet += strlen(response);
@@ -91,6 +89,7 @@ static void fastboot_udp_send_info(const char *msg) static void fastboot_timed_send_info(const char *msg) { static ulong start; + char response[FASTBOOT_RESPONSE_LEN] = {0};
/* Initialize timer */ if (start == 0) @@ -99,7 +98,8 @@ static void fastboot_timed_send_info(const char *msg) /* Send INFO packet to host every 30 seconds */ if (time >= 30000) { start = get_timer(0); - fastboot_udp_send_info(msg); + fastboot_response("INFO", response, "%s", msg); + fastboot_udp_send_response(response); } }
@@ -180,6 +180,19 @@ static void fastboot_send(struct fastboot_header header, char *fastboot_data, } else { cmd = fastboot_handle_command(command, response); pending_command = false; + + if (!strncmp("MORE", response, 4)) { + while (1) { + /* Call handler to obtain next response */ + fastboot_multiresponse(multiresponse_cmd, response); + + /* Send INFO or break to send final response */ + if (!strncmp("INFO", response, 4)) + fastboot_udp_send_response(response); + else + break; + } + } } /* * Sent some INFO packets, need to update sequence number in
Hi Svyatoslav,
Thank you for your patch.
- switch (cmd) {
- default:
break;
- okay() - Send bare OKAY response
This is non static, because it is also used in net/fastboot_udp.c
However, if we: 1. disable CONFIG_USB_FUNCTION_FASTBOOT 2. enable CONFIG_UDP_FUNCTION_FASTBOOT
The build will break with: net/fastboot_udp.c: In function 'fastboot_send': net/fastboot_udp.c:187:64: error: 'multiresponse_cmd' undeclared (first use in this function) 187 | fastboot_multiresponse(multiresponse_cmd, response); | ^~~~~~~~~~~~~~~~~ net/fastboot_udp.c:187:64: note: each undeclared identifier is reported only once for each function it appears in
Since having only CONFIG_UDP_FUNCTION_FASTBOOT is valid (there is no dependency on CONFIG_USB_FASTBOOT), can we think of something else to handle multi-response commands without breaking UDP-only fastboot support ?
- if (multiresponse_cmd == -1)
return;
- /* Call handler to obtain next response */
- fastboot_multiresponse(multiresponse_cmd, response);
- fastboot_tx_write_str(response);
- /* If response is not an INFO disconnect this handler and unset cmd */
- if (strncmp("INFO", response, 4) != 0) {
- if (!strncmp("MORE", response, 4)) {
As discussed in [1], please use TEXT instead of MORE
[1] https://lore.kernel.org/all/CAPVz0n2fOXeHQOOZ-obPWUCQ7LdFsKZFGxZw5bp-qF8SaxL...
- if (!strncmp("DATA", response, 4)) { req->complete = rx_handler_dl_image; req->length = rx_bytes_expected(ep);
- fastboot_handle_multiresponse() - Called for each response to send
- @cmd: Command id that requested multiresponse
- @response: Pointer to fastboot response buffer
- fastboot_udp_send_info() - Send an INFO packet during long commands.
- fastboot_udp_send_response() - Send an response into UDP
- @msg: String describing the reason for waiting
- @response: Response to send
}fastboot_udp_send_response(response);
MORE -> TEXT
while (1) {
As written previously, multiresponse_cmd is undefined when: CONFIG_USB_FUNCTION_FASTBOOT=n && CONFIG_UDP_FUNCTION_FASTBOOT=y
else
break;
- Sent some INFO packets, need to update sequence number in
-- 2.40.1
This commit implements "fastboot getvar all" listing by iterating the existing dispatchers that don't require parameters (as we pass NULL), uses fastboot multiresponse.
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- doc/android/fastboot-protocol.rst | 3 ++ drivers/fastboot/fb_command.c | 3 ++ drivers/fastboot/fb_getvar.c | 75 +++++++++++++++++++++++++------ include/fastboot-internal.h | 7 +++ 4 files changed, 75 insertions(+), 13 deletions(-)
diff --git a/doc/android/fastboot-protocol.rst b/doc/android/fastboot-protocol.rst index e8cbd7f24e..8bd6d7168f 100644 --- a/doc/android/fastboot-protocol.rst +++ b/doc/android/fastboot-protocol.rst @@ -173,6 +173,9 @@ The various currently defined names are:: bootloader requiring a signature before it will install or boot images.
+ all Provides all info from commands above as + they were called one by one + Names starting with a lowercase character are reserved by this specification. OEM-specific names should not start with lowercase characters. diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index ab72d8c781..6f621df074 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -156,6 +156,9 @@ int fastboot_handle_command(char *cmd_string, char *response) void fastboot_multiresponse(int cmd, char *response) { switch (cmd) { + case FASTBOOT_COMMAND_GETVAR: + fastboot_getvar_all(response); + break; default: fastboot_fail("Unknown multiresponse command", response); break; diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index 8cb8ffa2c6..fc5e1dac87 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -29,53 +29,67 @@ static void getvar_is_userspace(char *var_parameter, char *response);
static const struct { const char *variable; + bool list; void (*dispatch)(char *var_parameter, char *response); } getvar_dispatch[] = { { .variable = "version", - .dispatch = getvar_version + .dispatch = getvar_version, + .list = true, }, { .variable = "version-bootloader", - .dispatch = getvar_version_bootloader + .dispatch = getvar_version_bootloader, + .list = true }, { .variable = "downloadsize", - .dispatch = getvar_downloadsize + .dispatch = getvar_downloadsize, + .list = true }, { .variable = "max-download-size", - .dispatch = getvar_downloadsize + .dispatch = getvar_downloadsize, + .list = true }, { .variable = "serialno", - .dispatch = getvar_serialno + .dispatch = getvar_serialno, + .list = true }, { .variable = "version-baseband", - .dispatch = getvar_version_baseband + .dispatch = getvar_version_baseband, + .list = true }, { .variable = "product", - .dispatch = getvar_product + .dispatch = getvar_product, + .list = true }, { .variable = "platform", - .dispatch = getvar_platform + .dispatch = getvar_platform, + .list = true }, { .variable = "current-slot", - .dispatch = getvar_current_slot + .dispatch = getvar_current_slot, + .list = true #if IS_ENABLED(CONFIG_FASTBOOT_FLASH) }, { .variable = "has-slot", - .dispatch = getvar_has_slot + .dispatch = getvar_has_slot, + .list = false #endif #if IS_ENABLED(CONFIG_FASTBOOT_FLASH_MMC) }, { .variable = "partition-type", - .dispatch = getvar_partition_type + .dispatch = getvar_partition_type, + .list = false #endif #if IS_ENABLED(CONFIG_FASTBOOT_FLASH) }, { .variable = "partition-size", - .dispatch = getvar_partition_size + .dispatch = getvar_partition_size, + .list = false #endif }, { .variable = "is-userspace", - .dispatch = getvar_is_userspace + .dispatch = getvar_is_userspace, + .list = true } };
@@ -237,6 +251,38 @@ static void getvar_is_userspace(char *var_parameter, char *response) fastboot_okay("no", response); }
+int current_all_dispatch; +void fastboot_getvar_all(char *response) +{ + /* + * Find a dispatch getvar that can be listed and send + * it as INFO until we reach the end. + */ + while (current_all_dispatch < ARRAY_SIZE(getvar_dispatch)) { + if (!getvar_dispatch[current_all_dispatch].list) { + current_all_dispatch++; + continue; + } + + char envstr[FASTBOOT_RESPONSE_LEN] = { 0 }; + getvar_dispatch[current_all_dispatch].dispatch(NULL, envstr); + + char *envstr_start = envstr; + if (!strncmp("OKAY", envstr, 4) || !strncmp("FAIL", envstr, 4)) + envstr_start += 4; + + fastboot_response("INFO", response, "%s: %s", + getvar_dispatch[current_all_dispatch].variable, + envstr_start); + + current_all_dispatch++; + return; + } + + fastboot_response("OKAY", response, NULL); + current_all_dispatch = 0; +} + /** * fastboot_getvar() - Writes variable indicated by cmd_parameter to response. * @@ -254,6 +300,9 @@ void fastboot_getvar(char *cmd_parameter, char *response) { if (!cmd_parameter) { fastboot_fail("missing var", response); + } else if (!strncmp("all", cmd_parameter, 3) && strlen(cmd_parameter) == 3) { + current_all_dispatch = 0; + fastboot_response("MORE", response, NULL); } else { #define FASTBOOT_ENV_PREFIX "fastboot." int i; diff --git a/include/fastboot-internal.h b/include/fastboot-internal.h index bf2f2b3c89..610d4f9141 100644 --- a/include/fastboot-internal.h +++ b/include/fastboot-internal.h @@ -18,6 +18,13 @@ extern u32 fastboot_buf_size; */ extern void (*fastboot_progress_callback)(const char *msg);
+/** + * fastboot_getvar_all() - Writes current variable being listed from "all" to response. + * + * @response: Pointer to fastboot response buffer + */ +void fastboot_getvar_all(char *response); + /** * fastboot_getvar() - Writes variable indicated by cmd_parameter to response. *
Hi Svyatoslav,
Some small comments below.
With those addressed, please add:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- all Provides all info from commands above as
- case FASTBOOT_COMMAND_GETVAR:
default: fastboot_fail("Unknown multiresponse command", response); break;break;
- bool list; void (*dispatch)(char *var_parameter, char *response);
}, { .variable = "version-bootloader",.list = true,
}, { .variable = "downloadsize",.list = true
}, { .variable = "max-download-size",.list = true
}, { .variable = "serialno",.list = true
}, { .variable = "version-baseband",.list = true
}, { .variable = "product",.list = true
}, { .variable = "platform",.list = true
}, { .variable = "current-slot",.list = true
.list = true
.list = false
.list = false
.list = false
}.list = true
static please, as this is only used in drivers/fastboot/fb_getvar.c
- while (current_all_dispatch < ARRAY_SIZE(getvar_dispatch)) {
continue;
./scripts/checkpatch.pl --strict --u-boot complains a missing line here
envstr_start += 4;
envstr_start);
return;
- fastboot_response("OKAY", response, NULL);
- current_all_dispatch = 0;
- fastboot_getvar() - Writes variable indicated by cmd_parameter to response.
- } else if (!strncmp("all", cmd_parameter, 3) && strlen(cmd_parameter) == 3) {
} else {fastboot_response("MORE", response, NULL);
- fastboot_getvar_all() - Writes current variable being listed from "all" to response.
-- 2.40.1
14 листопада 2023 р. 11:32:35 GMT+02:00, Mattijs Korpershoek mkorpershoek@baylibre.com написав(-ла):
Hi Svyatoslav,
.list = true
.list = false
.list = false
.list = false
}.list = true
continue;
About missing lines, I have intentionally not added them since it does not make reading code harder while having a line-space-line IMHO makes it more unpleasant to read. I would like to leave it as is if possible. Everything else will be adjusted. Thanks!
envstr_start += 4;
envstr_start);
return;
-- 2.40.1
Separate record overflow logic and add console_record_isempty as available calls don't serve to know output has been read fully with readline's.
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- common/console.c | 15 ++++++++++++--- include/console.h | 14 ++++++++++++++ test/ut.c | 9 ++++----- 3 files changed, 30 insertions(+), 8 deletions(-)
diff --git a/common/console.c b/common/console.c index 98c3ee6ca6..8a869b137e 100644 --- a/common/console.c +++ b/common/console.c @@ -818,6 +818,8 @@ int console_record_init(void) ret = membuff_new((struct membuff *)&gd->console_in, CONFIG_CONSOLE_RECORD_IN_SIZE);
+ gd->flags |= GD_FLG_RECORD; + return ret; }
@@ -836,11 +838,13 @@ int console_record_reset_enable(void) return 0; }
-int console_record_readline(char *str, int maxlen) +bool console_record_overflow(void) { - if (gd->flags & GD_FLG_RECORD_OVF) - return -ENOSPC; + return gd->flags & GD_FLG_RECORD_OVF ? true : false; +}
+int console_record_readline(char *str, int maxlen) +{ return membuff_readline((struct membuff *)&gd->console_out, str, maxlen, '\0'); } @@ -850,6 +854,11 @@ int console_record_avail(void) return membuff_avail((struct membuff *)&gd->console_out); }
+bool console_record_isempty(void) +{ + return membuff_isempty((struct membuff *)&gd->console_out); +} + int console_in_puts(const char *str) { return membuff_put((struct membuff *)&gd->console_in, str, strlen(str)); diff --git a/include/console.h b/include/console.h index ceb733b5cb..c053bc9ba8 100644 --- a/include/console.h +++ b/include/console.h @@ -64,6 +64,13 @@ void console_record_reset(void); */ int console_record_reset_enable(void);
+/** + * console_record_overflow() - returns state of buffers overflow + * + * Return: true if the console buffer was overflowed + */ +bool console_record_overflow(void); + /** * console_record_readline() - Read a line from the console output * @@ -84,6 +91,13 @@ int console_record_readline(char *str, int maxlen); */ int console_record_avail(void);
+/** + * console_record_isempty() - Returns if console output is empty + * + * Return: true if empty + */ +bool console_record_isempty(void); + /** * console_in_puts() - Write a string to the console input buffer * diff --git a/test/ut.c b/test/ut.c index 28da417686..d202644a15 100644 --- a/test/ut.c +++ b/test/ut.c @@ -53,15 +53,14 @@ long ut_check_delta(ulong last)
static int readline_check(struct unit_test_state *uts) { - int ret; - - ret = console_record_readline(uts->actual_str, sizeof(uts->actual_str)); - if (ret == -ENOSPC) { + if (console_record_overflow()) { ut_fail(uts, __FILE__, __LINE__, __func__, "Console record buffer too small - increase CONFIG_CONSOLE_RECORD_OUT_SIZE"); - return ret; + return -ENOSPC; }
+ console_record_readline(uts->actual_str, sizeof(uts->actual_str)); + return 0; }
If line overflows readline it will not be returned, fix this behavior, make it optional and documented properly.
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- boot/bootmeth_extlinux.c | 2 +- common/console.c | 2 +- include/membuff.h | 5 +++-- lib/membuff.c | 4 ++-- 4 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/boot/bootmeth_extlinux.c b/boot/bootmeth_extlinux.c index aa2a4591eb..ae0ad1d53e 100644 --- a/boot/bootmeth_extlinux.c +++ b/boot/bootmeth_extlinux.c @@ -82,7 +82,7 @@ static int extlinux_fill_info(struct bootflow *bflow) log_debug("parsing bflow file size %x\n", bflow->size); membuff_init(&mb, bflow->buf, bflow->size); membuff_putraw(&mb, bflow->size, true, &data); - while (len = membuff_readline(&mb, line, sizeof(line) - 1, ' '), len) { + while (len = membuff_readline(&mb, line, sizeof(line) - 1, ' ', true), len) { char *tok, *p = line;
tok = strsep(&p, " "); diff --git a/common/console.c b/common/console.c index 8a869b137e..cd56035171 100644 --- a/common/console.c +++ b/common/console.c @@ -846,7 +846,7 @@ bool console_record_overflow(void) int console_record_readline(char *str, int maxlen) { return membuff_readline((struct membuff *)&gd->console_out, str, - maxlen, '\0'); + maxlen, '\0', false); }
int console_record_avail(void) diff --git a/include/membuff.h b/include/membuff.h index 21051b0c54..4eba626ce1 100644 --- a/include/membuff.h +++ b/include/membuff.h @@ -192,10 +192,11 @@ int membuff_free(struct membuff *mb); * @mb: membuff to adjust * @str: Place to put the line * @maxlen: Maximum line length (excluding terminator) + * @must_fit: If true then str is empty if line doesn't fit * Return: number of bytes read (including terminator) if a line has been - * read, 0 if nothing was there + * read, 0 if nothing was there or line didn't fit when must_fit is set */ -int membuff_readline(struct membuff *mb, char *str, int maxlen, int minch); +int membuff_readline(struct membuff *mb, char *str, int maxlen, int minch, bool must_fit);
/** * membuff_extend_by() - expand a membuff diff --git a/lib/membuff.c b/lib/membuff.c index 36dc43a523..964e504d5b 100644 --- a/lib/membuff.c +++ b/lib/membuff.c @@ -288,7 +288,7 @@ int membuff_free(struct membuff *mb) (mb->end - mb->start) - 1 - membuff_avail(mb); }
-int membuff_readline(struct membuff *mb, char *str, int maxlen, int minch) +int membuff_readline(struct membuff *mb, char *str, int maxlen, int minch, bool must_fit) { int len; /* number of bytes read (!= string length) */ char *s, *end; @@ -310,7 +310,7 @@ int membuff_readline(struct membuff *mb, char *str, int maxlen, int minch) }
/* couldn't get the whole string */ - if (!ok) { + if (!ok && must_fit) { if (maxlen) *orig = '\0'; return 0;
"oem console" serves to read console record buffer.
Signed-off-by: Ion Agorria ion@agorria.com Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- doc/android/fastboot.rst | 1 + drivers/fastboot/Kconfig | 7 +++++++ drivers/fastboot/fb_command.c | 39 +++++++++++++++++++++++++++++++++++ include/fastboot.h | 1 + 4 files changed, 48 insertions(+)
diff --git a/doc/android/fastboot.rst b/doc/android/fastboot.rst index 1ad8a897c8..05d8f77759 100644 --- a/doc/android/fastboot.rst +++ b/doc/android/fastboot.rst @@ -29,6 +29,7 @@ The following OEM commands are supported (if enabled): with <arg> = boot_ack boot_partition - ``oem bootbus`` - this executes ``mmc bootbus %x %s`` to configure eMMC - ``oem run`` - this executes an arbitrary U-Boot command +- ``oem console`` - this dumps U-Boot console record buffer
Support for both eMMC and NAND devices is included.
diff --git a/drivers/fastboot/Kconfig b/drivers/fastboot/Kconfig index 837c6f1180..58b08120a4 100644 --- a/drivers/fastboot/Kconfig +++ b/drivers/fastboot/Kconfig @@ -241,6 +241,13 @@ config FASTBOOT_OEM_RUN this feature if you are using verified boot, as it will allow an attacker to bypass any restrictions you have in place.
+config FASTBOOT_CMD_OEM_CONSOLE + bool "Enable the 'oem console' command" + depends on CONSOLE_RECORD + help + Add support for the "oem console" command to input and read console + record buffer. + endif # FASTBOOT
endmenu diff --git a/drivers/fastboot/fb_command.c b/drivers/fastboot/fb_command.c index 6f621df074..acf5971108 100644 --- a/drivers/fastboot/fb_command.c +++ b/drivers/fastboot/fb_command.c @@ -41,6 +41,7 @@ static void reboot_recovery(char *, char *); static void oem_format(char *, char *); static void oem_partconf(char *, char *); static void oem_bootbus(char *, char *); +static void oem_console(char *, char *); static void run_ucmd(char *, char *); static void run_acmd(char *, char *);
@@ -108,6 +109,10 @@ static const struct { .command = "oem run", .dispatch = CONFIG_IS_ENABLED(FASTBOOT_OEM_RUN, (run_ucmd), (NULL)) }, + [FASTBOOT_COMMAND_OEM_CONSOLE] = { + .command = "oem console", + .dispatch = CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_CONSOLE, (oem_console), (NULL)) + }, [FASTBOOT_COMMAND_UCMD] = { .command = "UCmd", .dispatch = CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT, (run_ucmd), (NULL)) @@ -159,6 +164,23 @@ void fastboot_multiresponse(int cmd, char *response) case FASTBOOT_COMMAND_GETVAR: fastboot_getvar_all(response); break; +#if CONFIG_IS_ENABLED(FASTBOOT_CMD_OEM_CONSOLE) + case FASTBOOT_COMMAND_OEM_CONSOLE: + char buf[FASTBOOT_RESPONSE_LEN] = { 0 }; + + if (console_record_isempty()) { + console_record_reset(); + fastboot_okay(NULL, response); + } else { + int ret = console_record_readline(buf, sizeof(buf) - 5); + + if (ret < 0) + fastboot_fail("Error reading console", response); + else + fastboot_response("INFO", response, "%s", buf); + } + break; +#endif default: fastboot_fail("Unknown multiresponse command", response); break; @@ -503,3 +525,20 @@ static void __maybe_unused oem_bootbus(char *cmd_parameter, char *response) else fastboot_okay(NULL, response); } + +/** + * oem_console() - Execute the OEM console command + * + * @cmd_parameter: Pointer to command parameter + * @response: Pointer to fastboot response buffer + */ +static void __maybe_unused oem_console(char *cmd_parameter, char *response) +{ + if (cmd_parameter) + console_in_puts(cmd_parameter); + + if (console_record_isempty()) + fastboot_fail("Empty console", response); + else + fastboot_response("MORE", response, NULL); +} diff --git a/include/fastboot.h b/include/fastboot.h index d1a2b74b2f..23d26fb4be 100644 --- a/include/fastboot.h +++ b/include/fastboot.h @@ -37,6 +37,7 @@ enum { FASTBOOT_COMMAND_OEM_PARTCONF, FASTBOOT_COMMAND_OEM_BOOTBUS, FASTBOOT_COMMAND_OEM_RUN, + FASTBOOT_COMMAND_OEM_CONSOLE, FASTBOOT_COMMAND_ACMD, FASTBOOT_COMMAND_UCMD, FASTBOOT_COMMAND_COUNT
Hi Svyatoslav,
- bool "Enable the 'oem console' command"
- depends on CONSOLE_RECORD
- help
record buffer.
endif # FASTBOOT
- [FASTBOOT_COMMAND_OEM_CONSOLE] = {
- }, [FASTBOOT_COMMAND_UCMD] = { .command = "UCmd", .dispatch = CONFIG_IS_ENABLED(FASTBOOT_UUU_SUPPORT, (run_ucmd), (NULL))
Checkpatch also complains about this.
Can we rewrite this using if (IS_ENABLED(CONFIG...)) please ?
- case FASTBOOT_COMMAND_OEM_CONSOLE:
} else {
if (ret < 0)
else
break;
- oem_console() - Execute the OEM console command
- @cmd_parameter: Pointer to command parameter
- if (cmd_parameter)
- if (console_record_isempty())
- else
MORE -> TEXT
- FASTBOOT_COMMAND_OEM_CONSOLE, FASTBOOT_COMMAND_ACMD, FASTBOOT_COMMAND_UCMD, FASTBOOT_COMMAND_COUNT
-- 2.40.1
14 листопада 2023 р. 12:24:52 GMT+02:00, Mattijs Korpershoek mkorpershoek@baylibre.com написав(-ла):
Hi Svyatoslav,
- help
record buffer.
endif # FASTBOOT
Please, do not relay on checkpatch that much. In this case #ifdef is better since in this case all under ifdef will be cut off while using if(...) requires all code under the if to be able to be run even if config is not enabled. Thanks.
} else {
if (ret < 0)
else
break;
- else
MORE -> TEXT
-- 2.40.1
Hi Svyatoslav,
Hi Svyatoslav,
- help
record buffer.
endif # FASTBOOT
I understand that sometimes, checkpatch generates false positives or bad suggestions. I also understand the differences between #ifdef and if (IS_ENABLED()).
I did not measure whether the binary size is bigger when switching from #ifdef to "if IS_ENABLED()" but I suspect that the compiler can optimize this out as it's known at compile-time.
This file (and the fastboot code in general) mostly uses "if (IS_ENABLED())" and to keep the code consistent I recommend using it.
Therefore, can we please use if (IS_ENABLED()) here ?
Thank you
Mattijs
} else {
if (ret < 0)
else
break;
- else
MORE -> TEXT
-- 2.40.1
Hi Svyatoslav, Ion,
Thank you for these series.
I'm happy to fastboot getvar all implemented since it's standardly supported on Android phones.
fastboot oem console seems like a nice debug tool as well when no console is available.
I do have some concerns with the series, mainly because the introduction of the "MORE" byte response. "MORE" is not part of the fastboot specification [1].
However, that specification documents "TEXT", which, per my understanding, should allow to send multiple responses as well.
Could we implement this using "TEXT" instead ?
[1] https://android.googlesource.com/platform/system/core/+/master/fastboot/#tra...
-- 2.40.1
9 листопада 2023 р. 10:41:30 GMT+02:00, Mattijs Korpershoek mkorpershoek@baylibre.com написав(-ла):
Hi Svyatoslav, Ion,
Hello Mattijs! Thank you for your suggestions and so rapid responce!
I see no issues with replacing MORE with TEXT whatsoever.
These patches were mainly developed and used for our internal development needs but since they served extremely well, I have decided to push them upstream so other developers could benefit as well.
If you have no other suggestions then swap more > text, please send your reviewed-by to patch and I will reload v2 with swap included.
Best regards, Svyatoslav R.
-- 2.40.1
Hi Svyatoslav,
Hi Svyatoslav, Ion,
Thank you for taking the time to upstream.
I will do a more thorough review in the coming days, I wanted to get feedback on MORE->TEXT first.
-- 2.40.1
чт, 9 лист. 2023 р. о 13:00 Mattijs Korpershoek mkorpershoek@baylibre.com пише:
Hi Svyatoslav,
Hi Svyatoslav, Ion,
I have just tested with TEXT and fastboot works exactly the same way it worked with MORE. I will upload v2 with swap alongside any other changes, if such would be needed.
-- 2.40.1
Mattijs Korpershoek
Svyatoslav Ryhel
