Re: [U-Boot] [PATCH] usb: do explicit unaligned accesses
Dear Albert ARIBAUD,
Hi Marek,
I think you are talking about lumping small-sized accesses together into a bigger access possibly aligned.
This is exactly what I mean.
If I am correct, then I don't think this is related to misaligned accesses.
Why won't it be? Such access can in the end turn out to be aligned, therefore leveraging all the penalty.
I have not expressed myself clearly. Yes, access lumping is related to access alignment. What I meant is: disallowing misaligned native accesses will not prevent access lumping. Misalignment restrictions do indeed restrict how such lumpings will happen, but it does not prevent lumping per se.
One place where lumping and misalignement prevention did clash was raised in the previous discussion: a 7+1 bytes function-local char array was allocated on a non-aligned address (which is possible and normal because it is a char) and was initialized with some content. The compiler lumped the initialization as two misaligned 32-byte native accesses, despite misaligned native accesses being forbidden by compiler command line options. This was a compiler bug.
But that'd mean that instead of fixing a compiler, we'd be doing a workaround in our code?
If I am not correct, can you please detail what you meant?
Besides, right now, the code is much more readable. So I really don't like adding some strange macros to force crazy aligned access if the compiler can do it for us and can do it better.
I personally would let the compiler do it too, but I prefer it to be clearly indicated to the reader of the code when an access is known to be misaligned.
I'd enable enable the Alignment trapping in the CPU and die on an unaligned access at runtime -- to indicate the user that he should fix his bloody compiler.
... or fix his bloody structure, or fix his bloody f...ixing pointer arithmetic, or... but I do agree with the trapping, and that's my plan.
However other architectures may need, or choose, another stance on alignments, and it is best if they don't have to discover intended misaligned accesses the hard way.
Yet still, in such case, valid compiler has to generate valid workaround code.
Thus my opinion that any misaligned access which cannot be fixed should not be sliently left for the compiler to handle, but should (also) be clearly marked as such, if only for humans to notice.
I can't say I agree here ... since it's a really ad-hoc solution. I can't say I see any real benefit other than that it's hiding possible compiler bugs :-(
Best regards, Marek Vasut
Amicalement,
