[U-Boot] [PATCH v2] serial: omap: Introduce DM specific omap serial
Add driver model support for OMAP_SERIAL while reusing the functions in ns16550.c
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Based on the conclusion on the thread[1], added a separate driver for omap uart.
[1] https://patchwork.ozlabs.org/patch/944756/
Changes since v1: - Updated ifdefs in NS16550_init() to use OMAP_SERIAL.
drivers/serial/Kconfig | 9 +++ drivers/serial/Makefile | 1 + drivers/serial/ns16550.c | 47 +------------ drivers/serial/serial_omap.c | 126 +++++++++++++++++++++++++++++++++++ 4 files changed, 139 insertions(+), 44 deletions(-) create mode 100644 drivers/serial/serial_omap.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 766e5ced03..0aa2338135 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -625,6 +625,15 @@ config MSM_SERIAL for example APQ8016 and MSM8916. Single baudrate is supported in current implementation (115200).
+config OMAP_SERIAL + bool "Support for OMAP specific UART" + depends on DM_SERIAL + default y if (ARCH_OMAP2PLUS || SOC_DA8XX) + select SYS_NS16550 + help + If you have an TI based SoC and want to use the on-chip serial + port, say Y to this option. If unsure say N. + config OWL_SERIAL bool "Actions Semi OWL UART" depends on DM_SERIAL && ARCH_OWL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 9fa81d855d..03dc29ee2e 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -65,6 +65,7 @@ obj-$(CONFIG_MVEBU_A3700_UART) += serial_mvebu_a3700.o obj-$(CONFIG_MPC8XX_CONS) += serial_mpc8xx.o obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o obj-$(CONFIG_OWL_SERIAL) += serial_owl.o +obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 9c80090aa7..f9041aa626 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -175,7 +175,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) ;
serial_out(CONFIG_SYS_NS16550_IER, &com_port->ier); -#if defined(CONFIG_ARCH_OMAP2PLUS) +#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_OMAP_SERIAL) serial_out(0x7, &com_port->mdr1); /* mode select reset TL16C750*/ #endif
@@ -183,7 +183,8 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) serial_out(ns16550_getfcr(com_port), &com_port->fcr); if (baud_divisor != -1) NS16550_setbrg(com_port, baud_divisor); -#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_SOC_DA8XX) +#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_SOC_DA8XX) || \ + defined(CONFIG_OMAP_SERIAL) /* /16 is proper to hit 115200 with 48MHz */ serial_out(0, &com_port->mdr1); #endif @@ -279,42 +280,6 @@ DEBUG_UART_FUNCS
#endif
-#ifdef CONFIG_DEBUG_UART_OMAP - -#include <debug_uart.h> - -static inline void _debug_uart_init(void) -{ - struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; - int baud_divisor; - - baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, - CONFIG_BAUDRATE); - serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); - serial_dout(&com_port->mdr1, 0x7); - serial_dout(&com_port->mcr, UART_MCRVAL); - serial_dout(&com_port->fcr, UART_FCR_DEFVAL); - - serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); - serial_dout(&com_port->dll, baud_divisor & 0xff); - serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); - serial_dout(&com_port->lcr, UART_LCRVAL); - serial_dout(&com_port->mdr1, 0x0); -} - -static inline void _debug_uart_putc(int ch) -{ - struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; - - while (!(serial_din(&com_port->lsr) & UART_LSR_THRE)) - ; - serial_dout(&com_port->thr, ch); -} - -DEBUG_UART_FUNCS - -#endif - #ifdef CONFIG_DM_SERIAL static int ns16550_serial_putc(struct udevice *dev, const char ch) { @@ -489,12 +454,6 @@ static const struct udevice_id ns16550_serial_ids[] = { { .compatible = "ingenic,jz4780-uart", .data = PORT_JZ4780 }, { .compatible = "nvidia,tegra20-uart", .data = PORT_NS16550 }, { .compatible = "snps,dw-apb-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap2-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap3-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap4-uart", .data = PORT_NS16550 }, - { .compatible = "ti,am3352-uart", .data = PORT_NS16550 }, - { .compatible = "ti,am4372-uart", .data = PORT_NS16550 }, - { .compatible = "ti,dra742-uart", .data = PORT_NS16550 }, {} }; #endif /* OF_CONTROL && !OF_PLATDATA */ diff --git a/drivers/serial/serial_omap.c b/drivers/serial/serial_omap.c new file mode 100644 index 0000000000..d8a047bb71 --- /dev/null +++ b/drivers/serial/serial_omap.c @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments' OMAP serial driver + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <dt-structs.h> +#include <ns16550.h> +#include <serial.h> +#include <clk.h> + +#ifndef CONFIG_SYS_NS16550_CLK +#define CONFIG_SYS_NS16550_CLK 0 +#endif + +#ifdef CONFIG_DEBUG_UART_OMAP + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; + int baud_divisor; + + baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE); + serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); + serial_dout(&com_port->mdr1, 0x7); + serial_dout(&com_port->mcr, UART_MCRVAL); + serial_dout(&com_port->fcr, UART_FCR_DEFVAL); + + serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); + serial_dout(&com_port->dll, baud_divisor & 0xff); + serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); + serial_dout(&com_port->lcr, UART_LCRVAL); + serial_dout(&com_port->mdr1, 0x0); +} + +static inline void _debug_uart_putc(int ch) +{ + struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; + + while (!(serial_din(&com_port->lsr) & UART_LSR_THRE)) + ; + serial_dout(&com_port->thr, ch); +} + +DEBUG_UART_FUNCS + +#endif + +#if CONFIG_IS_ENABLED(DM_SERIAL) + +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +static int omap_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct ns16550_platdata *plat = dev->platdata; + fdt_addr_t addr; + struct clk clk; + int err; + + /* try Processor Local Bus device first */ + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = (unsigned long)map_physmem(addr, 0, MAP_NOCACHE); + + plat->reg_offset = dev_read_u32_default(dev, "reg-offset", 0); + plat->reg_shift = 2; + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + err = clk_get_rate(&clk); + if (!IS_ERR_VALUE(err)) + plat->clock = err; + } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) { + debug("omap serial failed to get clock\n"); + return err; + } + + if (!plat->clock) + plat->clock = dev_read_u32_default(dev, "clock-frequency", + CONFIG_SYS_NS16550_CLK); + if (!plat->clock) { + debug("omap serial clock not defined\n"); + return -EINVAL; + } + + plat->fcr = UART_FCR_DEFVAL; + + return 0; +} + +static const struct udevice_id omap_serial_ids[] = { + { .compatible = "ti,omap2-uart", }, + { .compatible = "ti,omap3-uart", }, + { .compatible = "ti,omap4-uart", }, + { .compatible = "ti,am3352-uart", }, + { .compatible = "ti,am4372-uart", }, + { .compatible = "ti,dra742-uart", }, + {} +}; +#endif /* OF_CONTROL && !OF_PLATDATA */ + +#if CONFIG_IS_ENABLED(SERIAL_PRESENT) +U_BOOT_DRIVER(omap_serial) = { + .name = "omap_serial", + .id = UCLASS_SERIAL, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = omap_serial_ids, + .ofdata_to_platdata = omap_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), +#endif + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif +#endif /* DM_SERIAL */
Changes since v1:
+config OMAP_SERIAL
I didn't see da830 under the .compatible flags.
I believe the da850 has the reg-shift already set, but I am traveling and don't have my desktop Linux computer to test.
Is the SOC_DA8XX necessary here?
I think it's using the more generic ns16550 compatible flags as well which might cause some strange conflict.
help
#endif
int baud_divisor;
CONFIG_BAUDRATE);
-DEBUG_UART_FUNCS
-#endif
- Texas Instruments' OMAP serial driver
- Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
Lokesh Vutla <lokeshvutla@ti.com>
int baud_divisor;
CONFIG_BAUDRATE);
+DEBUG_UART_FUNCS
fdt_addr_t addr;
struct clk clk;
int err;
return -EINVAL;
if (!err) {
plat->clock = err;
return err;
if (!plat->clock)
if (!plat->clock) {
return -EINVAL;
+}; +#endif
2.18.0
On Monday 27 August 2018 03:43 PM, Adam Ford wrote:
On Mon, Aug 27, 2018, 10:41 AM Lokesh Vutla <lokeshvutla@ti.com mailto:lokeshvutla@ti.com> wrote:
Add driver model support for OMAP_SERIAL while reusing the functions in ns16550.c Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com <mailto:lokeshvutla@ti.com>> --- Based on the conclusion on the thread[1], added a separate driver for omap uart. [1] https://patchwork.ozlabs.org/patch/944756/ Changes since v1: - Updated ifdefs in NS16550_init() to use OMAP_SERIAL. drivers/serial/Kconfig | 9 +++ drivers/serial/Makefile | 1 + drivers/serial/ns16550.c | 47 +------------ drivers/serial/serial_omap.c | 126 +++++++++++++++++++++++++++++++++++ 4 files changed, 139 insertions(+), 44 deletions(-) create mode 100644 drivers/serial/serial_omap.c diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 766e5ced03..0aa2338135 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -625,6 +625,15 @@ config MSM_SERIAL for example APQ8016 and MSM8916. Single baudrate is supported in current implementation (115200). +config OMAP_SERIAL + bool "Support for OMAP specific UART" + depends on DM_SERIAL + default y if (ARCH_OMAP2PLUS || SOC_DA8XX)
hmm..right, SOC_DA8XX is not required here. Looks like I overlooked this. Will post a v3 soon.
Thanks and regards, Lokesh
+ select SYS_NS16550 + help + If you have an TI based SoC and want to use the on-chip serial + port, say Y to this option. If unsure say N. + config OWL_SERIAL bool "Actions Semi OWL UART" depends on DM_SERIAL && ARCH_OWL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 9fa81d855d..03dc29ee2e 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -65,6 +65,7 @@ obj-$(CONFIG_MVEBU_A3700_UART) += serial_mvebu_a3700.o obj-$(CONFIG_MPC8XX_CONS) += serial_mpc8xx.o obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o obj-$(CONFIG_OWL_SERIAL) += serial_owl.o +obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 9c80090aa7..f9041aa626 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -175,7 +175,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) ; serial_out(CONFIG_SYS_NS16550_IER, &com_port->ier); -#if defined(CONFIG_ARCH_OMAP2PLUS) +#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_OMAP_SERIAL) serial_out(0x7, &com_port->mdr1); /* mode select reset TL16C750*/ #endif @@ -183,7 +183,8 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) serial_out(ns16550_getfcr(com_port), &com_port->fcr); if (baud_divisor != -1) NS16550_setbrg(com_port, baud_divisor); -#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_SOC_DA8XX) +#if defined(CONFIG_ARCH_OMAP2PLUS) || defined(CONFIG_SOC_DA8XX) || \ + defined(CONFIG_OMAP_SERIAL) /* /16 is proper to hit 115200 with 48MHz */ serial_out(0, &com_port->mdr1); #endif @@ -279,42 +280,6 @@ DEBUG_UART_FUNCS #endif -#ifdef CONFIG_DEBUG_UART_OMAP - -#include <debug_uart.h> - -static inline void _debug_uart_init(void) -{ - struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; - int baud_divisor; - - baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, - CONFIG_BAUDRATE); - serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); - serial_dout(&com_port->mdr1, 0x7); - serial_dout(&com_port->mcr, UART_MCRVAL); - serial_dout(&com_port->fcr, UART_FCR_DEFVAL); - - serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); - serial_dout(&com_port->dll, baud_divisor & 0xff); - serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); - serial_dout(&com_port->lcr, UART_LCRVAL); - serial_dout(&com_port->mdr1, 0x0); -} - -static inline void _debug_uart_putc(int ch) -{ - struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; - - while (!(serial_din(&com_port->lsr) & UART_LSR_THRE)) - ; - serial_dout(&com_port->thr, ch); -} - -DEBUG_UART_FUNCS - -#endif - #ifdef CONFIG_DM_SERIAL static int ns16550_serial_putc(struct udevice *dev, const char ch) { @@ -489,12 +454,6 @@ static const struct udevice_id ns16550_serial_ids[] = { { .compatible = "ingenic,jz4780-uart", .data = PORT_JZ4780 }, { .compatible = "nvidia,tegra20-uart", .data = PORT_NS16550 }, { .compatible = "snps,dw-apb-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap2-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap3-uart", .data = PORT_NS16550 }, - { .compatible = "ti,omap4-uart", .data = PORT_NS16550 }, - { .compatible = "ti,am3352-uart", .data = PORT_NS16550 }, - { .compatible = "ti,am4372-uart", .data = PORT_NS16550 }, - { .compatible = "ti,dra742-uart", .data = PORT_NS16550 }, {} }; #endif /* OF_CONTROL && !OF_PLATDATA */ diff --git a/drivers/serial/serial_omap.c b/drivers/serial/serial_omap.c new file mode 100644 index 0000000000..d8a047bb71 --- /dev/null +++ b/drivers/serial/serial_omap.c @@ -0,0 +1,126 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Texas Instruments' OMAP serial driver + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla <lokeshvutla@ti.com <mailto:lokeshvutla@ti.com>> + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <dt-structs.h> +#include <ns16550.h> +#include <serial.h> +#include <clk.h> + +#ifndef CONFIG_SYS_NS16550_CLK +#define CONFIG_SYS_NS16550_CLK 0 +#endif + +#ifdef CONFIG_DEBUG_UART_OMAP + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; + int baud_divisor; + + baud_divisor = ns16550_calc_divisor(com_port, CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE); + serial_dout(&com_port->ier, CONFIG_SYS_NS16550_IER); + serial_dout(&com_port->mdr1, 0x7); + serial_dout(&com_port->mcr, UART_MCRVAL); + serial_dout(&com_port->fcr, UART_FCR_DEFVAL); + + serial_dout(&com_port->lcr, UART_LCR_BKSE | UART_LCRVAL); + serial_dout(&com_port->dll, baud_divisor & 0xff); + serial_dout(&com_port->dlm, (baud_divisor >> 8) & 0xff); + serial_dout(&com_port->lcr, UART_LCRVAL); + serial_dout(&com_port->mdr1, 0x0); +} + +static inline void _debug_uart_putc(int ch) +{ + struct NS16550 *com_port = (struct NS16550 *)CONFIG_DEBUG_UART_BASE; + + while (!(serial_din(&com_port->lsr) & UART_LSR_THRE)) + ; + serial_dout(&com_port->thr, ch); +} + +DEBUG_UART_FUNCS + +#endif + +#if CONFIG_IS_ENABLED(DM_SERIAL) + +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +static int omap_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct ns16550_platdata *plat = dev->platdata; + fdt_addr_t addr; + struct clk clk; + int err; + + /* try Processor Local Bus device first */ + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->base = (unsigned long)map_physmem(addr, 0, MAP_NOCACHE); + + plat->reg_offset = dev_read_u32_default(dev, "reg-offset", 0); + plat->reg_shift = 2; + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + err = clk_get_rate(&clk); + if (!IS_ERR_VALUE(err)) + plat->clock = err; + } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) { + debug("omap serial failed to get clock\n"); + return err; + } + + if (!plat->clock) + plat->clock = dev_read_u32_default(dev, "clock-frequency", + CONFIG_SYS_NS16550_CLK); + if (!plat->clock) { + debug("omap serial clock not defined\n"); + return -EINVAL; + } + + plat->fcr = UART_FCR_DEFVAL; + + return 0; +} + +static const struct udevice_id omap_serial_ids[] = { + { .compatible = "ti,omap2-uart", }, + { .compatible = "ti,omap3-uart", }, + { .compatible = "ti,omap4-uart", }, + { .compatible = "ti,am3352-uart", }, + { .compatible = "ti,am4372-uart", }, + { .compatible = "ti,dra742-uart", }, + {} +}; +#endif /* OF_CONTROL && !OF_PLATDATA */ + +#if CONFIG_IS_ENABLED(SERIAL_PRESENT) +U_BOOT_DRIVER(omap_serial) = { + .name = "omap_serial", + .id = UCLASS_SERIAL, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = omap_serial_ids, + .ofdata_to_platdata = omap_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), +#endif + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif +#endif /* DM_SERIAL */ -- 2.18.0 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de <mailto:U-Boot@lists.denx.de> https://lists.denx.de/listinfo/u-boot
Adam Ford
Lokesh Vutla
