[U-Boot-Users] [PATCH] mpc83xx: fix phy-connection-type fixup code
use tree passed to us in local blob, not global fdt.
Also use fdt_path_offset to convert to relative offset, since absolute reference is needed to check for rgmii-id mode string value.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc8360emds/mpc8360emds.c | 24 +++++++++++++++--------- 1 files changed, 15 insertions(+), 9 deletions(-)
diff --git a/board/freescale/mpc8360emds/mpc8360emds.c b/board/freescale/mpc8360emds/mpc8360emds.c index 2fcef8b..c1691ae 100644 --- a/board/freescale/mpc8360emds/mpc8360emds.c +++ b/board/freescale/mpc8360emds/mpc8360emds.c @@ -318,28 +318,34 @@ void ft_board_setup(void *blob, bd_t *bd) const char *prop; const char *path;
- nodeoffset = fdt_path_offset(fdt, "/aliases"); + nodeoffset = fdt_path_offset(blob, "/aliases"); if (nodeoffset >= 0) { #if defined(CONFIG_HAS_ETH0) /* fixup UCC 1 if using rgmii-id mode */ path = fdt_getprop(blob, nodeoffset, "ethernet0", NULL); if (path) { - prop = fdt_getprop(blob, nodeoffset, - "phy-connection-type", 0); + path = fdt_path_offset(blob, path); + prop = fdt_getprop(blob, path, + "phy-connection-type", 0); if (prop && (strcmp(prop, "rgmii-id") == 0)) - fdt_setprop(blob, nodeoffset, "phy-connection-type", - "rgmii-rxid", sizeof("rgmii-rxid")); + fdt_setprop(blob, path, + "phy-connection-type", + "rgmii-rxid", + sizeof("rgmii-rxid")); } #endif #if defined(CONFIG_HAS_ETH1) /* fixup UCC 2 if using rgmii-id mode */ path = fdt_getprop(blob, nodeoffset, "ethernet1", NULL); if (path) { - prop = fdt_getprop(blob, nodeoffset, - "phy-connection-type", 0); + path = fdt_path_offset(blob, path); + prop = fdt_getprop(blob, path, + "phy-connection-type", 0); if (prop && (strcmp(prop, "rgmii-id") == 0)) - fdt_setprop(blob, nodeoffset, "phy-connection-type", - "rgmii-rxid", sizeof("rgmii-rxid")); + fdt_setprop(blob, path, + "phy-connection-type", + "rgmii-rxid", + sizeof("rgmii-rxid")); } #endif }
Kim Phillips
